Author Topic: Installing T molding  (Read 2910 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: August 23, 2005, 01:22:22 pm »
What do you use to make the groove in thwe wood? A router or a Dremel?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
Ed_McCarron
Re: Installing T molding
« Reply #1 on: August 23, 2005, 01:51:47 pm »
I used a small beaver.  Just turned him loose on the MDF and whammo -- t-molding slot.
Seriously, your choice.  Router w/ slot cutting bit the proper thickness for your molding is probably the best bet.
Budget?  Have a dremel?  Theres a $10 bit that works like a charm.  You will burn up your dremel in the process.  The part # is around somewhere.
I used that bit in a roto-zip with decent results, albiet with much dust and mess.
I'm the last person to say something like this, but its been discussed to death already,  even I found this info by searching. :)
88mph
  • Last login:July 30, 2018, 12:17:48 pm
  • I need fuel!
« Reply #2 on: August 23, 2005, 01:55:53 pm »
If I had my choice, I would definitely go with the router.  The router is built for jobs like this, and the dremel is not.  That said, the job is not impossible with the dremel and the right attachments.
I wonder if there is a place where you can rent a router for a day or so..
-88mph
« Last Edit: August 23, 2005, 01:58:01 pm by 88mph »
rescue161
  • Last login:August 04, 2025, 05:20:11 pm
  • I built my own Cabaret machine!
« Reply #3 on: August 23, 2005, 02:28:58 pm »
I'm cheap and routers are only sold in 220V here.  I live on base where there is only 110V.
So, I used a drill attachment that worked like a champ.  It's basically a slot cutter bit with a guard/gide.  I used my codless drill and I was finished in no time.  It was about $20.00, so a LOT cheaper than buying a router that I won't be able to use back in the States.
If I were in the States, I'd most definitely get a router.  Whenever I get back, I'm getting one.
Good luck!
"Censorship reflects a society's lack of confidence in itself." - Supreme Court Justice Potter Stewart
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« Reply #4 on: August 23, 2005, 05:45:27 pm »
Use a router.  If your dad doesn't have one, ask him if he'd borrow one from a friend or neighbor.  I'll sell you my slot cutting bit if ya need it.
  • Last login:April 18, 2026, 05:46:43 pm
« Reply #5 on: August 23, 2005, 06:44:20 pm »
Use a router.  Accept no substitutes.  Once you have the depth set you can route every panel in less than 15 minutes and it comes out absolutely perfect.
USSEnterprise
    • USS Odyssey
« Reply #6 on: August 23, 2005, 09:56:46 pm »
I have a router, but its not a great one. A Ryobi. Also, I don't get how one wounf get into angled corners with a router?
Bones
  • [Moderator]
« Reply #7 on: August 23, 2005, 10:29:22 pm »
Using a router with a T-slot cutter is the only way to go.
Don't worry about the corners. The guide bearing will follow the cabinets profile and the blade cuts deeper than you will require so where the tool doesn't get right into the tight corners, it will still cut a groove deep enough to install the T-molding.
GameOver
  • Got a quarter?
    • Check out my cab!
« Reply #8 on: August 23, 2005, 10:36:02 pm »
Hey Bones - is it really lunch time in Sydney right now?  What's for lunch?!   8)
Bones
  • [Moderator]
« Reply #9 on: August 23, 2005, 10:44:46 pm »
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #10 on: August 23, 2005, 10:55:49 pm »
Hey! there's nothing wrong with that Ryobi router!  It'll be perfect for MDF
