Author Topic: Need Advice  (Read 1558 times)
ojelela
  • Last login:May 16, 2007, 09:59:37 pm
Need Advice
« on: December 29, 2005, 09:43:58 pm »
Hi,this is great forum :angel:
Finally I both older cabinet from local shop without monitor,and after years
of planing its time for MAME.Now cabinet came all wired up with coin door and
JAMA harness +wico track ball, my setup will have two 4-8 way joysticks 6 buttons each player,1&2 player buttons happ tr.ball arcade connector not usb,and two pinball buttons.Finally my question is can i use existing harness or should i start from scratch.What is easier way and cheaper to go,because my boss(wife) its already complaining about spending money.
Thanks in advance and Happy New Year to everyone :D
brophog
  • Last login:January 20, 2019, 03:49:41 am
Re: Need Advice
« Reply #1 on: December 29, 2005, 09:46:10 pm »
That's what they're good at.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
Re: Need Advice
« Reply #2 on: December 29, 2005, 10:14:40 pm »
You can use the Jamma harness already installed.
ojelela
Re: Need Advice
« Reply #3 on: December 29, 2005, 10:34:28 pm »
OK,so i can use J-Pac for all 16 PB and two joystics??That means I have to add more wires to harness since original CP had only 3 PB and trackball.Is there than other way to go than J-Pac and orig. harness because i cant use it for my happ TB
GGKoul
  • Cheesecake Apprentice
Re: Need Advice
« Reply #4 on: December 29, 2005, 10:36:57 pm »
You need 2 boards.. J-Pac for the joystick and buttons and the Opti-pac for the trackball.  Goto www.ultimarc.com for more information how those boards work.
ojelela
Re: Need Advice
« Reply #5 on: December 29, 2005, 11:20:32 pm »
Since I know something about wiring(I'm electrician), I will go with I-Pac and Opti-Pac. Just not sure Ultimarc have two versions:
1. http://www.ultimarc.com/ipacve.html
brophog
Re: Need Advice
« Reply #6 on: December 29, 2005, 11:28:52 pm »
2. http://www.ultimarc.com/ipac1.html and no prices that i can find.
That's because he took his shopping cart down. You're not ordering until Jan 9 when he returns from vacation. The 'regular' IPAC is 39.95 + 13 shipping (assuming you're in the U.S.)
markrvp
  • NFL Expert
Re: Need Advice
« Reply #7 on: December 29, 2005, 11:35:02 pm »
ojelela
Re: Need Advice
« Reply #8 on: December 29, 2005, 11:56:29 pm »
Tnx ,don't get me wrong i don't mind reading and searching just after few hours,days and weeks everything is getting blurry and makes less sense then before.That why I really appreciate yours help. So all I need then is MINIPAC and I guess if I build my own IDE cable I can find that on the Board??
markrvp
  • NFL Expert
Re: Need Advice
« Reply #9 on: December 30, 2005, 12:04:21 am »
Wiring Diagram:
http://www.ultimarc.com/mp_inst.html
The IDE cable is the same as the cable you connect your hard drive to your motherboard.
ojelela
Re: Need Advice
« Reply #10 on: December 30, 2005, 12:54:14 am »
Ok, here we go,I will post same pics on progress, and hopefully wont bug you too much in the future.
