Author Topic: Construction of a four person Control Panel, Starting with Kinkos.............  (Read 3588 times)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
I used the thirty day trial of Adobe Illustrator to make a four person layout.
« Last Edit: December 06, 2005, 08:27:48 am by mccoy178 »
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
Re: Kinkos printed my CP layout for construction
« Reply #1 on: November 07, 2005, 12:35:27 pm »
Cool, very nice!
What are its dimenions?
Also, would you mind PM'ing me the illustrator file you used here?  I'd be most thankful.
--Erich
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« Reply #2 on: November 07, 2005, 09:52:33 pm »
You could have printed it across multiple sheets and taped them together. I found these instructions. NOTE: I haven't tried this myself as I don't have the program.
I use a program called QuarkXpress. This also allows printing across multiple pages. I used this to design the large template for my CP.
Mario
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #3 on: November 07, 2005, 10:13:59 pm »
Since I'm having artwork done somewhere else, I had to be 100% sure they would be identical.  Since it was only a few bucks, it was worth it.
quarterback
« Reply #4 on: November 07, 2005, 10:46:12 pm »
Yeah, I've done the multi-page-tape-together like three times and while it works, it's not always perfect   The lines don't always line up from one piece of paper to the next and it's just generally a PITA.
Looks cool, mccoy178
-- Chad Tower
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #5 on: November 08, 2005, 02:51:55 am »
Reporting in:
This was a great idea because after having this made, I decided that the trackball needed just a smidge more room.
« Last Edit: November 08, 2005, 02:56:19 am by mccoy178 »
Crowley
  • Last login:January 25, 2006, 04:07:23 am
  • Wakka-wakka-wakka-wakka
« Reply #6 on: November 08, 2005, 03:13:49 am »
....Wow. Ya, kinko's rules at these type of things.
"It's Raining Sideways!"
RickDIII
  • Last login:June 03, 2007, 10:18:28 pm
  • Finished 1st Cab!
« Reply #7 on: November 11, 2005, 08:40:01 am »
So, is it considered bad form for a newbie building his first project to come in and ask for a copy of the file you used for the template.
AtomSmasher
    • Atomic-Train
« Reply #8 on: November 11, 2005, 10:54:19 am »
I had kinkos print both that and my overlay, the overlay was perfect but the layout was printed slightly too small which made it useless.  I ended up just printing them out on multiple sheets from my home computer, it worked well enough.  And if your wondering what program I used to print it, microsoft paint, the free one that comes with windows, if you print a large picture from it it automatically prints it on multiple pages.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #9 on: November 11, 2005, 12:09:48 pm »
AtomSmasher,
I was very particular about the sizes.  I want to avoid exactly what you are mentioning.  I just measured at kinko's, and it was perfect.  Now I hope Mame Marquess does the same!  I trust they will, or I wouldn't of done this.
BTW, Anyone is welcome to this.  I designed this with the Golden Tee players of the world in mind.  By the way, if you choose to do this, you should look into the Johnny5 viewer of Howard Casto and using Method 5 mentioned by Tiger Heli's tutorial.
RickDIII
  • Finished 1st Cab!
« Reply #10 on: November 11, 2005, 12:45:25 pm »
« Last Edit: November 11, 2005, 02:20:18 pm by RickDIII »
jopenner
« Reply #11 on: November 12, 2005, 01:07:45 pm »
I did the same thing with mine and cut my CP out and waited for my CP printout from Mame Marquees.
Once the printout arrived, I placed a flourescent light light under the CP so that the light would shine through my cut outs.  I then carefully dry-layed my marquee and then clamped it down into position.  I then cut the backing on the printout at the half way point and very slowly began applying the graphi to my CP.  I slowly peeled the backing in one direction as I applied the graphic.  I used a wallpaper roller to ensure that there was no bubbling at all.
Once the entire graphic was applied, I then took a modelling knife (very sharp and began cutting out my holes.
It looks great and Scott at mame Marquees did an awesome job.
His work is highly recommended.
John
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #12 on: November 12, 2005, 02:25:16 pm »
Thanks for the input.  I like these type of threads to help people in their first attempts!
daywane
  • GRRRR!
« Reply #13 on: November 13, 2005, 07:01:05 am »
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Here is a preview of the artwork.
« Last Edit: December 06, 2005, 10:59:23 pm by mccoy178 »
Havok
  • Trade Count: (+17)
Looks awesome. Although, with the size of the cp and the space around the trackball, I would go with a 4 1/2"...
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Thanks for the compliment.  The reason for the 3" trackball is because of Golden Tee.
« Last Edit: December 06, 2005, 11:01:21 am by mccoy178 »
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
where did you get the speaker grills on the bottom of that control panel stand?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
That's the grills that came with it.  It's an old Dynamo that I routed out to add my own cp.  That stand is a buddies.  The ones that I'm currently working on are all fullsize arcades.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Well, great news and terrible news today.  I have the control panel put together.  I wired up the led wiz completely backwards, so I can't finish the wiring yet.  Here are some early pics of the Boston control panel.
Big thanks and shout out to SNAAAKE and Scott from MameMarquees.  Both did an outstanding job on this.  Thanks fellas!!!
SNAAKE
  • Trade Count: (+29)
hey hey looking good congrats !! :)
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
Had to bring this one back from the dead.  Trying to build mental strength for next project.......
