Author Topic: Pushbutton flip guards ???  (Read 4772 times)
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« on: July 26, 2005, 04:25:36 pm »
I'm looking for a pushbutton to use for power my PC on/off. There are plenty out there but what Im looking for is one with a flip guard. You have to flip up the plastic before you can push the button. Since this is the PC power button it has to be a momentary pushbutton not a toggle or rocker switch. I've found plenty of guards for those.
I've search the web for 2 days with no luck, anyone seen those anywhere before?
The Way Back Machine - http://www.taborious.com
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
Re: Pushbutton flip guards ???
« Reply #1 on: July 26, 2005, 10:55:27 pm »
You can get momentary toggle switches.  The guard basically holds the switch in the "off" position anyway.
This what you're looking for?
http://www.thebestconnection.com/showcase.shtml
joshbr7257
  • Last login:August 15, 2006, 10:12:28 pm
  • B.Y.O.B.!!!!!!!!!!!
« Reply #2 on: July 26, 2005, 11:54:16 pm »
yes i am looking for the exact same thig that stormy151 is looking for. I dont think the gaurd in that url will work its to small i think, im looking for something to just cover the button and protect it from accidental press's not something to hold the button down? and i think stormy is looking for what i want to.
WANT A FREE PSP? CLICK BELOW.
http://www.FreePSPs.com/?r=17776949
AlanS17
    • AlanS17
« Reply #3 on: July 27, 2005, 12:31:07 am »
He needs a guard for a momentary pusbutton, not a toggle switch.
I'll be using a momentary pushbutton for mine, but I won't be using a guard. Rather, I'll be setting mine in so it can't be accidentally pressed. Maybe that'll work for you too.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #4 on: July 27, 2005, 12:31:34 am »
Hmmmmmm
I need the exact same thing as well.
Without thinking, I put my cab's power button on the underside of my control panel right where my hand needs to go to open the access door to the controller plugs of the Xbox inside.
It'd be great if anyone found some flip guards that covered a standard arcade button.
I honestly hadn't even thought of that solution, and was looking instead to just sink the button into the wood, so that it would be flush, but I'd much rather have the cover.
I am going to do me some searchin as well, and will post back any results if I can find any.
joshbr7257
« Reply #5 on: July 27, 2005, 12:53:40 am »
thanks for thethought but i actually would much rather have a cover like i said before, cause that still has a chance of being pressed accidentally, please post anything you find versapak cause i cant find anything
ultramagnus
  • Last login:September 09, 2005, 02:10:45 am
« Reply #6 on: July 27, 2005, 04:47:53 am »
hmm, you could try and make one, if you have some skills with wood/metal/plastic it shouldnt be too hard.
the other option i can think about would be get a ejection panel out of a f-16 or somthing similar
Taborious
  • Win or go Home!
« Reply #7 on: July 27, 2005, 08:32:40 am »
I did find a flip gaurd for 16mm pushbuttons here:
http://www.mouser.com/catalog/622/1070.pdf
They have a very large selection and it shows pricing for single units. I have not ordered anything as I'm still researching and deciding whether I want an illuminated pushbutton or not. Just thought I'd pass along some info.
Stormy, I have not seen a momentary toggle switch anywhere and I didn't seen any at the link you posted.
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #8 on: July 27, 2005, 10:05:15 am »
How about at Mouser?
http://www.mouser.com/index.cfm?handler=displayproduct&lstdispproductid=689569&e_categoryid=84&e_pcodeid=69103
Or Hosfelt?
http://www.hosfelt.com/en-us/dept_157.html
Or surplus places?
http://www.surplussales.com/Switches/SWToggle-1.html
American Laser Games Wrapper
O2em Rom Utility
Brewser
  • Last login:August 10, 2006, 02:01:48 pm
  • Fighting the forces of evil since 1978
« Reply #9 on: July 27, 2005, 12:12:33 pm »
If your CP sticks out over the sides of your cab, why not mount a pushbutton on the back of the cp. That is what I did with my slikstik CO and it works great and no one hits it my accident.
joshbr7257
« Reply #10 on: July 27, 2005, 09:28:05 pm »
I cant believe its this hard to find a button guard???????? :'(
Taborious
  • Win or go Home!
« Reply #11 on: July 28, 2005, 09:35:35 am »
Check my earlier port, mouser.com had some and they showed single unit pricing. I was surprised at how hard it was to find this stuff. I thought for sure Radio Shack would have had it but nope.
joshbr7257
« Reply #12 on: July 28, 2005, 05:05:54 pm »
did you order the ones from mouser?
Taborious
  • Win or go Home!
« Reply #13 on: July 28, 2005, 05:52:54 pm »
not yet...
