Author Topic: Cutting Holes For Pushbuttons  (Read 3139 times)
JeepMonkey
  • Last login:July 13, 2012, 01:51:24 pm
« on: February 23, 2006, 03:46:33 pm »
Is there a spade bit or maybe a hole saw that will cut a hole the right size for a pushbutton to mount in?  If so, what size?
I really would rather not cut that many holes with a jig saw.
Pins:  Theatre Of Magic, JP The Lost World, Revenge From Mars
rdmustang
  • Last login:February 05, 2011, 12:43:31 pm
  • Planning takes so much time :(
Re: Cutting Holes For Pushbuttons
« Reply #1 on: February 23, 2006, 03:51:01 pm »
A quick search would provide an answer..
1 1/8" (spade or hole)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« Reply #2 on: February 23, 2006, 04:31:58 pm »
Home Depot sells a 1 1/8 metal hole cutter that worked great for me
Necro
  • Last login:December 31, 2025, 03:36:17 pm
« Reply #3 on: February 23, 2006, 04:35:27 pm »
Target sells a set of spade bits (10 of them I think) that has 1 & 1/8th and a bunch of others.  I got it for... $8 I think.  May not be as 'great' as the Home Depot one (it was $5 and they were out of it), but...well you get more options for other controls/joysticks/etc.
toasty
  • Last login:October 10, 2019, 11:48:47 am
  • Purveyor of Fine Latex Products
« Reply #4 on: February 23, 2006, 05:14:47 pm »
Assuming you're using MDF, does a spade bit or a hole saw provide a cleaner hole?  Does it even matter?
hnugz
  • Last login:September 14, 2013, 06:18:38 pm
    • Horrorcore Games
« Reply #5 on: February 23, 2006, 05:16:54 pm »
i dont think it matters, but I used a 1 1/8 in forstner bit and put a piece of wood on the bottom so when it went through the first piece the other was there, made an extremely clean cut.
"Don't play pinball if you only got one arm, cuz your score will suck."
JeepMonkey
« Reply #6 on: February 23, 2006, 05:57:14 pm »
Thanks guys.  I much prefer to use spade bits over hole saws.
miles2912
« Reply #7 on: February 23, 2006, 06:54:30 pm »
I bought a cheap set of hole cutting bits and they burn the MDF after cutting about half way through.  I don't know if this is normal or not so I borrowed a nice set from a neighbor and they still burned the wood but not as bad.  I have a variable speed hand drill and adjusting the speed didn't seem to help that much.  The burns are inside the hold and the MDF was 5/8.  I am going to try some spade bits.
Don
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #8 on: February 23, 2006, 08:03:52 pm »
Don
In wood or a wood product like mdf, you will get the cleanest holes with a forstner bit.
Hubble
  • Last login:December 04, 2022, 02:53:31 pm
« Reply #9 on: February 23, 2006, 08:58:38 pm »
Might be slightly off topic, but . . .
I'm cutting all the holes for my console this weekend (using my dad's drill press).  I know the correct hole diameter for pushbuttons, joysticks, and the spinner.
But the one component I haven't ordered yet is the trackball.  I intend to get one from SlikStik (the 3" illuminated), but I'd like to cut the hole this weekend.  I know it's an odd-shaped hole, but does anyone have dimensions handy, or a graphic they could post with the correct measurements?  I tried Slikstik tech support, but they just suggested I buy the trackball first...
Thanks in advance!
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #10 on: February 23, 2006, 09:12:45 pm »
The trackball template is on the companion CD that comes with the PROJECT ARCADE book.
Necro
« Reply #11 on: February 23, 2006, 09:15:43 pm »
I'm fairly certain that's going to require a hole saw bit also.  I dont know if that was implied, or you were even asking it, but...just FYI.
Dervacumen
  • Last login:June 12, 2024, 01:58:21 am
  • Home of Three Squares dice game
    • Beaker Games
« Reply #12 on: February 23, 2006, 09:18:11 pm »
Forstner bits are great but maybe overkill for this, spade bits a very close second and cheaper (after all, the finesse is hidden by the pushbutton anyway), and hole saws gum up and burn in MDF.  At least my MDF.
Go slow with the spade in MDF and it makes some really beautiful curls.
Derv
Bringing to life a child's imagination.
JeepMonkey
« Reply #13 on: February 23, 2006, 09:40:57 pm »
I agree, the reason I don't like hole saws is because they will burn the wood.  Plus spade bits generally cut deeper, and are a bit easier to center.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #14 on: February 23, 2006, 10:07:22 pm »
I would be sure to just draw the circle for the trackball and use that to center the template for the trackball plate.  The area where the trackball goes is going to be a bigger cut out because of the size of the trackball housing.  I printed off a copy of the trackball template from the bood and used that to make my cut.
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #15 on: February 24, 2006, 01:07:19 pm »
I have used both a spade bit and a forstner bit.  Forstner bit is much cleaner IMO.
Necro
« Reply #16 on: February 24, 2006, 03:14:08 pm »
I haven't done a ton of cutting/drilling like this, but if your using a hand held drill, wouldn't dipping the bit in some water all but eliminate the burning?  The bit would be recooled down to room temp, etc.
Just curious.
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« Reply #17 on: February 24, 2006, 04:20:33 pm »
CUTTING THE HOLES WITH A JIG???, 27 jig-a-saw holes, GREAT SCOTT Marty it can't be done!!!  ;D
I wouldn't even think about cutting the holes with a jig it would look like crap. Definetly get the bit from Home Depot, it will go right through the lexan as well...
The Way Back Machine - http://www.taborious.com
Havok
  • Trade Count: (+17)
« Reply #18 on: February 24, 2006, 04:57:28 pm »
What about a flathead screwdriver and a hammer? That's how I made all my holes...
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #19 on: February 24, 2006, 05:31:04 pm »
I know you can get spade bits cheap, but if you have a local harbor freight you can get a decent set of forstner bits for $30.  Some will say "30 bucks to drill holes - that's way too much" and some will say "must be garbage - only 30 bucks for a set of forstner bits".
Totally up to you and your budget etc.  Personally, I don't mind shelling out the $30 for some bits that will do a good job when needed, but may not be top quality.  I don't believe I will use them that often.  Just my $.02 - err $30 worth.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=47128
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #20 on: February 24, 2006, 09:30:00 pm »
My Harbor Freight forstners have built 6 games so far and also do all my woodworking drilling as well. Great value.
JeepMonkey
« Reply #21 on: February 24, 2006, 09:45:09 pm »
I agree with  buying quality bits for more money since they last and do a good job.  Much better than buying cheap and having them break when you are using them.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #22 on: February 26, 2006, 07:10:49 am »
Just curious.
Why wouldn't you just use cutting oil instead of losing the temper on the bit and screwing it up?
