Author Topic: cocktail safety  (Read 3771 times)
mo1e
  • Last login:May 28, 2013, 10:07:02 am
  • Do the happy dance
cocktail safety
« on: October 04, 2005, 04:22:26 pm »
hi all i was wondering while i was at work today but would a standard tv be ok to be used in the cocktail position?
mo1e
Re: cocktail safety
« Reply #1 on: October 04, 2005, 05:17:12 pm »
anyone know?
mo1e
Re: cocktail safety
« Reply #2 on: October 04, 2005, 05:29:19 pm »
yer well if it has to be decased i think im ok just building a normal cab as i will prolly blow myself up :P
crashwg
Re: cocktail safety
« Reply #3 on: October 04, 2005, 08:33:20 pm »
OMFG people!  Why is everyone so afraid of decasing a monitor?  It's pretty darn easy, the dangerous part is easy to avoid and even if you do happen to get zapped by it, it doesn't hurt that bad...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: cocktail safety
« Reply #4 on: October 04, 2005, 08:58:51 pm »
I've often used a standard tv in the cocktail position.  How I usually do it is place it in front of the chair I'm sitting in, about several feet away.  I've been known to switch the cocktail position from right hand to the left, but that's only after I've had a few.  No need to go gettin' all crazy from the git-go.
As for safety, always rest your glass on a level and sturdy surface, and only mix as much as you're going to drink.  No sense in letting a perfectly good cocktail go to waste because you passed out and can't finish it.
(seriously....SOMEONE had to do it.  Might as well be me!)
mahuti
Re: cocktail safety
« Reply #5 on: October 04, 2005, 08:59:32 pm »
I've decased so many monitors. The case isn't really the problem.... take the case off, you're fine. Start unplugging wires... then you could have a problem.
There can be some serious problems... but decasing shouldn't be one of them.
I have a TV in my cab.. no problems. Make sure you get one with an automatic on after power failure option. It'll make your life a lot easier.
mo1e
Re: cocktail safety
« Reply #6 on: October 05, 2005, 01:09:46 am »
well this is my frst cab so i think i mite go for th e easy option lol but im still deciding as the cocktail is smaller and i dont think i will have alot of room
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
Re: cocktail safety
« Reply #7 on: October 05, 2005, 01:15:18 am »
I'd be more concerned about color purity issues.  TVs and cheap monitors don't like being on their side or backs.  Tilting this cheapy 19" monitor on my desk back about 45 degrees makes the colors go all wiggity wack.  A manual degaussing tool should maybe help this?
mo1e
Re: cocktail safety
« Reply #8 on: October 05, 2005, 01:24:41 am »
yer the colours was an issue also i mite try a ccktail for my second cab if i get this oe done :)
Lilwolf
Re: cocktail safety
« Reply #9 on: October 05, 2005, 07:23:56 am »
I'm assuming your joking right?  Since it can kill you I think everyone should take note.
Its IS dangerous.  And it IS EASY to get around.  Just read up before you do it.
Last...
If your building an cocktail cabinet, you don't want more then a 19" monitor in it.  And you can get a GREAT 19" arcade CRT for 200 shipped anywhere in the US.  So for the price of an ArcadeVGA (or using dos and many/most video cards + some time configuring it) you can have the ultimate solution.... that you don't have to decase... because it comes in the buff.
OMFG people!
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Re: cocktail safety
« Reply #10 on: October 05, 2005, 09:36:36 am »
An important note:  Cocktail tables take up MORE room than standard arcade machines.
first off your and idiot
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
Re: cocktail safety
« Reply #11 on: October 05, 2005, 10:27:36 am »
An important note:
Flinkly
Re: cocktail safety
« Reply #12 on: October 05, 2005, 01:09:59 pm »
so 19 inchs is the max due to the curvature of the screen and the sitting position relative to the screen, right?  if you happened to get a flat screen monitor/tv, you could go larger within reason, right?  i just wanted to add a couple of cents to this worthwhile discussion.
whammoed
    • NiceMite
Re: cocktail safety
« Reply #13 on: October 05, 2005, 01:18:36 pm »
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
Re: cocktail safety
« Reply #14 on: October 06, 2005, 07:13:16 am »
D5A1AC
Re: cocktail safety
« Reply #15 on: October 06, 2005, 07:51:38 am »
I would suggest that whatever you do with your TV, before you mount it leave it runnning for a few hours out in open space in cocktail position (probably best to do that while it's still cased  ;) and see how it goes. When I was testing out my monitor I left it for about 5 hours - it got a little warmer than usual but nothing worth worrying about. Not sure about a TV though.
