Author Topic: Getting this sticker off my PAC-MAN cabinet  (Read 4217 times)
BUCKETHEAD
  • Last login:April 04, 2024, 07:31:52 pm
  • Don't hate the player .... Hate the Game
« on: September 04, 2005, 12:43:28 pm »
I don't know if this is the proper place to post this?
If not please move it.
I picked up a PAC-MAN cabinet for $150.00 yesterday.
It has TIGER HELI in it right now.
krick
  • Gotta have blue hair.
Re: Getting this sticker off my PAC-MAN cabinet
« Reply #1 on: September 04, 2005, 01:51:12 pm »
Try lighter fluid.  Lighter fluid dissolves the glue and makes it easy to remove stickers.  Try a small area first to make sure that it doesn't affect the original pac man artwork.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« Reply #2 on: September 04, 2005, 04:01:19 pm »
You could also try a heat gun set on mid or low temp.  Mask the area around the sticker with tape and maybe foil.  Warm the sticker enough to make the vynal pliable again so you should be able to peal off more at a time.  Try a nylon scraper too.  Not metal.  You just have to be real carefull not to blister the paint.
After you get the plastic off, go back and use Rubber Cement thinner to remove the glue.  It should leave the paint in tact, but test it first.
(don't use Rubber Cement thinner or lighter fluid at the same time as a heat gun, or you'll be posting a message about how to remove the melted polyester shirt from your body)
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
LiquidFire
  • Last login:February 11, 2022, 09:22:19 pm
« Reply #3 on: September 05, 2005, 12:32:47 am »
Please allow me to elaborate slightly on the heat gun post-this is by far the best way to remove a vinyl sticker.
Use a hair dryer first, this may be all the heat you will need and won't be as likely to light anything. The idea is to liquefy the glue that is holding it in place.
Warm an area about a square foot for a minute or so before you attempt to peel.
Be patient, keep the heat right in front of the peeling sticker. Go slow and you may find the entire sticker and its adhesive comes off cleanly.
As for solvent to use for cleanup, try rubbing alcohol first as this is harmless to just about everything. Then if you need more strength you can go to something more flammable-be careful about open flames and don't use anything indoors.
Kerosene, although unbearable to smell, will break almost any glue without damage to a finish. Don't work without good ventilation!
SirPeale
  • Green Mountain Man
« Reply #4 on: September 05, 2005, 07:19:42 am »
Poor guy, let him out!
koolmoecraig
    • My Intervention
« Reply #5 on: September 05, 2005, 04:36:43 pm »
Hair dryer and patience. It WILL work. I wouldn't use a heat gun on it. Just take your time.
quarterback
« Reply #6 on: September 05, 2005, 11:00:54 pm »
LOL  I had the exact same thought. :D
-- Chad Tower
BUCKETHEAD
« Reply #7 on: September 06, 2005, 07:22:48 am »
I let TIGER HELI out now.
He flew away safely!
missioncontrol
  • MC-Retro says Wot!
  • Trade Count: (+13)
« Reply #8 on: September 06, 2005, 02:11:56 pm »
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #9 on: September 06, 2005, 02:12:46 pm »
Tiger-Heli is out, so now the cab has No_One in it?  ;)
Oh, and another vote for the hair dryer.  Heat guns get REALLY hot- OK if you're peeling from a surface you aren't worried about, like getting an old overlay off of a metal control panel- but could easily cook your Pac-Man art.
« Last Edit: September 06, 2005, 02:14:52 pm by Kremmit »
Jakobud
  • Last login:April 07, 2026, 10:10:56 pm
« Reply #10 on: September 07, 2005, 03:09:30 am »
Hair dryer for the win.
BUCKETHEAD
« Reply #11 on: September 07, 2005, 07:28:01 am »
I haven't had a chance to use it yet.
But im going with the HAIR DRYER first.
Ohh by the way?
I was looking closely at the burn on the monitor.
This PAC-MAN has had.
PAC-MAN,  MS. PAC-MAN  JR. PAC-MAN Pcb's  and now TIGER HELI  Pcb
in it.
Amazing the shape it is in!
BUCKETHEAD
« Reply #12 on: September 09, 2005, 11:16:16 pm »
Used a Hairdryer as recomended.
« Last Edit: September 09, 2005, 11:18:09 pm by BUCKETHEAD »
JCL
  • Last login:April 20, 2008, 04:11:10 pm
  • What Are You Looking At?
« Reply #13 on: September 09, 2005, 11:47:09 pm »
That looks great. Really shows what work, patience and good technique can do!
