Author Topic: BETABRITE SCROLL LED SIGN IN ARCADE OS  (Read 8300 times)
Netcat
  • Last login:October 20, 2023, 08:41:25 am
« on: August 11, 2005, 10:02:29 pm »
HELP! PLEASE
Danny Rego submitted the modifications to ArcadeOS some time ago that allows interfacing with an LCD sign via Serial or parallel port.
I cannot find Danny Regos Email anywhere, so I am posting here in hopes
Someone can help me
I have a Betabrite LED sign (not LCD) It works thru the serial port from DOS
In order to make it work in DOS I must first issue a:
MODE COM1:4800,E,7
Command, so it will set proper parameters for serial communication with the sign
ALSO in order for messages to be displayed specific characters must be
Sent PRECEDING the text, and AFTER the text
i.e.
------------------------------CONTENTS OF TEST.TXT-----------------------------------
 " pQ
Netcat
Re: BETABRITE SCROLL LED SIGN IN ARCADE OS
« Reply #1 on: August 11, 2005, 10:08:57 pm »
I am really really sorry didnt meant to posttwice, I just couldnt find my post
perhps the sysop can remove my clone post.
thanks
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #2 on: August 11, 2005, 10:24:16 pm »
I have a betabrite in my cabinet.
www.ohiostate.photosite.com
Please assist me in setting this up as this is well beyond my knowledge level.
Netcat
« Reply #3 on: August 11, 2005, 10:27:34 pm »
I dont uunderstand
It appears your sign is up and running in your cabinet !
you running your emulator in DOS or WINDOWS ??
it looks like its working in your photos ???
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #4 on: August 11, 2005, 10:45:05 pm »
I am just using the program that comes with the sign.  I am interested in getting the controls.dat or whatever is used to display the controls to display before a game.  Is that what you are trying to do?
Netcat
« Reply #5 on: August 11, 2005, 11:06:32 pm »
Kinda.
Except I am working in DOS
using Arcade OS (DOS Based frontend)
I am under the impression you are running under WIndows ????
If you nned info on generating proper CHaracter sequences to send text to SIgn I can help you with.
Sending the data to the signs is another matter the Frontend you are usign must support it.
ArcadeOS does support sending data to a seiral port (somewhat) I suspect some of the settings are hardcoded into Arcade os i.e. Stop Bits & Parity and therefore the data is not acknowledged by the sign when it is sent.
ALl of this is of course in the realm of theory. if someon e here knows how to look into the SOurce code and could tell me, that would be great.
Netcat
« Reply #6 on: August 11, 2005, 11:15:56 pm »
AHA !!!!!!!!!!!!!!!!!!!!!!
Found the following information in the AOS_MAN.DOC file
Note: Any Serial Device must be configured for 8 data-bits, 1 start-bit, 1  stop-bit and no parity. BAUD rate is configured in the arcadeos.cfg file
Therefore either I figure a way to reconfigure these settings within the sign (No Jumpers here!) or I find someon able to modify arcade os.
Help !
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #7 on: August 11, 2005, 11:16:40 pm »
Im using Mamewah and windows.
Netcat
« Reply #8 on: August 11, 2005, 11:47:26 pm »
DOes mamewah support sending information to the serial port ???
I now understand I nned to set the sign to 8N1, my betabrite is model 1040-4402 I am looking very hard but have yet to find out if and how to do this, either that or ARcadeOS modification.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #9 on: August 11, 2005, 11:53:07 pm »
Yes, mamewah does support LCD to comm1 port.
Netcat
« Reply #10 on: August 12, 2005, 12:45:17 am »
As long as you can determine the com port settings and what text exactly is sent to the com port YOU ARE ALL SET !!!
I have written an article regarding my discoveries so far including a groovy little digram I made detailing how to build yourself an interface cable
enjoy.
http://www.780tech.com/arcade/
Now if someone could please tell me how to set my betabrite to 8N1 ?
Netcat
« Reply #11 on: August 12, 2005, 12:56:20 am »
Well according to the BETABRITE Protocol PDF
my the EZKEYII (I Believe thats mine) only supports following settings
EZKEY II
First released:    1991
Baud rate:    1200, 2400, 4800
Start bits:      1
Data bits:    7
Parity:       Even
Stop bits:    2
Flow control:   NONE
If this is the case, my only hope is that someone (Much smarter than me) can modify ArcadeOS for me to allow me to set these parameters, sure would open a whole world of possibilities, dont understand why they hardcoded it to 8N1 to begin with.
Help !
Acids
  • Last login:July 26, 2025, 06:10:07 am
  • Bring It.. Smart arse!
« Reply #12 on: August 12, 2005, 02:19:27 am »
I was with the keymaker and i think he choose a different door than normal..
Bam here we are..
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #13 on: August 12, 2005, 03:39:18 am »
Can't help with ArcadeOS, but Mamewah will send text from a file out the serial port, and you can set any com port settings you like. It works like a charm on an LCD attached to the serial port.
There is no reason at all this will not work with a betabrite. They use ASCII just like all the LCD's I've seen, but just just different control characters for fancy stuff. it will probably display straight text with no extra info, but for fancy wipes/scrolling you will need to specify what you want. I've looked into it briefly to try and add support for Betabrites to my LCDgen program - they use the Alpha protocol if anyone is interested. Unfortunately I don't own one, which makes any kind of testing near impossible....
Netcat
« Reply #14 on: August 12, 2005, 07:38:52 am »
 I might be wrong but I believe Betabrite actually uses the alpha protocol.
Can someone confirm for me ?
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #15 on: August 12, 2005, 09:21:07 am »
Yes it does.  I have one.  Silver also just pointed this out.
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #16 on: August 12, 2005, 10:28:29 am »
I do own one, but I am no help on the testing.  I appologize in advance, I'm pretty much tagging along on this one.  But, let me know if there is anything I can do.  Silver, do you have a tutorial or something than can help me get started?  Someone set me one the path, and I will try to follow.
Netcat
« Reply #17 on: August 12, 2005, 11:16:48 am »
mccoy178
Have you read teh page I put together for U? it lays out the basics on how to interface the sign and send text to it
Also anyone else interested I have put together the "most comprehensive" diagram so far to interface the Betabrite to your PC (at leat I think so)
http://www.780tech.com/betabrite/
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #18 on: August 12, 2005, 02:12:46 pm »
I'm gonna go buy a new cable and modify it.  The rest will take me a minute to figure out, but I think I can handle it.  Silver, considering I'm using mamewah and windows, does his fact sheet jive with what I need to do?
Netcat
« Reply #19 on: August 12, 2005, 04:19:13 pm »
OK I have fixed my system so now it dual boots into 98SE in order to test the sign with mamewah
after a fashion I got Mamewah running
Have made changes to .INI files
working on generating LCD files
will let you know how it goes
Netcat
« Reply #20 on: August 12, 2005, 05:40:51 pm »
OK SO now I have Mamewah Displaying a nice
"Welcome to MameWah" as soon as I start the program
NICE !!!
I am having a b..... of a time getting the LCD file right
Latest version of LCDGEN states Betabrite support but it doesnt appear to be working or maybe I';m doing something wrong.
Even tryed cutting and pasting the necessary SCROLL HEADER & SCROLL ENDER
I suspect the characters are getting messed up with the CUT & PASTE functions
SILVER
could you please checkl out the Header and footer information on the following two files, THSE WORK just by sending them to the COM port.
http://www.780tech.com/betabrite/simple.txt
http://www.780tech.com/betabrite/complex.txt
If these files are edited with wordpad or notepad they stop working (use MS WORD or EDIT command)
Is it possible to modify LCDGEN to provide an option to ONLY output the game name with the proper HEADER AND FOOTER tagged before and after text
Netcat
« Reply #21 on: August 13, 2005, 02:06:40 am »
OK GUYS BREAKING NEWS.
The sign is now FULLY functional within Mamewah
Could not manage for the life of me to make LCDGEN do the generate proper characters
Developped a litle application in Quickbasic that generates the gamelist, extracts the names & descriptions, creates the LCD directory, creates the files containing Betabrite compatible commands enclosing the description of each game
Pleas evisit my site www.780tech.com/betabrite to download application
Regards.
Tony
NOTE: I would still rather do this from ArcadeOS, anyone know how to modify C code ?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #22 on: August 13, 2005, 02:40:45 am »
Wonderful, wonderful news! :o  This takes the idea of the sign to a whole new level.  As soon as I start to work on this, I will have a million questions.  What a wonderful thing this is.  Thanks for the hard work! ;D
Silver
    • Mods'n'Mods
« Reply #23 on: August 13, 2005, 07:32:24 am »
Hi Sorry Betabrite support is listed but not fully functional in the version available to download..... The header/ender boxes will not easily support non-printable ASCII characters which is what the alpha protcol use (and are in the txt files you printed). Notepad/Wordpad do not fully support these and tend to convert them to something else - hence they stop working.
Theres no reason I can't change LCDgen to create any output you want - the issue so far is that I don't have a betabrite to test, and although I have the full alpha protocol documentation, its clearly overkill for what we want.
you seem to known the exact ASCII characters you want (seeing as you can generate the text files above) can you post them/pm them to me? eg ASCII 10,15,25,13 "TEXT" ASCII 10,13 or whatever.
Netcat
« Reply #24 on: August 13, 2005, 11:13:08 am »
The corrsponding ASCII characters that display a UNICOLOR, STATIC output
PREFIX
CHR$(112)+CHR$(81)+CHR$(232)+CHR$(192)+CHR$(143)+CHR$(156)+CHR$(197)+CHR$(1)+CHR$(88)+CHR$(120)+CHR$(181)+CHR$(1)+CHR$(1)+CHR$(90)+CHR$(48)+CHR$(48)+CHR$(2)+CHR$(65)+CHR$(65)+CHR$(27)+CHR$(32)+CHR$(98)
SUFIX
CHR$(4)
The corrsponding ASCII characters that display a MULTICOLOR, DYNAMIC output
PREFIX
SUFIX
CHR$(4)+CHR$(114)+CHR$(14)+CHR$(64)+CHR$(27)+CHR$(8)
Netcat
« Reply #25 on: August 13, 2005, 11:17:16 am »
Also remember the LED sign requires only displaying the name of the game and no additional info regarding cotrollers, I tried to make LCDGEN output only this info and nothing else but was unable to do so.
It sure would be nice if Mamewah could switch Game names as you scroll thru them and not just when you load the game, mamewah could wait for 10 seconds of inactivity and then revert to the original title message it sends to the LCD/LED sign
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #26 on: August 13, 2005, 09:14:12 pm »
I'm certain this is no help really, just wanted to post it FWIW:
http://www.ams-i.com/cgi/wwwthreads/wwwthreads.pl?Cat=
It is a site dedicated to betabrite support.
Netcat
« Reply #27 on: August 13, 2005, 10:19:53 pm »
Mccoy
How is it going with your interface?
With the information we have uncovered so far you should be up and running with Mamewah?
mccoy178
  • Trade Count: (+9)
  • Go Bucks!
« Reply #28 on: August 13, 2005, 10:58:49 pm »
I could not find the proper cable this weekend.  I don't want to cut up the one I have.  I tried the tutorial that you have, but due to the cable, it didn't work.  Also, I spent all day on the J5 viewer and getting it to work in mamewah.
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #29 on: December 09, 2006, 05:49:13 pm »
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« Reply #30 on: December 11, 2006, 07:02:04 pm »
Okay, I would have never thought of using something like that for a MAME application, but that would be cool to use in place of a marquee. Where does one find a betabrite sign?
www.wolfelectronics.ca
Cap Kits for Canadians!
loadman
    • MaLa
« Reply #31 on: December 11, 2006, 08:11:04 pm »
If you click on the link above I put a link below the picture of the BetaBrite
edge
  • Last login:May 08, 2025, 09:08:47 am
  • AttractMode and GroovyArcade rock!
« Reply #32 on: December 11, 2006, 08:29:09 pm »
Grauwulf,
They show up on ebay alot... I've seen them as low as 75 bucks, and as high as 125+..
Grauwulf
  • Button Masher
« Reply #33 on: December 13, 2006, 11:35:21 pm »
Okay, now I've started looking for one of these things. Does anyone have a picture of one mounted in a machine in place of a marquee? I'm looking for ideas now. :D
edge
« Reply #34 on: December 13, 2006, 11:45:16 pm »
Check out mccoy's site:
http://www.ohiostate.photosite.com/MameArcade/
