Author Topic: Defender control panel - 2 players  (Read 5613 times)
francmusic
  • Last login:August 24, 2009, 07:15:59 am
« on: January 16, 2006, 06:07:11 pm »
I'am looking for some examples (vector files) of Defender control panel redesigned for 2 players. How to make two players panel with 7 buttons/player in original Defender dimensions?
soulblazer28
  • Last login:September 27, 2009, 09:12:17 pm
Re: Defender control panel - 2 players
« Reply #1 on: January 18, 2006, 11:44:49 pm »
I thought about this for a while myself. In a typical 7 button fighter configuration, player 1 button 7 could be used for the reverse, and player 2 button 7 could be used as the inviso, while strong-punch, fierce punch (sf terms) would be thrust and shoot respectively.  Maybe it might work, maybe it would feel too uncomfortable.
I decided to just make a dedicated stargate panel instead, moving the hyperspace button a few inches right of the shoot button where it is more easily accesible, and in the middle of the panel will be a four way joystick.  The minimal cost for this extra panel is small compared to the joy of playing Stargate again and trying to break that 2.2 million barrier of mine. Though I dont expect my skill and reflex would have improved after 15 years. *sigH* how i miss those Yllabian dogfights.
Of course I haven't actually built them yet, parts are in route to build the prototype :)  But just a thought.
erikthecat
  • Last login:September 21, 2008, 06:53:57 am
  • I 've Built My Own Arcade Cabinet & Controls!!
    • BYO Williams Defender Trubute
« Reply #2 on: January 19, 2006, 08:26:05 am »
i don't think there is enough space on an original size panel for everything:)
Regards,
GaRy:o)
please visit...
www.SplatThatCat.com/arcade/
www.SplatThatCat.com/artwork/
Classic arcade game playing,
in style, in your own home:o)
mahuti
« Reply #3 on: January 19, 2006, 09:23:08 am »
My cab; click here
Havok
  • Trade Count: (+17)
« Reply #4 on: January 19, 2006, 11:33:32 am »
My cab; click here
Not to de-rail the thread, but I like your fighter layout on your cab - I am planning a similiar removable panel on my cab, the panels will be 24 x 10, which looks to be around the same size as yours. Do you have a visio diagram of your layout, or measurements?
Now, back to the thread at hand...
I don't see why you couldn't use the fighter panel for defender, I guess it just depends if you want an "authentic" layout or not.
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
« Reply #5 on: January 19, 2006, 11:43:07 am »
The Defender panel is 24.5"X8. I was working on a redesign, but I may change it again to be 4 button Neo-Geo layout. I have a full sized .tiff file if anyone is interested:
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #6 on: January 19, 2006, 07:47:10 pm »
It fits. I have a 2-player six-button fighter layout on that panel. Looks alot like these other guys' panels. Works great although elbow room is a little tight.
-pmc
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #7 on: January 20, 2006, 07:06:22 pm »
I have a fighter style layout on my cab as well.  It fits, but it's a bit tight.  I accidentally drilled my start buttons in the wrong place so I actually have two extra buttons at the top.  I had to be a bit creative (with a saw) when fitting it into the original cabinet after that though.
I also have vector art (in adobe illustrator) of the sideart for Defender I picked up from somewhere.  If anyone cares.  :D
mahuti
« Reply #8 on: January 21, 2006, 01:08:09 am »
you can get that defender art from the Arcade Art Library. Link in my sig.
francmusic
« Reply #9 on: February 16, 2006, 03:14:47 am »
Ok. I think it's my final version of my defender-styled  CP artwork for 2 players  :D
What do you think? It's will be panel for defender cab, so I chose simple, classic graphics.
I tested pushbuttons and it's working very good and confortable.
Thanks soulblazer28  for your suggestion. :)
Next step is replace all "non-defender" color pushbuttons on black pushbuttons for better looking.
quarterback
« Reply #10 on: February 16, 2006, 10:49:49 pm »
What do you think?
To me, those buttons all look very far apart from each other.
-- Chad Tower
francmusic
« Reply #11 on: February 17, 2006, 07:36:34 am »
1) Circle on my image is only mounting hole for pushbutton (1.13 ") so it's not bezel size.
2)
_123
_456
7
From pushbutton centre #1 to #2, #2-#3, #4-#5, #5-#6 distance is : 4,5 cm (1,77").
Between #1-#4, #2-#5, #3-#6  : 4,5 cm too.
Only from centre of #4 to #7 is 5 cm (1,96 ").
For Defender, only Hyperspace placement is not so good. Others are ok.
For others games it's ok.
soulblazer28
« Reply #12 on: February 17, 2006, 10:07:50 pm »
You dont play stargate? No inviso :(
I'm planning to do the same for my cab except my fire/thrust will be on the first row (button 2-3) so the seventh button acts as the inviso. I'll have to try to see how comfortable it will be to play while having buttons 5-6 "in the way". I was going to build a separate panel but I'm not so sure anymore. I dont even wash my lunch dish to serve dinner....
How many times do you really press Hyperspace in defender?  I think I use it maybe 3-4 times during the course of a two hour game, and half the time its instant death anyway. In your setup, I'd probably map the hyperspace to button 3 on the second player. It's easier to get to.
Also, if you have it built already, I'd love to know how well you're going to hit that reverse button in the long run. I was thinking i'd have to cut away into the joystick base to get the button closer. I know there was one guy in the forum that did that before.
francmusic
« Reply #13 on: February 18, 2006, 01:55:00 am »
Mame offer to config keyboard definition for each game separetly and it's great. For stargate invisio will be used of course but without extra description on panel artwork (it's defedner-based panel  ;) )
It's true. Hyperspace is rarely used.
The centre of reverse button is 9 cm (3.5 ") from centre of joystick.
For me it's ok.
It's not easy to install reverse button closer to joystick. Look at inside photo of my panel.
francmusic
« Reply #14 on: March 15, 2006, 03:05:51 pm »
Ok. Here you are more pictures:
What do you think? How to put together wood and plexi? Glue or screws?
Havok
« Reply #15 on: March 16, 2006, 01:12:11 pm »
That looks great!
