April 19, 2026, 09:59:23 am
What do you think the hardest part of building your own cabinet is?1.
Quote from: javeryh on June 28, 2005, 06:39:02 pmWhat do you think the hardest part of building your own cabinet is?1.
when you're cutting the side panels, what is best way ?Do one side first, then clamp it on 2nd board for cutting or clamp both boards and cut both sides at same time ?
Quote from: skarr on June 30, 2005, 06:50:25 amwhen you're cutting the side panels, what is best way ?Do one side first, then clamp it on 2nd board for cutting or clamp both boards and cut both sides at same time ?I'd cut one and get it perfect and then use a router and pattern cutting bit to make an exact copy or you can do what I did and get 1/4" plywood and make a pattern and se it to cut both sides.
