Author Topic: Keywiz Eco connection issues  (Read 3235 times)
Raybdbomb
  • Last login:January 06, 2006, 07:31:56 pm
« on: January 06, 2006, 10:49:52 am »
I'm having issues connecting my Keywiz Eco to my computer.  I sent an e-mail to (randyt?) techsupport@groovygamegear.com, but i thought I'd post here also.  Here's what's up:
It says
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Keywiz Eco connection issues
« Reply #1 on: January 06, 2006, 11:03:40 am »
I'm da bomb? WOW I'm flattered. Thanks!
NO MORE!!
eccs19
  • Last login:April 20, 2021, 10:36:08 am
  • Just plugin away!
« Reply #2 on: January 06, 2006, 11:07:54 am »
As stupid as this may sound, but are you sure you don't have it plugged into the mouse PS/2 port?
Working - Mr. Do! - Neo Geo 4 Slot - Bartop Mame
Project(s) - Pacman
finsailor
  • Last login:July 24, 2007, 12:40:54 am
  • decisions, decisions
« Reply #3 on: January 06, 2006, 11:08:32 am »
I had (still have) the same issue.
I gave up and use only the default set and switched to Linux.
Mame works fine, because you can remap the keys in mame.
~~I
        /I\
       / I \                                  _
      /  I  \                           _0/
   _/_ I_ \__                 ____il____
__\_____/_________(
Raybdbomb
« Reply #4 on: January 06, 2006, 12:25:05 pm »
Yes, I'm sure it's plugged into the keyboard PS/2 port.  If it weren't, it shouldn't even show the keys being pressed.
Also, I can't remap the escape key as far as I can tell... if you figure out a way, please let me know and I suppose I can not use the software =\
Bloinkxp
  • Last login:August 30, 2020, 11:20:28 am
« Reply #5 on: January 06, 2006, 12:47:21 pm »
Hi Raybdbomb!
Have you tried the ECO on another machine?  How does it work?  I had to flash the BIOS of my machine to get it to work.  That mobo had a 1 yr old BIOS and it was NIB...
Good Luck!
Nothing witty here...move along.
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: January 06, 2006, 01:06:06 pm »
What OS?  You need different software for pure DOS (I think).
Do you mean to remap it in MAME?  If so - INPUT-USER INTERFACE-UI CANCEL
RandyT
  • Last login:April 16, 2026, 01:13:33 pm
    • GroovyGameGear.com
« Reply #7 on: January 06, 2006, 01:38:53 pm »
Use a util like GhostKey and look for a shorted input or a microswitch with the wires on the wrong terminals.
When in Ghostkey, hit the Shazaaam! button a couple of times to see if something is stuck.
Drop me an email with your results.
Thanks,
RandyT
Raybdbomb
« Reply #8 on: January 06, 2006, 03:02:01 pm »
@Boinkxp: technically speaking I don't remember the model # of the motherboard, and I'd rather not disassemble it at this point.  But if nothing else works, I will do that as a last resort, thanks.
@Tiger-Heli: It's Windows XP.  Also, I'm not sure what you meant by "- INPUT-USER INTERFACE-UI CANCEL"...
@RandyT: Thanks for the response.  I found GhostKey and will try that this evening when I get him and let you know.
Thanks for the help so far.
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: January 06, 2006, 03:08:43 pm »
Raybdbomb
« Reply #10 on: January 06, 2006, 04:18:47 pm »
Well, that makes it so technically speaking I don't HAVE to have the encoder work, I could use all of the defaults as a worst-case.
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: January 07, 2006, 10:20:51 am »
True, and you could program MAME to Esc when one of the Shazaaam'd inputs was pressed (for example, "PgDown" or "=").
Bigger question is are you sure you REALLY need all 32-inputs.
I used them on my KeyWiz-based panel, but mostly because they were there (oh, and 98% of the time I just use the default set and don't reprogram it).
