Author Topic: Best Metal-to-Wood Glue?  (Read 2018 times)
  • Last login:April 18, 2026, 05:46:43 pm
« on: January 04, 2006, 02:47:04 pm »
The bond needs to be very secure.  I am mounting a wood block underneath my metal CP , drilling a hole in the middle and screwing my spinner to it from underneath.  I don't want it to ever come apart... Any recommendations?
Knievel
    • Knievel Kustoms
Re: Best Metal-to-Wood Glue?
« Reply #1 on: January 04, 2006, 03:00:25 pm »
5 minute epoxy works great, clamp the pieces together while it dries if possible.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: January 04, 2006, 03:16:01 pm »
Gorilla glue is amazing. But you MUST use clamps. The glue expands.
NO MORE!!
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
« Reply #3 on: January 04, 2006, 03:25:59 pm »
Dont forget to clean and or sand the metal part being glued.
liquidnails works good.
They treated me like an animal and that's what I became.
JonnyBoy
  • Last login:November 12, 2009, 01:59:00 pm
  • Inka Dinka Do
« Reply #4 on: January 04, 2006, 04:21:27 pm »
I've used this stuff called Multi-Grip before, easy to work with and very strong. In your application, I second the epoxy, it can withstand usually around 2 tons of pressure before seperating.
I had to beat them to death with their own shoes...
Bones
  • [Moderator]
« Reply #5 on: January 04, 2006, 04:51:58 pm »
Loctite 3801 5 minute Adhesive. Suitable for ceramics, concrete, fibreglass, marble, wood & metal. No clamping needed.
Comes in a two part syringe so you can get the right mix. This stuff is awesome, you could use this stuff to glue the end of two turds together if you wanted....
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #6 on: January 04, 2006, 05:34:12 pm »
If you get the mixture right. For most jobs, I just eye it. I've had it come apart a couple times due to a bad mixture. Measure it and it will be incredibly strong.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #7 on: January 04, 2006, 05:43:16 pm »
How about JB Weld, stuff is cheap and is really strong!   I've used it to fix broken drill bits, and fix my weight lifting equipment!   I believe it bonds to mostly anything?
http://jbweld.net/products/uses.php
Someone mentioned on that page,  that they used it to weld a wooden fence post to cement!
Also found this....
What does it bond to?
Virtually any combination of iron, steel, copper, aluminum, brass, bronze, pewter, porcelain, ceramic, marble, glass, PVC & ABS, concrete, fiberglass, wood, fabric, paper -- just about any porous and non-porous material.
« Last Edit: January 04, 2006, 06:05:51 pm by creatine28 »
Ken Layton
  • Guru
  • Technician
« Reply #8 on: January 04, 2006, 06:28:13 pm »
Good old silicone glue.
JonnyBoy
  • Inka Dinka Do
« Reply #9 on: January 04, 2006, 10:14:17 pm »
I was under the impression that JB Weld was a good metal to metal epoxy, looks like I underestimated it. It's been around forever too.
Crazy_Mack
  • Last login:July 24, 2007, 11:20:49 pm
  • Mackinturf! You're Crazy!
« Reply #10 on: January 05, 2006, 08:55:04 pm »
I think site is quite useful when it comes to gluing things together.
http://www.thistothat.com/
