Main > Main Forum
Betson Imperial Trackball
<< < (2/2)
Fozzy The Bear:
OK Thanks guys!!  I'll have to wait and see what comes in the post....
I am going to be using some sort of mounting plate.....  But maybe not a conventional one. It may be that instead of mounting the trackball to the top panel, I'm going to bolt it to the bottom panel of the control case.
I know that doesn't immediately seem to make sense. But I'm in the realm of experimentation here. I have an idea for an unusual setup that may work quite well.
I'll post the details and photographs if it works out.
Best Regards,
Julian (Fozzy The Bear)
Timstuff:
I made a template as a vector file in Adobe Illustrator for the Betson Imperial trackball. If you've got illustrator I could send it to you. Otherwise, I might be able to see about making it as a raster file.
Fozzy The Bear:
--- Quote from: Timstuff on October 30, 2005, 06:41:45 pm ---I made a template as a vector file in Adobe Illustrator for the Betson Imperial trackball. If you've got illustrator I could send it to you.
Hey!! Thanks Tim... That'd be great. I can read illustrator files. I'll PM you an email addy.  :D
Thanks for your help with this.
Best Regards,
ErikRuud:
With a little advance planning, you don't need any monuting plate at all.
I can measure mine for you when I get home after work.
ArcadEd:
I have one sitting on my shelf I can measure for you if you haven't gotten in the info yet.
Navigation
[0] Message Index
[*] Previous page
Go to full version
