Author Topic: Things I learned the hard way while making my cabinet.  (Read 15840 times)
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« on: February 19, 2006, 08:29:14 pm »
Hopefully this will serve as a good guide for beginners.  These are all things that I wish I had known before I started my project.  Try and keep these one line type responses.  Start another parallel thread to discuss anything which inspires you.
I'll start:
1.  BYOAC forums will time out if you type a really really long reply and you will loose everything  you typed in that really really long time then you will have to do it all over again, but you won't have the patience and everything will become a crappy abbreviated version of what you typed before.
2.  Tolerance.  MDF is very flat and very smooth and drawers and doors that work wonderfully in mock up will stick later on.  See #3.
3.  Paint is thicker than you thought.  See #2.
4.  Black paint recipies at paint stores include white pigment.  Make sure are very clear when you order that you want it black, black, black.  For extra fun, dress up like a goth and say it's for your living room.  People will always ask you why you're buying gallons of black paint.
5.  Acrylic is impossible to score and snap.  Conversely acrylic is easy to work with a router while sandwiched between two pieces of wood.  Don't fear acrylic.  Don't pay for lexan.
6.  Plan everything.  The only thing that doesn't fit on my cab is the two pinball button holes that I drilled impulsively while building.  I modeled my whole cab in 3d except that. Now I have to find special internal microswitch buttons and hope that they fit.
7.  Wiring takes up more space than you think.  Plan it.  If your PC and coin door in the bottom, and there's a keyboard drawer between your PC and the monitor/CP, you have to get by that drawer.  I found a way.  Luckily.
8.  The oscar controls 3d model of a happ track ball doesn't show the mounting bolts.  Despite modelling my cp in 3d I ended up routing slots for the bottom two mounting bolts in the wall of my CP.  Thank god they didn't end up outside the box.
9. MDF is insidious.  The dust gets everywhere.  I shop vac-ed my whole garage.  I vacuumed everything.  I mean everything.  Walls, my lawn mower, the broom, empty beer bottles, shelves, the floor, my tools, the door.... I'm still picking up pieces of MDF off of the living room carpet.  Don't even think about building inside your house.  Ruin just your garage.
10.  MDF dust is toxic.  This is the one thing I didn't learn the hard way.  I have a long history of working on boats and to me sanding/cutting/dust = mask; always has.  Any money you spend on a mask is an investment in your health.  Don't skimp here.  I honestly didn't know MDF dust is toxic when I started so I'm glad I always wear a mask.
« Last Edit: February 19, 2006, 08:31:16 pm by Mark70 »
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
Mark70
Re: Things I learned the hard way while making my cabinet.
« Reply #1 on: February 19, 2006, 08:41:41 pm »
11.  A router with a deep cutting slot bit on it will "climb".  My router started climbing and it didn't feel any different than when the router base was riding on the material.  I ruined about 12" of one of my t-moulding slots.
12.  When you have your artwork printed make sure that you tell them to print it with no border which seems to be the default for most printers.  Staples/business depot printed my CP art with a border and didn't notice until I was trimming the edges.  My artwork had all shrunk by the width of the white border.  It was mostly cut and installed when I noticed and kept it anyway.
13.  When you make your sawboard make sure the saw motor will clear the clamps while they're in place.
14.  When you make and angled cut with your sawboard, you ruin it for making cuts except on that angle for ever more because it cuts your sawboard off on that angle and you can no longer line up the edge of the sawboard for a regular 90 degree cut.  Make new sawboard.
15.  MDF will split and spread if you screw into the end, even if you pre drill.  Find any way you can to screw perpendicular to the piece.  Usually it means adding blocking
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
« Reply #2 on: February 19, 2006, 09:38:17 pm »
Doesn't project arcade incorporate some of this?  I didn't have any of this happening myself.
always irritating when something goes wrong when posting and everything is erased.  This is actually probably common knowledge, unfortunately!
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: February 19, 2006, 09:41:42 pm »
Yeah but it seems to be happening a lot lately. go easy there new guy  ::)
quarterback
« Reply #4 on: February 19, 2006, 09:50:54 pm »
I'm not sure exactly what the issue is, but if it's that you don't have enough room inside your CP for the buttons, maybe you should take a look at the Sanwa pushbuttons.  ponyboy sells them
NOTE: The 2nd pic here is of a "snap in" style.  As of this posting, ponyboy only carries the screw in style.  The first post in his thread should let you know if that changes
« Last Edit: February 20, 2006, 01:13:38 pm by quarterback »
-- Chad Tower
SirPeale
  • Green Mountain Man
« Reply #5 on: February 19, 2006, 09:59:07 pm »
Before you send, click anywhere.  Hit "CTRL-A, CTRL-C" so you copy everything you just typed into clipboard.  That way if it does time out, you can go back a page and just "CTRL-V" to paste it back in.
Also, make sure when you log in, click the 'always logged in' checkbox.
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #6 on: February 20, 2006, 12:14:51 am »
Even though you may have spent a lot of money on the cabinet (whether a "true cabinet" or you built it yourself) Bondo and black paint will solve many problems when you can't drill/cut worth crap.
[Was putting wheels on my cabinet, mis-drilled through the bottom twice.]
« Reply #7 on: February 20, 2006, 09:17:51 am »
Ergonomics!
Even a mockup can be misleading till you've tried it a few times. My first arcade cabinet is a converted Nintendo cabinet. It has a 22.5 x 8.5 inch control panel. I mounted the joysticks too low and after a bit of playing - your wrists get a little tired. It's a little thing, but something you don't think about till afterwards. The only real fix is to rebuild the CP.
hypernova
« Reply #8 on: February 20, 2006, 12:31:53 pm »
huh? ???
edit:  oh...maybe that's it...i need to use more smileys.  Personally, I hate 'em, but they do help clarify what kind of tone/mood you want to convey in a post.
And i'm hardly new.  Almost a year anniversary for me here.  (I could've used an exclamation point there, but I also hate unnecessary punctuation marks.) ;)
« Last Edit: February 20, 2006, 12:38:59 pm by hypernova »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: February 20, 2006, 01:01:09 pm »
16. Don't install ANYTHING, until you are 100% finished sanding and painting.
17. DO NOT use wall repair putty to fill in holes or repair damaged wood. It is NOT strong enough.
NO MORE!!
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
« Reply #10 on: February 20, 2006, 01:12:45 pm »
I know people like to build their cab as cheap as possible, but when i built mine, I learned a few things, dont go cheap on the controls buy the good ones to start with.  The same with the computer I purchased cheap parts, pcchips mb etc, & I payed for it, get the best computer for your buck, you wont regret it later, i did a 3000 amd 64+ with a gig of ram & it handles, most roms( & this system ran about $350.00) use a big hard drive the first time, i wanted to save money so i purchased a tv, I hated the picture then i purchased a arcade monitor...so i did everything twice, the moral is spend the extra first time its cheaper in the long run, sometime i will see post about people stating they really on a very tight budget, this hobby is not cheap its best to take your time & use quality parts etc
thanks
dm
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
GGKoul
  • Cheesecake Apprentice
« Reply #11 on: February 20, 2006, 01:29:21 pm »
Don't start playing it until you've completly 100% finished your cab.  As it never gets finished after that..
divemaster127
« Reply #12 on: February 20, 2006, 01:32:21 pm »
that's what i did finally a year & 1/2 later i put on the artwork
thanks
dm
Brad
  • Last login:August 03, 2018, 05:43:23 pm
    • www.emuchrist.org
« Reply #13 on: February 20, 2006, 04:36:11 pm »
Boy is this ever true. I've had my cab almost finished for over 2 years. I just play it now despite it needing artwork and decent speakers  ::)
Brad
ChicagoDave
  • Last login:May 18, 2023, 11:08:23 am
    • Dave's Website
« Reply #14 on: February 20, 2006, 05:22:34 pm »
A couple of things I learned:
18. Hot glue is hot.
19. Never let go of a circular saw while it's still spinning.
20. When you measure for the coin door hole, make sure that you account for the fact that the coin door has rounded corners.  I ended up having to repair this by cutting 4 corners off of a piece of MDF and hot glued them into the corners of the hole.  I then used wood filler to fill the gaps and sanded the whole thing down.  After paint, the problem was fixed.
21.  If you use rotating casters, make sure they have enough clearance to rotate completely around.  Any obstruction will cause the cabinet to "lock up" when trying to move it.
Homer Simpson:
"Here's to alcohol, the cause of, and solution to, all life's problems."
hypernova
« Reply #15 on: February 20, 2006, 05:58:02 pm »
I didn't think rotating casters would be possible.  They require so much clearance, it seems it would compromise the stability somewhat.  (Course I tried using 4" ones from work.  3" would still seem a bit too much diameter of motion.)
I propose an addendum to this one:
Hot glue is hot, yet ironically doesn't stay hot enough long enough.
I can totally deviate from that norm.  Mark my words! :angel:
GGKoul
« Reply #16 on: February 20, 2006, 06:39:15 pm »
Don't start playing it until you've completely 100% finished your cab.  As it never gets finished after that..
Brad
I fall in that category too...
dax
  • Last login:August 17, 2006, 02:13:08 pm
« Reply #17 on: February 20, 2006, 06:48:45 pm »
Are you people using Internet Exploder (I mean Explorer)?   If so, that makes sense.  I use Firefox and I can usually go back and not lose my form data.
All this talk about MDF problems... is there some reason why you would want to use it over regular wood or plywood?  Can you not install molding on plywood?  Or is it a cost consideration?  The thing that scares me about MDF is if it gets wet, it gets ruined quickly.
« Last Edit: February 20, 2006, 06:51:53 pm by dax »
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #18 on: February 20, 2006, 07:12:36 pm »
MDF has 3 properties that make it attractive to cabinet builders:
1.)  It is less expensive than cabinet-grade plywood
2.)  It is easy to work with
3.)  It accepts paint very evenly (without wood grain bleeding through).
The disadvantages are:
- Swelling when wet (so keep it inside)
- It's heavier than plywood
- it's messy as hell
NinjaEpisode
  • Last login:June 16, 2019, 06:47:45 pm
« Reply #19 on: February 20, 2006, 07:22:32 pm »
a.k.a. Wear a Mask!  I was a smoker at the time that I did my cab last year and even for me, the dust from that MDF was worse than smoking a pack of cigarettes.  I was sadistic enough to even smoke while I was cutting....after a day of that, I went and grabbed some cheapo masks to cover my mouth and nose.
Mark70
« Reply #20 on: February 20, 2006, 07:38:04 pm »
The choice of MDF over plywood was based on the fact that I hate sanding.  A life of growing up sanding wood boats has just about burned me out on sanding.  Paint "picks up the grain" on plywood, even high quality sanded or veneered plywood. The grain swells unevenly when you paint it and it takes a hell of a lot of filler primer and sanding to get a nice flat surface.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #21 on: February 20, 2006, 08:02:52 pm »
Run 2 skim coats of drywall compound over it.  Problem solved - IF you're going to paint.  Make it the consistency of shampoo to make it easier to work with to cover the grain, and use it regular strength to fill in wider gaps and holes.
Seeing as how I just advised FOR using this, I'd like to ask what you are referring to when you say "holes".  You are COMPLETELY correct in not using it for repairing damaged wood.  The "holes" are what I'm wondering about.  I've got a CP with some mighty hefty cracks on exhibit in Project Announcements that I had no problems filling, and no problems drilling.
  • Last login:April 18, 2026, 05:46:43 pm
« Reply #22 on: February 20, 2006, 09:57:08 pm »
22.  If you are staining you cabinet, stain each piece PRIOR to assembly if you want it to come out as even as possible.
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #23 on: February 21, 2006, 08:00:43 am »
23. EE will slow down your progress and once you start posting there your cabinet will most likely never get done
Mark70
« Reply #24 on: February 21, 2006, 08:33:32 am »
EE? ...my cabinets is done.  Well, as done as they ever really get.
MYX
    • MYX Digital Blog
« Reply #25 on: February 21, 2006, 10:19:18 am »
24. Drill bits are sharp.
25. Arcade building and insomnia may be related.
26. BYOAC forums = lower job performance
27. Talking about building your cab gives your daughter yet another excuse to roll her eyes.
28. Building this thing is a heck of a lot of fun.
M    Y    X
psychopanda
  • Last login:August 31, 2006, 01:13:17 pm
    • PsychoPanda's Secret Grotto
« Reply #26 on: February 21, 2006, 11:04:46 am »
29. Make a plan to organize the cp wires beforehand.
30. Building a cabinet is going to cost you alot more than you think. ;)
missioncontrol
« Reply #27 on: February 21, 2006, 12:24:06 pm »
Everything Else
Buddabing
« Reply #28 on: February 21, 2006, 03:47:12 pm »
32. The enemy of good is better.
Please read the wiki!
RayB
  • There's my post
    • RayB.com
« Reply #29 on: February 22, 2006, 11:40:57 am »
Maybe I should ammend/clarify. Don't use it for control panel repair or large deep holes. It will end up just crumbling. If used on the control panel, when you drill button holes through it, it tends to break off very easily. Note, I am talking about wall patching compound, or whatever it's called. I'm not talking about bondo, which is what everyone recommends we use.
NO MORE!!
Doc Thirst
  • Last login:November 18, 2013, 09:55:28 pm
« Reply #30 on: February 22, 2006, 11:56:23 am »
Joint Compound?
RayB
  • There's my post
    • RayB.com
« Reply #31 on: February 22, 2006, 12:03:41 pm »
White stuff that dries kind of chalky....  ???
NO MORE!!
missioncontrol
« Reply #32 on: February 22, 2006, 03:25:14 pm »
Oh and if you ever decide to do a keyboard hack don't complete the hack and put it away for 8 months then come back and expect to know what your layout was and what you wire labels were for and other stuff you didn't think you needed to write down because you didn't plan on it being 8 months before you did anything with the hack.........
arzoo
  • Last login:March 24, 2026, 08:14:12 am
  • Robots WILL kill you.
    • LEDBlinky
« Reply #33 on: February 23, 2006, 08:53:47 am »
This may seem counter intuitive, but if you get hot glue on your skin, immediately spread it thin (smear it) with your fingers. The thinner the layer of glue, the quicker it cools and you won
Robots will kill you.
Arcade Addiction
MovingTarget
  • Last login:January 03, 2025, 10:55:15 am
« Reply #34 on: February 23, 2006, 08:57:28 am »
krick
  • Gotta have blue hair.
« Reply #35 on: February 23, 2006, 11:23:51 am »
The same goes for a router.  I'm lucky I didn't take my finger off.  It did bleed a lot though.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
ChicagoDave
    • Dave's Website
« Reply #36 on: February 23, 2006, 11:35:35 am »
Mine just caught a piece of the wood, shot up and hit me in the stomach.  I was pretty lucky.  The saw then landed on the cement garage floor.  I thought the laser would have been knocked out of line, but it was fine.  My cut was screwed up though.
Homer Simpson:
krick
« Reply #37 on: February 23, 2006, 11:49:17 am »
I finished routing around the edge of a piece of MDF, then I sat the router on its side on top and proceeded to brush off the MDF-dust with my hand and contacted the still spinning router bit.  What a dumbass I am.  It's no wonder I had two minor but equally bloody shop class accidents in jr highschool.  One required stitches.  Me and power tools, really don't mix well.
Hantarex Polo 15KHz
« Reply #38 on: February 23, 2006, 03:30:54 pm »
I was cutting an 1/8" peice of plexi for the CP. I was pretty excited since the project was coming to a close. Wasn't even thinking about securing the plexi down. Got the drill to full speed and when it hit the plexi - the plexi spun around and hit my hand. I seriously thought I cut something off.
Wouldn't that be some sh!t? Cut off your gaming hand trying to build a arcade machine?
jcrouse
    • CPViewer
« Reply #39 on: February 23, 2006, 03:48:16 pm »
Thanks for a good afternoon chuckle at work.
John
