Author Topic: Control Panel Concept  (Read 2556 times)
Thumperman
  • Last login:March 24, 2006, 02:27:47 pm
« on: November 01, 2005, 09:49:22 am »
I have searched through the forums for anything related to control panels and have seen many great ideas. I have come up with one layout that I would like to gain some opinions on.
I have tried to make this layout to fit the majority of arcade classics and have ease of use when playing the golf variaties available (Tiger Woods, Golden Tee, Links). I also wanted to be able to play Asteroids fairly easily, which is one of my all time favorites.
- SlikStik Tornado Spinner
- Happs Competition Joystick
- Happs 3" High-Ball Trackball
- Ultimarc T-Stik PLus
- Happs buttons
- Ultimarc 28 Input I-Pac
- Ultimarc Opti-PAC Interface
- Happs USB Extension Cables
Any opinions would be appreciated.
Tom
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
Re: Control Panel Concept
« Reply #1 on: November 01, 2005, 10:39:53 am »
Is there a reason you want he Mouse R/L and Track 1-3 buttons?
To make a less of a frankinpanel, I would recommend doubling up either P1 or P2 buttons for those.  That way the panel will look a little cleaner.
The joysticks and the buttons look a little too close.  You might have some room issues trying to hook up the microswitches underneath the joy and button 7.
What keyboard encoder are you using?  If it has some sort of 'shift' function capability, you might want to also hide some of the admin keys.  Some people like fix admin and some don't,  its just a option.
Teamwork - A group of people running around doing what I say.
Hoopz
  • Last login:April 14, 2026, 11:47:32 pm
  • Intellivision Rocks!
« Reply #2 on: November 01, 2005, 10:46:29 am »
How about using the Mini-Pac instead of the Opti-pac?  It supports a trackball and spinner.  And if you went that route, you could eliminate the I-Pac also.  The Mini has support for 28 switches.  Have you considered going that route to save a little money?
http://www.ultimarc.com/minipac.html
Thumperman
« Reply #3 on: November 01, 2005, 02:20:00 pm »
HoopZ,
Thanks for the suggestion, I think I will go with the MiniPAC. I do not see any reason to stay away from this Idea. Wiring is not problem.
MameJunkie,
Are you saying that you can share both the trackball buttons and the mouse buttons with Player 1 and/or Player 2? I like the idea of sharing the trackball buttons with player one and I am currently researching that idea..
Thanks,
Tom
MameJunkie
  • Eeeeeeeevil
« Reply #4 on: November 01, 2005, 02:51:16 pm »
Yea, you can use P1 and/or P2 buttons as the trackball/mouse buttons.
Also, if you are going to get the Mini-PAC, you need to get the USB cable if you want to support tractball/spinners.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #5 on: November 01, 2005, 02:54:21 pm »
I've got my player 1 and 2 buttons wired to both the I-PAC and the Opti. Works like a charm.
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
MameJunkie
  • Eeeeeeeevil
« Reply #6 on: November 01, 2005, 03:05:50 pm »
I'm on the ledge on the Admin buttons.  I can see usages for having dedicated buttons.  I was going to have them myself but the cab I just finisned, I only use the default Mini-PAC shift functions plus I configured "shift + button 3" as reset.  It kept my CP cleaner.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #7 on: November 01, 2005, 03:41:33 pm »
I assume you have the T-stick for your 4-way joystick and the 2 competitions are your P1 & P2 8 ways?
I would ditch the T-stick and go with a Happ 4-way MsPacman/Galaga reunion stick.  This is a better 4-way solution and is closer in feel to the other joysticks on your panel.  The T-stick throw is too completely different from the Competitions.  I speak from experience because I originally did exactly what you are doing and replaced my T-stick plus with a 4-way reunion stick.
SlikStik Tornado already comes with a Ps2/USB combo cable, so it plugs straight into your motherboard, not the Minipac.  My preference would be to get the PS2/USB trackball and use the regular Ipac.  This would elminate the Optipac and give you screw terminals on your keyboard encoder.  You also don't have to worry about a harness to connect the minipac to the trackball.  It costs a little more, but gives you the most flexibility.
I have all the parts mentioned above (Ipac, minipac, PS2/USB trackball, Tornado Spinner), so these opinions are based actual use.
I also agree that I would ditch the 5 buttons dedicated to mouse/trackball.
MameJunkie
  • Eeeeeeeevil
« Reply #8 on: November 01, 2005, 04:01:30 pm »
Right on the money...
Thumperman
« Reply #9 on: November 01, 2005, 07:31:22 pm »
markrvp,
Thank you for your comments. I was wondering about the Tornado Spinner with its own interface. I was also not sure what was a good 4way joystick and I like that idea.
Here is my lateset solution from all of the advise I have recieved:
2- Happs Competition Joysticks (8-way)
1- Happs 4-way MsPacman/Galaga reunion stick (4 way)
1- Happs 3
markrvp
  • NFL Expert
« Reply #10 on: November 01, 2005, 07:50:27 pm »
1- Happs 3
MameJunkie
  • Eeeeeeeevil
« Reply #11 on: November 01, 2005, 07:51:21 pm »
Just noticed something in the pic.  Is that a power button in the front?  If so, you might want something to cover it up or move it.  You wouldn't want to accidently press it while playing games.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
« Reply #12 on: November 01, 2005, 07:52:07 pm »
I really like your USB sockets on the front of the CP box... That's a good idea if you want to plug in USB Joypads at any time.
Anything else is down to personal preference. But IMHO One thing I would do is make the panel a little narrower... That's a thumping wide panel for just a two player unit.
« Last Edit: November 01, 2005, 07:58:06 pm by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
IG-88
« Reply #13 on: November 03, 2005, 05:21:25 pm »
Hey Thumperman what did you use to draw your CP? Visio I hope?
-HarumaN
Doc Thirst
  • Last login:November 18, 2013, 09:55:28 pm
« Reply #14 on: November 03, 2005, 07:03:18 pm »
Pardon the dumb question, but I have seen this in a few designs now.  What games use the 7th button (the lower one near your j-stick) on your button group?
Barkuti
  • Last login:July 07, 2006, 03:50:12 pm
« Reply #15 on: November 03, 2005, 08:42:23 pm »
Yep, that's something I've also wondered sometimes. Why 7 (or more) buttons?
I know there are games that use more than 6 buttons, but honestly speaking, any worthwhile title within such a reduced group that makes having 7+ buttons a necessity? ???
Cheers
JamIt
  • Last login:June 17, 2011, 03:27:07 pm
« Reply #16 on: November 03, 2005, 09:44:46 pm »
Re the "7th" button.
Many people like it oriented that way to simulate the Neo Geo control panel.  Many Neo Geo titles have 4 buttons.
--JamIt
markrvp
  • NFL Expert
« Reply #17 on: November 03, 2005, 10:05:13 pm »
Here is an illustration of how the 7 button layout is commonly used.
Doc Thirst
« Reply #18 on: November 04, 2005, 11:27:15 am »
AH!!!
I knew it looked familiar, I just couldn't place it.  Thanks for the low-down, sorry for the hyjack.
