Author Topic: OPINION: Best 4/8 way stick?  (Read 5214 times)
« on: September 23, 2005, 12:41:05 pm »
A friend of mine has asked me to help him make some controls.  I would like to hook him up with a pair of 4/8 way sticks, switchable without opening the panel.
What is the best stick for this?
stratjakt
  • Last login:October 16, 2006, 11:43:58 am
Re: OPINION: Best 4/8 way stick?
« Reply #1 on: September 23, 2005, 12:47:40 pm »
Those Suzo inductive sticks where you switch 4/8 way by adjusting a pot sound really intriguing.  You could either find two resistance values you like, and wire them to a switch, or maybe just remount the pot itself on the panel..
Has anyone actually bought one of these sticks and played with them to see if any of this is possible?
tommy
« Reply #2 on: September 23, 2005, 12:50:12 pm »
Read the faq, noob.  ;D
« Reply #3 on: September 23, 2005, 12:56:28 pm »
I did... didn't see this, or just didn't find it.
Besides, I'm asking for opinions, not a rundown of features.  I know what features I need.  I'm not going to find the opinions of people I trust in the FAQ.
Stingray
« Reply #4 on: September 23, 2005, 01:47:34 pm »
I've got an Omnistick Prodigy that I've been very happy with. Works great in both modes, switching takes all of about a second. It does have a very short throw, which some people don't like, I like it quite a lot myself.
-S
TOK
  • The Game Always Wins
« Reply #5 on: September 23, 2005, 02:06:34 pm »
I got T-Stick +'s which were great for ease of switching, but I wasn't crazy about the short stiff throws, and neither was anyone that tried them. I ended up taking them out and installing Happ's Competitions. I preferred learning to play 4 way games in 8 way mode with them to using the T-Sticks.
The newbies that tried playing stuff with the T-Sticks hated them. Gamers adapted quickly, but still didn't like the feel.
Not sure if that info will be helpful or not, but there it is.  :)
Edit to add... If I was to do it again, I would just add a single dedicated 4 way and wire it to stick 1. Don't think there are enough games that use multiple 4 ways to worry about more than that. Since you're doing a new build from scratch and sticks are cheap, that's the route I'd go.
« Last Edit: September 23, 2005, 02:10:28 pm by TOK »
« Reply #6 on: September 23, 2005, 02:32:32 pm »
Not a bad idea... I'm trying to do it without altering the steel CP much, but maybe drilling one hole is doable.
TOK
« Reply #7 on: September 23, 2005, 02:44:52 pm »
My buddy added an extra stick to a steel panel and we used one of these to make a perfect hole. You drill a small pilot hole, put one side of this on each side of the panel and tighten it down. It cuts a perfectly circular hole. The one we had used a standard 9/16" socket not an allen key, but this gives you a pic to get the idea.
It's just called a sheetmetal hole punch.
« Reply #8 on: September 23, 2005, 02:48:02 pm »
Awesome.
« Last Edit: September 23, 2005, 02:55:23 pm by ChadTower »
Lilwolf
« Reply #9 on: September 23, 2005, 02:59:04 pm »
So nobodys going to mention a happs 49 way + GP49 encoder?
I hear they are the best all around joystick once they are broken in.  Not the best for fighters, but still very good.
I have different control panels for each.  So I would vote for a happs super, and a happs pacman reunion stick...
TOK
« Reply #10 on: September 23, 2005, 03:00:00 pm »
He bought a Craftsman set that was around $40.
If you want to take a chance on Harbor Freight, they have a real cheap set.
Might work once, and that's all you need.  ;)
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=91201
TOK
« Reply #11 on: September 23, 2005, 03:01:57 pm »
Awesome.  How much do those run?
EDIT:  Oh, duh!  I forgot, he wants to use a JPac he has on hand, which would preclude a third stick, yes?
Not at all, you just double up the wires from the encoder. Run one set to the 8 way, other to the 4 way. As long as he's only trying to use one of them at a time (since MAME will recognize both as stick 1) he won't have a problem.
« Reply #12 on: September 23, 2005, 03:07:39 pm »
Ah, yes, parallel wiring.  Gotcha.
Hrm... which is better... a pair of 4/8 ways, or keeping the existing 8 ways and buying the hole punch + a 4 way...
The cost is roughly the same, I think.
Level42
« Reply #13 on: September 23, 2005, 03:20:01 pm »
http://forum.arcadecontrols.com/index.php?topic=43210.0
and
http://forum.arcadecontrols.com/index.php?topic=42066.0
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #14 on: September 23, 2005, 04:00:42 pm »
From a gameplay standpoint, you will not beat a dedicated 4-way. 4-way wico leaf sticks are my personal pick. Next best compromise IMO is the 49way, but cost gets up there. 3rd choice is T-stick+, but I don't like mine in 8-way games. I really do like it in 4-way games because of the short throw, but it's no wico.
« Reply #15 on: September 23, 2005, 04:01:50 pm »
what would a 48 way give him?  He wants 4 way for 4 way games, 8 way for 8 way games... 48 way is neither.
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
« Reply #16 on: September 23, 2005, 04:08:06 pm »
I really like the T stick pluses I have, going with the Groovy Game stick you will have to alter the panel for the switch arm of the stickto stick through. Not easy unless you have mad welding skills like Stingray.
nostrebor
  • SHOCKING!!
« Reply #17 on: September 23, 2005, 04:14:10 pm »
You must come out of EE more often. You're missing some good stuff over here ;) ;D
http://forum.arcadecontrols.com/index.php?topic=32747.0
Stingray
« Reply #18 on: September 23, 2005, 04:18:58 pm »
Hey, we're doing our best to contain and quarantine Chad. Don't encourage him to leave the restricted area. ;)
-S
« Reply #19 on: September 23, 2005, 04:20:23 pm »
That's cool, but over the top for this guy.
He's not a heavy gamer.
nostrebor
  • SHOCKING!!
« Reply #20 on: September 23, 2005, 04:26:55 pm »
Don't get all fussy. I was just joshin on ya. Note the big simley. ;)
epic69
  • Last login:October 21, 2011, 04:21:03 pm
« Reply #21 on: September 23, 2005, 04:44:11 pm »
I would agree that the T-Stick plus is great as a 4-way and functional as an 8 way. I like it for ease of swtiching and it looks like any other joystick on the panel. The short throw is awesome for ms. pacman. If i had to do it again (which i probably will) i will go with 49way and gpwiz. I would love to be able to play Qbert as it is meant to be played, i have not figured out how to disable cardinal directions in mame and only use diagonals yet.
NoOne=NBA=
« Reply #22 on: September 23, 2005, 06:47:58 pm »
You set it just like you would any other game-specific control, except that you hit the diagonal after hitting enter to change the input.
That will give you P1 Right=Right Arrow Down Arrow in the game-specific controls.
That sets it so that you have to hit the Right Arrow AND the Down Arrow to send the game a Right command.
paigeoliver
  • Awesome face!
« Reply #23 on: September 25, 2005, 10:59:34 pm »
I have never found a mode switching joystick I was truly happy with. The Happs Universal (which switches from the bottom), is the only one I can really even tolerate.
« Reply #24 on: September 26, 2005, 08:28:59 am »
I like the J-Stik personally.  It is not switchable from the top, but at least the switching mechanism (rotating restrictor plate) is easy to rotate to switch modes.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #25 on: September 26, 2005, 09:11:16 am »
I'm very impressed with the Suzo Inductive's that I got. I haven't hacked a switch to them yet, but they seem to work great with the pot set half-way between 4-way and 8-way modes- you can hit diagonals at its full throw, but still play Donkey Kong and Pac-Man without hitting a diagonal.
Since these are the sticks that I grew up playing with they feel just right too.
fiscap
  • Last login:November 24, 2024, 03:30:36 pm
  • I dare ye enter... the dungeons of daggorath!!!
    • BYOAC blog
« Reply #26 on: September 26, 2005, 04:30:46 pm »
Ok guys - you're starting to scare me. I ordered four T-stick pluses last week (should be here today) for my cabinet. I hope I didn't make the wrong decision and I'm happy with them. I had considered the 49-way joysticks, but since I only have about 2.5" of clearance in my panel I didn't think they would fit.
deadmoney5
  • Last login:February 03, 2020, 11:02:02 pm
  • I don't feel tardy
« Reply #27 on: September 26, 2005, 06:12:59 pm »
I have T-stik plus's myself ..
I ended up putting cherry switches in place of the stiff ones that come with the T-stiks, though...
Much better....
the3eyedblindman
  • Last login:November 17, 2006, 03:00:06 pm
  • Soon: 4 Player Mame and Scratch Built Moonwalker.
« Reply #28 on: September 26, 2005, 07:07:22 pm »
Im really not satisfied with my j stick from ultimarc, I dont like the screw on ball top, when you move it around during a game it screws off sometimes, leaving you with just a steel stick in the middle of a game....and thats not a good thing... :-\
Coming soon: 4 player mame cab and Scratch built Moonwalker....Hall of Fame, here I come!
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #29 on: September 27, 2005, 07:36:17 am »
Just one point about the T-Stiks. About a month ago we changed the type of switches fitted to these, to a type which are much less stiff.
These were previously sold as an optional "light action" switch kit but are now standard fitment.
Andy W
« Reply #30 on: September 27, 2005, 08:08:57 am »
Tighten the ball on properly then ;)
Put a flat  screwdriver in the slot on the underside of the joystick shaft, and use a rubber grip to hold and tighen the ball.  Do it as tight as you can and it won't come accidentally undone.
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #31 on: September 27, 2005, 08:10:28 am »
Another vote for the Omnistick Prodigy from GroovyGameGear.
Level42
« Reply #32 on: September 27, 2005, 08:48:53 am »
Please people, lets'call it what it is:
Omnistick Basic (Groovy Game Gear) = Euro-stick (Ultimarc) = Suzo 500
The Omnistick Prodigy is a Suzo 500 with a modification to change from 4 to 8 ways from the top of the panel (a very nice mod if you ask me !).
Prices for the Basic (500) are very good at GroovyGameGear, but I just wonder why they just don't call the stick as what it is....
The 500 is the best stick with microswitches IMHO.
I still love my Inductive Suzo's more though....
nostrebor
  • SHOCKING!!
« Reply #33 on: September 27, 2005, 09:37:24 am »
Un screw the stick and put a bit of silicone in the hole/on the threads. Screw the stick back on tightly. This should hold it fine, and it will come back off if necessary.
« Reply #34 on: September 27, 2005, 11:01:39 am »
At this point, I may just stick a 4 way in the middle and leave the two 8 ways.
RTSDaddy2
  • Last login:April 03, 2014, 08:28:03 pm
  • Bees! Oh bother!
« Reply #35 on: October 02, 2005, 01:50:58 am »
My two cents -
I know some don't like the short throw, but I'd cut you before I'd let anyone take away my T-stick plus sticks.  Maybe it's just from years of console gaming, but I like the short throw.
SirPeale
  • Green Mountain Man
« Reply #36 on: October 02, 2005, 08:12:27 am »
My suggestion:
ditch 4 way altogether.  Since you already have a CP layout, use games that use that layout.  Two 8 ways plus three buttons each?  That's a massive amount of games.  That way you won't have to cut your CP, and it'll make things easier to wire, etc.
quarterback
« Reply #37 on: October 02, 2005, 12:52:59 pm »
My suggestion:
I'll add that I use my wico 8-ways 99% of the time and that includes playing pac-man, donkey kong and other 4-way games.    I much prefer the 8-way to the Ms Pac/Galaga reunion stick and it works fine in Mame with 4-way games, IMO.
In my next version of my CP I'm pretty sure I'm going to lose the dedicated 4-way all together.  YMMV
-- Chad Tower
