Author Topic: POWER SUPPLY question  (Read 2417 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: November 18, 2005, 07:19:31 pm »
I have a empty ROLLING THUNDER cabinet,
That im not planning on doing anything with.
I am thinking about making something simple and cheap,
For my Best Friend's little brother.  (He wants a ARCADE MACHINE bad!)
I thought about hacking a JAKKS  MS. PAC-MAN  and putting it in for him.
(He loves my real PAC-MAN cabinet)  ;)
My question is this?
I want to put an Arcade power supply in it.
Will the 5+V be enough to run the hacked JAKKS stick?
Or will i need more Juice?
And will i need to put some fuses in between the AC cord and the Power Supply?
I want to light the Coin Door with it to.
I know it will not be functional. But it will give the setup a more realistic feel.
That is why i would like to run everything with an Arcade Power Supply.
Thanks for any suggestions?
Bucket ...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: POWER SUPPLY question
« Reply #1 on: November 18, 2005, 07:37:34 pm »
Do Jakks games come with their own power supply?
NO MORE!!
BUCKETHEAD
« Reply #2 on: November 18, 2005, 07:52:00 pm »
Yeah,
Batteries.
Which would be a pain in the @ss!
To have to change out when they die all the time.
I know some People have Hacked some JAKKS games here before.
But im not sure how many Volts they require?
And if they can be run off the 5+V on a Arcade Power supply?
I had in mind something like this?
15 AMP Penn-Ray Powertec
« Last Edit: November 18, 2005, 07:56:43 pm by BUCKETHEAD »
quarterback
« Reply #3 on: November 18, 2005, 07:54:59 pm »
Do a search and I bet you'll find what you need, I know for a fact that the required voltage info has been posted here.
-- Chad Tower
SirPeale
  • Green Mountain Man
« Reply #4 on: November 19, 2005, 08:01:55 am »
Yeah, it'll work fine.  Kind of overkill, though.
You may have a wall wart (wall transformer adaptor) that can work.  Just make sure you measure the voltage before hooking it up.  Even though it may *say* 5V, it may output much more.
BUCKETHEAD
« Reply #5 on: November 19, 2005, 10:55:47 am »
Thanks for the confirmation Peale.
Yeah i know kind of OVERKILL.
But i want to use a ARCADE power Supply to light the Coin Door.
More Realistic touch.   ;)
But this way?  Do i need to put some fuses in between to AC cord and the Power
Supply?
Or can i hook the cord straight up to the Power Supply?
BUCKET ....
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #6 on: November 19, 2005, 11:56:16 am »
The Jakks use 6v so turn up the +5V output on the arcade power supply.  Why not just put a surge protector plug strip in the cabinet and plug the TV and the power supply into that?  The plug strip will have a fuse and you can power both off one cable.
Check out my thread HERE to see how I hacked three Jakks controllers into one cabinet and one set of controls.
I used three different 6v wall warts, but I may buy one switching power supply like you suggested and wire all three of them into it.  The output on that power supply is 15amps which would be way more than enough for three of these babies.
BUCKETHEAD
« Reply #7 on: November 19, 2005, 02:23:58 pm »
Because i want to light up the coin door lights.  (For a realistic touch)
I read your posts. I found them very informative.
I plan on using some of your tips!   ;)
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« Reply #8 on: November 19, 2005, 04:44:51 pm »
Nicest mini-pac ever. It's inspiring me to do a bartop pac with leftover MDF. If my wife will let me.  ;)
-pmc
SirPeale
« Reply #9 on: November 19, 2005, 05:27:57 pm »
Make sure to measure the voltage with a multimeter.  The Jakks unit will run fine with a lower voltage.  Too low and you'll notice graphics errors.
BUCKETHEAD
« Reply #10 on: November 19, 2005, 06:10:45 pm »
Thanks good advise PEALE.
I went and bought a JAKKS Wireless MS. PACMAN today at WAL-MART
They are $18.77 here in GREENVILLE SC.
I must admit i am impressed with it so far!
Except it takes 8 AA batteries OUCH!
markrvp
  • NFL Expert
« Reply #11 on: November 19, 2005, 06:55:58 pm »
BUCKETHEAD
« Reply #12 on: November 19, 2005, 07:28:39 pm »
What I mean is, plug the arcade power supply into the surge protector as opposed to wiring in a fuse, distribution block, etc.  The surge protector already has a line filter and fuse built in.  The added benefit is that you can also plug your TV into the surge protector and wire the surge protector to an on/off switch.
Unless I misunderstand, and you want the coin door lights to always be on.
Ok, got what you mean now!
Good idea!
Thanks!     ;)
