Author Topic: ACT_Labs PC USB, 2 Player Help!  (Read 3045 times)
bmame
  • Last login:September 29, 2005, 11:40:24 am
« on: September 26, 2005, 07:52:09 am »
I have tried everything I could find to get true two player to work with my new ACT-Labs USB guns (PC version, not TV).
I tried Analog Mame+, CPN Mouse Driver, Advanced Mame.  No go.
Searching around the web yielded vague recommendations.
Does anyone have two USB PC guns working in true-two player mode and how is this done?
By true two player, I mean the second player firing independently of player one (not sharing the same cursor).
Barry
Lilwolf
Re: ACT_Labs PC USB, 2 Player Help!
« Reply #1 on: September 26, 2005, 08:25:27 am »
1st, don't grab the latest analog+ mame.  It doesn't have the dual mouse code in it.  Read and you will see the one where he says that it doesn't have the 'core' changes yet.  These changes are the ones that allow for multiple mice.
2nd.  Get it working with dual usb mice first.  Just to make sure it has nothing to do with the actual gun.
3rd.  Calibrate to your screen resolution, and force mame to NOT change resolution or bits per pixel.  And use hwstretching or d3d.  Then the calibration of the gun is the same in game.  This is really useful for at least the games in analog+ mame you want to run.
Then by this point, you should be able to do whatever you want.  But remember you do have to recalibrate between each screen resolution or bpp change.  So you may want to force these for all gun games.  Really does help.
Smog
  • Last login:April 30, 2007, 06:50:51 am
  • .357
    • How to make a cheap GunCon2 work on your PC
« Reply #2 on: September 26, 2005, 04:38:38 pm »
Advance is the way.
I looked in the code some weeks ag
« Last Edit: September 26, 2005, 04:41:38 pm by Smog »
GunCon2PC Driver on http://guncon2pc.no-ip.org/
bmame
« Reply #3 on: September 28, 2005, 08:35:12 am »
I downloaded Analog Mame 0.83.
Used: -multiplemice -lightgun  as the switches (I saw this listed on the Analog Mame Site FAQ).
It almost worked!  Gun one can independently target and fire; Gun 2 can independently target, but the fire function doesn't work!
Any thoughts?  I've tried various combination of the gun switches (lightgun1a, dual, etc..), but nothing came as close to working as the -multiplemice option.
Lilwolf
« Reply #4 on: September 28, 2005, 08:46:59 am »
did you get it working with two usb mice?
make sure you don't pause the game when your setting the buttons.
I can't think of anything else... and I don't have it setup so I can't post working ini file.
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #5 on: September 28, 2005, 10:50:03 pm »
Have you gone into the settings and reconfigured button 1 (or whatever the fire button is called in Mame) to be the trigger for the second gun?
bmame
« Reply #6 on: September 29, 2005, 07:27:09 am »
I have never fiddled with the mame settings, but this is a very good suggestion!
Granted this is AnalogMame, but I should be able to sort through this since it uses the core mame code.
If I get this to work, I will post the exact configuration since I see many, many people having problems with this two gun thing.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #7 on: September 29, 2005, 07:31:51 am »
Look at your .ana files
I couldn't get anything to work till I edited these.
(Can't remember exactly what I did edit in them, it's been months since I setup my dual guns.)
Later,
dabone
bmame
« Reply #8 on: September 29, 2005, 09:44:17 am »
dabone,
What version of Analog Mame are you using?
Any chance you could send me a copy of your .ana file?
dabone
  • Time to work...
« Reply #9 on: September 29, 2005, 11:19:36 am »
I'm using .83, and I'll try to get into my arcade tonight.
(Busy lately, 2 kids, scouts etc...)
Later,
dabone
bmame
« Reply #10 on: September 29, 2005, 11:29:18 am »
Totally understand!  Have 3 kids myself and now the feeling!
I am using Analog MAME 0.83 myself.
Really want to play Terminator 2 with two guns.
dabone
  • Time to work...
« Reply #11 on: October 03, 2005, 09:10:52 pm »
This is a copy of my .ana file for area51
You have to tell analog mame which mouse is what player.
MAMEANA1
P1X M3A0
P1Y M3A1
P2X M2A0
P2Y M2A1
P3X M3A0
P3Y M3A1
P4X M4A0
P4Y M4A1
P5X M5A0
P5Y M5A1
P6X M6A0
P6Y M6A1
P7X M7A0
P7Y M7A1
P8X M0A0
P8Y M0A1
Later,
dabone
Orders at ACT LABS
  • Last login:November 10, 2006, 06:24:27 pm
« Reply #12 on: December 16, 2005, 10:49:22 pm »
:) :D
Happy Day !
My boss told me post the good news here. We got the following message from TroubleShooter Support .
I've had a look at the new CRT guns.
Orders at ACT LABS
« Reply #13 on: December 24, 2005, 12:16:20 am »
Pre-order MAME32 two player PC Guns at :
http://www.act-labs.com/products/gun1.htm
Delivery around mid January
Orders@act-labs.com
comichacker
  • Last login:January 10, 2006, 02:30:29 pm
« Reply #14 on: December 29, 2005, 10:25:48 pm »
I am having trouble also and if anyone can help I would really appreciate it.  I have mame 102, two act-labs pc usb guns, and I cannot get both guns to work properly.  They both track correctly (they hit where I shoot on screen) and I configured the games in mame (I did not pause the game while configuring buttons).
My problem is that both gun 1 and gun 2 register the trigger as MOUSE1 BUTTON0.  I cannot get mame to recognize gun 2's trigger as mouse button 3.
Did anyone have this problem and solve it?
jerryjanis
  • Skate or Die!!!
    • Jake's Joystick
« Reply #15 on: December 30, 2005, 09:08:45 am »
I am assuming that your are using Windows XP.  If you are using regular Mame, then you won't be able to use multiple pc lightguns.  (You could with the TV version because it has a special switch for player on or player 2).  You need to use a version of Mame that will support multiple lightguns in Windows XP:
The latest version of Advance Mame
MameAnalog+ ver 0.83 (that's the latest version of Mame Analog+ that supports it)
Orders at ACT LABS
« Reply #16 on: January 14, 2006, 11:33:47 pm »
the new 2 player PC version is same as TV 2 player version and it can work in MAME32.
Orders @ ACT LABS
Circo
  • Last login:May 11, 2020, 03:27:51 am
  • Still using screenshots? Try EmuMovies instead.
    • EmuMovies
« Reply #17 on: January 15, 2006, 12:26:59 am »
Question, with an arcade monitor would I get TV guns or PC guns?  I am ordering the new Billabs monitor.
My Websites
Orders at ACT LABS
« Reply #18 on: January 30, 2006, 01:35:59 am »
that depends on the type of connector between your VGA card and the monitor, if that is regular PC video connector, then it is PC gun, if that is s-video, then it is TV gun
Orders @ ACT LABS
