Author Topic: How do they do it.Golden tee and Silver strike?  (Read 14812 times)
fairway2000
  • Last login:April 21, 2012, 06:53:54 pm
  • Loooking for games in Detroit
« on: December 13, 2005, 06:16:58 pm »
I saw a Golden tee with GT complet and silver strike in it.How do they do it?
Has any one seen this?Any instructions?I have seen the jamma one but not this.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Re: How do they do it.Golden tee and Silver strike?
« Reply #1 on: December 14, 2005, 01:40:49 am »
I am interested in knowing this as well.
ArcaMan
  • Last login:July 29, 2008, 05:15:10 pm
    • Man Tripping
« Reply #2 on: December 14, 2005, 12:02:59 pm »
They both use the same trackballs in the same place, so my guess is that there is a switch somewhere that just switches between the two kits.  The inside of a GT and a SS cab are mostly open space, so there is plenty of room to mount two motherboards (both are PC-based, running Linux), the motherboards may be the same as well - I know that GT and Buck Hunter share the same boards - just update the software. - if that's the case then maybe someone has hacked it and made a loader to select which drive image?
I would lean more towards two kits in the same cabinet though with a manual switch.
That would be a blast to have in my gameroom though :)
Man Tripping: Guy's Getaways and Mancation Ideas!
http://www.mantripping.com
fairway2000
« Reply #3 on: December 14, 2005, 03:58:02 pm »
Sounds good.But.I think if you tried doing a hard drive switch the board would
not see the security key.I'm just thinking.There is some kind off security key I think.But not sure.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: December 14, 2005, 05:28:37 pm »
I am confident that they have two boards.  I know the chips are interchangeable, but I believe you would have to have two boards to make them work.
ArcaMan
    • Man Tripping
« Reply #5 on: December 14, 2005, 08:03:55 pm »
I am pretty sure they use HASP hardware keys (I know Live! uses them). If so, you could proably just put two of them in different USB ports.
Most likely though, it is two different boards.  The kits aren't that expensive.   Complete is just a software upgrade for around $500 and you can get the red boards on ebay for 200-600$ depending which year (the software upgrade works on all Fore platform boards), Silver Strike kits are about $1900 I think as well. (Pardon if my numbers are a bit off, but I am pretty sure those are ball park)
A kit ready GT cabinet from TLC (factory that makes the coin-op version) should only run you about $1200-$1400 for a 27" but you could probably make your own for less.
Those of you who haven't played Strike, it is a hell of a game.  I would love to have one in my game room.
Cheers,
Arcaman
fairway2000
« Reply #6 on: December 14, 2005, 09:52:58 pm »
Thanks.But still no way to switch between the games.I found this
http://www.multigame.com/jamma.html
Might help?
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #7 on: December 14, 2005, 11:03:48 pm »
Call Incredible Technologies Technical Support at 1-847-870-7027 x121.
« Last Edit: December 14, 2005, 11:07:37 pm by markrvp »
fairway2000
« Reply #8 on: December 15, 2005, 07:38:14 am »
What does the usb ports do?
ArcaMan
    • Man Tripping
« Reply #9 on: December 15, 2005, 09:13:22 am »
oh, my bad on the HASP key part, I haven't looked at a GT kit in a long time, just Live.  Thanks for clarifying that :)
fairway2000
« Reply #10 on: December 15, 2005, 09:16:56 am »
Called them and the kit is not made by IT.Back to square one
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #11 on: December 15, 2005, 09:52:42 am »
If they are both PC based, could it be possible to add a switch on the hard drive power lines, so that on boot up only one drive is powered (therefore becoming 'C:')
Though my question here really which Fairway was vague on: Were the two games SELECTABLE from a menu on the screen? I think that makes all the difference in figuring out what was done here.
NO MORE!!
fairway2000
« Reply #12 on: December 15, 2005, 10:04:53 am »
Never saw one.Just saw it listed on EBay.Not sure how they did it.The only thing
about switching hard drives is that the board has security and only could run one hard drive.I am pretty sure you need 2 boards and hard drives.
markrvp
  • NFL Expert
« Reply #13 on: December 15, 2005, 10:38:35 am »
I would tend to agree.
fairway2000
« Reply #14 on: December 15, 2005, 03:08:15 pm »
It has nothing to do with doing it he said.But you gave me good idea.
With the jamma switch (http://www.multigame.com/jamma.html).
You have like 17 extra wires on the jamma plug.What if you took the trackball
plug and pluged it into the jamma switch board using the extra connections?That would switch the trackball.With the printer switch wouldn't you be getting sound from both boards at the same time?Or would that be part of the switch?
markrvp
  • NFL Expert
« Reply #15 on: December 15, 2005, 03:54:39 pm »
Yes you are right - there is a speaker + and - from the jamma connector.
I looked at the Multi-Jamma website.
fairway2000
« Reply #16 on: December 15, 2005, 06:55:40 pm »
Now all we need is to get a person with lots of money to try it.Just in case it is a $2300.00 fuse.LOL
z28dan
  • Last login:August 08, 2018, 08:50:01 pm
  • mad scientist with jukes
« Reply #17 on: February 05, 2010, 07:39:33 pm »
Gatorcade sells the switcher, it runs about  $400
You still need to have 2 boards and 2 hard drives.
http://www.gatorcade.com/dualgamessbgt.html
Hoopz
  • Last login:April 14, 2026, 11:47:32 pm
  • Intellivision Rocks!
« Reply #18 on: February 05, 2010, 08:28:08 pm »
Good to know.  I'm sure the OP has been fretting about this for the last 4+ years.   ;)
GMZombie
  • Last login:March 22, 2022, 10:11:23 am
  • I am a living Legend who fixes stuff... mostly
« Reply #19 on: February 05, 2010, 10:08:45 pm »
yea they use a system from happ mostly called the perfect solution. look up on happs website. it will do any resolution u need but there is a catch. it dosent pass through power, so if you wanted to do this you would need to hack a jamma harness to put power on that board...for example im setting up a world class bowling/golden tee 2005 w extra courses game. ive been told though that the resolution change on the system from silver strike and golden tee 2005 is bad on the monitor cause it just uses a push button to change games...both powered up in cab with seperate power supplioes and hard drives and boards.
Brutal E
  • Last login:July 07, 2010, 09:11:23 pm
« Reply #20 on: February 08, 2010, 06:30:23 pm »
Here is my plan. I have my Silver Strike and Golden Tee 2005. I figure wire up both boards to the same buttons and trackballs. Wire them up to the same speakers. Silver Strike does VGA no problem for Golden Tee 2005 I am using a converter to get VGA. Both VGA outputs into a vga switcher. Put two external switches for the power supplies with some kind of sliding cover so when you turn one on the cover is covering the other switch to keep you from accidentally turning it on. I am trouble shooting my 2005 board right now, my Silver Strike kit is ready to go, and I have a Golden Tee Complete board I am sending into repairs.
This is my goal to have both games in the same cabinet. I am going to buy a new cabinet from Arcade Shops. They are close enough I can drive to pick it up and that saves like 500 dollars in shipping.
