Author Topic: Buttons,buttons and buttons  (Read 5583 times)
whatzcrackn
  • Last login:January 19, 2019, 12:14:02 pm
  • U just won tickets to da 'GUN SHOW'
« on: December 24, 2005, 10:08:57 am »
Has anyone bought the following buttons:
Happs Translucent (The Type that are being sold in this forum)
Dream Arcades (Frosted top)
« Last Edit: December 29, 2005, 11:40:54 am by whatzcrackn »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Buttons,buttons and buttons
« Reply #1 on: December 24, 2005, 10:35:58 am »
NONE of those come with an LED. You have to install lights yourself.
NO MORE!!
whatzcrackn
« Reply #2 on: December 24, 2005, 01:01:01 pm »
Yes I know, but whick type of button is better.
« Last Edit: December 29, 2005, 11:39:17 am by whatzcrackn »
Roughy
  • Last login:July 01, 2009, 09:33:20 pm
  • Easily impressed.
    • UserGlue
« Reply #3 on: December 24, 2005, 01:41:03 pm »
It's all preference.  If you can get the opportunity to try one of each, you should.
I like the Happs, and have heard that others do, because of the "click" noise/response.  I've never tried the leafs, but I'm pleased with what I've got.
Drilling the holes for the LEDs was pretty simple and more an issue of my own aim since I was doing it by hand, but Happs is kind enough to provide a nice little circle in the bottom for you to aim at.
whatzcrackn
« Reply #4 on: December 24, 2005, 02:45:53 pm »
thx!!! ::)
« Last Edit: December 29, 2005, 11:38:05 am by whatzcrackn »
whatzcrackn
« Reply #5 on: December 24, 2005, 02:46:41 pm »
as u can see my spelling needs to be checked :police:
Roughy
  • Easily impressed.
    • UserGlue
« Reply #6 on: December 24, 2005, 05:37:49 pm »
Do a search; I don't have the thread handy since I'm on the road, but I believe Knievel has a thread showing it on the Happ...
whatzcrackn
« Reply #7 on: December 24, 2005, 05:42:27 pm »
yeah, i think that is the one which just shows the holes............thx!
i also need the wiring and which set of buttons is the KOOLEST!! 8)
Roughy
  • Easily impressed.
    • UserGlue
« Reply #8 on: December 24, 2005, 06:35:32 pm »
so much more about preference.
Personally, I really, truly wanted metallic buttons.  Dead serious.
However, I'm more into the "total design" of my cabinet, and the translucents go with that total design more.  If/when I do a mini/bartop cab, I'm going to really consider the metallics.
Spaz Monkey
  • Last login:February 15, 2011, 11:33:55 pm
  • Hit me with a chicken quesadilla and a Coke.
« Reply #9 on: December 26, 2005, 07:57:53 pm »
Leaf switches are a matter of feel.  They don't click because they don't have the micro-switches, but they "bounce back" more, if that makes sense... You will have to re-adjust the leaf switches since they actually make connections.
I know I'm not making any sense here...  Think of digital joystick vs. analog for the microswitch vs leaf spring ....    bleh...  so maybe I can't describe the differences as well as I thought I could... :P
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #10 on: December 26, 2005, 11:17:03 pm »
The DreamArcades ones come with a light.
Leaf buttons (FXbuttons)  I know the hole sizes have to be bigger.
FXbuttons does not sell leaf buttons, they sell (and were the first to sell) the translucent microswitch buttons.
Translucent leaf buttons can be had from www.centsibleamusements.com or, if you're really brave and don't mind your order being late and screwed up, www.wicothesource.com.  Wico is NOT reccomended, but others have managed to get buttons from them.
« Last Edit: December 28, 2005, 11:54:59 pm by Kremmit »
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
« Reply #11 on: December 26, 2005, 11:31:39 pm »
Just be sure that you don't get the plain Translucent Buttons from centsible, as they are convex. I'm not sure about the leafs (convex or concave).
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
DreamArcades
  • Last login:April 26, 2022, 05:36:40 pm
    • Dream Arcades, LLC
« Reply #12 on: December 27, 2005, 03:39:17 am »
The Dream Arcades buttons come with the LED. They are built-in, so you do not have to figure out how to modify the button to add them. They even have the Resistor included so you don't have to worry about blowing them out if you get the polarity wrong.
RandyT
  • Last login:April 16, 2026, 01:13:33 pm
    • GroovyGameGear.com
« Reply #13 on: December 27, 2005, 07:52:13 pm »
You won't "blow out an LED if you get the polarity wrong".  LEDs are diodes, light emitting ones per the abbreviation.  If you hook a diode up backwards, it simply does not conduct.  Or in the case of the LED, illuminate.
The inclusion of the resistor is only beneficial if you are using the voltage the resistor was intended for.  If you want to drive it with 5v and it's designed for use with 12v, the resistor causes a problem unless you can swap it out easily.
There are calculators all over the Internet for figuring out the proper resistors to use with LEDs.  If one takes a minute to look them up, they are dead simple to use.
RandyT
whatzcrackn
« Reply #14 on: December 28, 2005, 01:43:01 am »
« Last Edit: December 28, 2005, 01:44:46 am by whatzcrackn »
whatzcrackn
« Reply #15 on: December 28, 2005, 01:47:47 am »
« Last Edit: December 28, 2005, 06:24:15 pm by whatzcrackn »
whatzcrackn
« Reply #16 on: December 28, 2005, 06:25:37 pm »
So...........are DA buttons kool 8)
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #17 on: December 28, 2005, 06:51:30 pm »
You mean the one's sold by ponyboy?
http://forum.arcadecontrols.com/index.php?topic=36770.0
Dream Arcades (Frosted top)  Does that really matter....They claim the led does not show??  BAsed on the pics I have seen, I dont see the led in either of them.
I don't have experience with these.
fx sells micros, not leafs, and are compatible with happs.
You can go leaf if you like too.
whatzcrackn
« Reply #18 on: December 28, 2005, 08:05:27 pm »
dreamarcade buttons
are they kooler 8)
8)
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #19 on: December 28, 2005, 09:35:34 pm »
yes they are.  You should buy all of them from there.  When you get them in your hand, will you make sure to tell us we were right if you like them, and wrong if you hate them?  Why aren't you grasping what Roughy is saying?  If YOU like them, does it mean they're not "right", since you "want to do this right"?
Stop asking the same damn thing over and over and over and over and over and over and over again.  It's also annoying since "cool" and "doing this right" don't necessarily go hand in hand even though you seem to think so.  You aren't even picking up on your own desire to make things look cool even though they might not look right.  Read your own words.  "I'm clueless but need lights connected to my buttons".  No you don't.  You WANT lights.  You don't "NEED" lights, so stop asking 50 brazilian times.
GO PICK UP SOME OF THE TWO DOLLAR BUTTONS AND TELL US IF THEY'RE COOL.
Are you pickin' up what I'm puttin' down?  Do ya see "whatzcrackn"?
SirPoonga
  • Puck'em Up
« Reply #20 on: December 28, 2005, 09:47:28 pm »
hmm, well, fx buttons are not compatible with happs :(  I wanted to put a sold center into a button.  Doesn't fit.
Hole size is still standard 1 1/8"
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #21 on: December 28, 2005, 09:56:06 pm »
Drew:
What buttons do you think are the most Kewl?
DrewKaree
  • HAH! Nice one!
« Reply #22 on: December 28, 2005, 09:59:18 pm »
Drew:
yU0r m0mZ!  ;D
Roughy
  • Easily impressed.
    • UserGlue
« Reply #23 on: December 29, 2005, 02:18:20 am »
whatzcrackn
« Reply #24 on: December 29, 2005, 09:30:23 am »
« Last Edit: December 29, 2005, 11:13:37 am by whatzcrackn »
DrewKaree
  • HAH! Nice one!
« Reply #25 on: December 29, 2005, 10:36:26 am »
What is the difference and is one better (bulbs vs led)?
dreamarcade buttons
are they kooler 8)
Yeah, I guess you're right, wherever would I have gotten that impression? ::)  You aren't asking about bulbs vs LED's, you continue to ask "whutz kewler doodz?"  pssst.  Your quotes betray the fact I'm right and show you to be attempting CYA maneuvers.  Spend the 2 bucks, since clearly they'll work and R teh kewl.  You'll never know if you like them better than the other style until you hold them in your hand and compare them side by side, but what do I know, going and following my own advice ::)
p.s. UR jedi master talk roolz!!11one!11!!eleventy!!1
whatzcrackn
« Reply #26 on: December 29, 2005, 11:11:18 am »
i guess you r right. i never thought of just buying one of each first....  thought i would just get the opinions first...
it has been asked because no one answered it.  but u r right stop asking and just do it!!
THX
The darkside clouds everything....impossible to see, it is.............
Roughy
  • Easily impressed.
    • UserGlue
« Reply #27 on: December 29, 2005, 11:15:20 am »
While you're at it--and this isn't meant to come across as harsh--could you exercise a little etiquette and stop the AOL-speak?
Unless you're visiting this via a mobile phone with standard 12-key entry, please try and utilize such things as grammar and punctuation to help us all out.
As it is now, it is very difficult to read your posts and feel like a response will be either understood or even that the right question is being answered.
Above all else, these are great people.  Try not to piss them off much--it's tough enough to do, but I think you've somehow managed to find the yellow brick road to doing exactly that.
whatzcrackn
« Reply #28 on: December 29, 2005, 11:23:12 am »
QUE ???
I have not been rude at all.
I have serious needs and those were real questions and answers. :angel:
WOW :-\ :-\ :-\ :-\ :-\ :-\
P.S.
Not to sound harsh or rude..............
« Last Edit: December 29, 2005, 11:32:45 am by whatzcrackn »
markrvp
  • NFL Expert
« Reply #29 on: December 29, 2005, 11:27:54 am »
This is a site made up primarily of adults, although there are many high school age persons as well.  We prefer to post in correct English.  Basically, try and compose each post as if you were answering a question in English class.  Smilies should be used sparingly and text-message abbreviations should be avoided.  Complete thoughts, if not sentences are a must in order to help.
And help you we will young Padawan - because we like cool buttons, too.
whatzcrackn
« Reply #30 on: December 29, 2005, 11:31:04 am »
Understood MASTER!  but the extras are so kool (i am sorry cool). just joking I will get it together.
whatzcrackn
« Reply #31 on: December 29, 2005, 11:35:44 am »
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #32 on: December 29, 2005, 01:05:25 pm »
I'm one of the few exceptions to complete thoughts though right???
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #33 on: December 29, 2005, 01:15:07 pm »
My guess is you are 15... how close am I?  ::)
first off your and idiot
whatzcrackn
« Reply #34 on: December 29, 2005, 01:31:19 pm »
« Last Edit: December 29, 2005, 01:35:57 pm by whatzcrackn »
