Author Topic: can i use dremmel for tmolding?  (Read 5965 times)
alundra
  • Last login:February 02, 2009, 09:30:05 pm
« on: June 14, 2005, 06:47:45 pm »
router is a little expensive to me..i can find all those good dremmel at flea market and pawnshop for a very cheap price..so yea..im thinking use the dremmel instead..i only install the tmolding on the top board of the CP..any comment? thanks
AlanS17
    • AlanS17
Re: can i use dremmel for tmolding?
« Reply #1 on: June 14, 2005, 06:53:14 pm »
You're welcome to give it a shot, but I wouldn't expect it to work properly. In fact, I tried once before and I wasn't happy with the result.
nobody
  • Last login:September 05, 2005, 02:57:54 pm
« Reply #2 on: June 14, 2005, 06:55:16 pm »
i think you can, it just takes alot of time
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #3 on: June 14, 2005, 06:57:03 pm »
You could do it, but you will need a very steady hand. Unless of course you have the dremel "drill press" table or whatever it is.
dmsuchy
  • Last login:August 29, 2025, 01:27:50 pm
  • I kill communist llamas for fun.
« Reply #4 on: June 14, 2005, 06:57:31 pm »
I would buy a cheap router, like Roybi or Craftsman. It take quite a motor to cut all the t molding slots, thats alot of material to cut through. Also a router is a great tool for almost anything.
alundra
« Reply #5 on: June 14, 2005, 07:04:22 pm »
well..i might buy a router then..im not a patient type of guy..if something take me forever to do it, and when i get it done but turned out not like i was expected..i usually kick the hell out of it and destroy the damn thing...
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #6 on: June 14, 2005, 07:17:14 pm »
As someone who uses a dremel a LOT (although I wouldn't call myself an expert by any means), I will say that the dremel can do a lot of things... but I would not use it to cut a t-mold slot.  You would need a super steady hand, and even then, its just not physically possible IMHO to keep your line perfectly straight on the edge of a board like that.  Your T-mold will probably wind up waving up and down with little edges popping up or down throughout the whole piece.
The dreme has a "router" attachement.. which works decent enough.. but still not well enough IMO to do the job.  It's just not meant to cut through that much MDF.  It fights it tooth and nail.
Buy a cheap router, or borrow one from a friend.  Or perhaps see if somewhere near you rents tools... that'd be your best bet.
first off your and idiot
Clonedsheep
  • Last login:March 29, 2025, 09:59:42 pm
« Reply #7 on: June 14, 2005, 08:04:53 pm »
Hi, I am Almost to your point in my cabinet. I did read on a thread that CitznFish had on his site. A guy used the #542 Carbide slot cutter Dremel bit for the t molding. He said it worked great but practiced first. I was going to use my dremel. I have not really used it since I got one for Christmas. I will be interested in what others have to say.
The king of 1/2 done projects
AlanS17
    • AlanS17
« Reply #8 on: June 14, 2005, 08:08:53 pm »
I highly discourage the idea. That's about all I've got to say about that.
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: June 14, 2005, 08:41:45 pm »
Don't use a dremmel tool. I broke 2 bits ($32 plus shipping)
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #10 on: June 14, 2005, 09:10:32 pm »
I went down this path and with patience, it can be done. Smooth groove that did not end up wavy as some might be lead to believe but you must work slowly both to ensure you keep path straight and do not burn up the dremel.
I used the carbide bit and did *not* use the router attachment. Rather, I set the depth with the standard offset attachment, turned the piece on its side and went to work.
If you have access to a router, it is certainly the tool of choice for such tasks assuming you acquire a slot cutting bit as well.
I've done all sorts of tasks with my dremel and its still going strong but if you are going to have to purchase one for this single task alone, you would be better off searching out a router option.
I use my dremel for lots of tasks including case mods, household chores, plexi signs, etc so it was something I already had including the carbide bit.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #11 on: June 14, 2005, 09:11:57 pm »
Isn't there a Dremel router adaptor tool??
NO MORE!!
Kev-in DFW
  • Last login:September 10, 2008, 12:36:09 pm
  • Duke it out amongst yourselves...
« Reply #12 on: June 14, 2005, 09:18:27 pm »
There is a Dremel router attachment, but it is NOT for a t-molding slot, for sure.  It will control the depth, but it will not control the placement of the slot and keep it centered in the middle of the edge of the MDF.  A router is the ONLY way to go.  If they made a winged slot cutter attachment for a Dremel, then it might work. I still think it would be far underpowered for the job.
Good luck!
Kev~
The biggest tragedy in life is not death, but what dies inside of us while we are still alive...
xonix_digital
  • Last login:February 20, 2016, 04:36:05 pm
  • I am the Milky-Way Commander!!!
« Reply #13 on: June 14, 2005, 09:57:06 pm »
ROTO-ZIP!!!
Thats all I gotta say. It's like a diesel Dremel/Router thing. With the right attachments it is the sickest cutting tool I have used. Good Luck!
- XD
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #14 on: June 14, 2005, 11:01:36 pm »
ROTO-ZIP!!!
- XD
You have clearly never used a plasma cutter.
Underway: Joey's Arcade
alundra
« Reply #15 on: June 15, 2005, 12:53:37 am »
can someone post a picture of a router drill bit for tmolding? and can the router carve custom holes, like a half depth square hole for mounting joysticks...sorry i never work on these stuff before..thanks
bjk7382
  • Last login:January 15, 2011, 09:05:16 pm
« Reply #16 on: June 15, 2005, 01:35:44 am »
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
« Reply #17 on: June 15, 2005, 02:06:40 am »
ROTO-ZIP!!!
- XD
You have clearly never used a plasma cutter.   8)
http://www.torchmate.com/torch1.jpg
-- Chris
oooh.. i want one of those 8)
Chris
    • Chris's MAME Cabinet
« Reply #18 on: June 15, 2005, 08:10:20 am »
I've used a Dremel for cutting T-molding slots in a CP.  For a CP, a Dremel is fine.  I would NEVER try to use it for a whole cab!
Also, after cutting slots for 2 panels and using it with the routing attachment to route a space for a joystick plate, the Dremel burned out.
--Chris
--Chris
alundra
« Reply #19 on: June 15, 2005, 01:13:33 pm »
ok, i just bought  a router..but i dont know which bit is for tmolding..i ask a couple guys at Home Depot and none of them know.. i saw there is a blade call "3 wing slot cutter" but it just a blade, it doesnt have any handle to attach to the router...dont know if the right one..can someone here give me an example for 3/4 molding slot? thanks
CJK
« Reply #20 on: June 15, 2005, 01:23:14 pm »
You usually need a 5/16" slot cutter, but check with the supplier of your T-molding to be sure.
The blade you saw is actually only half of the slot cutter. The other piece is an arbor, which acts as a shaft onto which you bolt the actual slot cutting bit. Then you insert the whole assembly into the router's collet like any other bit.
-- Chris
bjk7382
« Reply #21 on: June 15, 2005, 01:31:21 pm »
It is a 5/16 arbor, but it is only 1/16 thick, which is what 3/4" t-molding calls for.
Here is what I use, the bearing isn't totally necessarry, but I wanted uniform depth.
alundra
« Reply #22 on: June 15, 2005, 01:34:09 pm »
where do you bought it? i found this one on the internet..http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_slot.html#Anchor%20slotct3w
it listed as 3 wing slot  cutter..this one will also work as well right?
CJK
« Reply #23 on: June 15, 2005, 01:36:24 pm »
You'll want the bearing -- either that or you'll have to use some sort of an edge guide, which can be tough on curved edges.
-- Chris
bjk7382
« Reply #24 on: June 15, 2005, 01:43:57 pm »
Stingray
« Reply #25 on: June 15, 2005, 01:48:53 pm »
A router is one of those tools that everyone should own. Once I got one I wondered how I ever did without it.
-S
alundra
« Reply #26 on: June 15, 2005, 02:04:52 pm »
thanks alot guys.. ;D
xonix_digital
« Reply #27 on: June 15, 2005, 03:34:48 pm »
ROTO-ZIP!!!
- XD
-- Chris
Why would you use a plasma torch for T-Molding again???
- XD
CJK
« Reply #28 on: June 15, 2005, 08:41:16 pm »
I guess you could use it if you were building your cab out of stainless steel or something. (Now THAT would be a HOF project!)
-- Chris
Frosty
  • Last login:December 30, 2021, 11:11:38 pm
« Reply #29 on: August 07, 2005, 04:35:17 pm »
Just a little feedback about my experience with a Dremel and t-molding slot for the control panel:
While I would recommend a slot cutting bit and a router for a large job (molding for the whole cabinet), I had some really nice results with the Dremel and the tungsten carbide cutting bit on just the control panel.  With a little planning and a steady hand, you can come away with a nice slot for your t-molding...
DreamArcades
  • Last login:April 26, 2022, 05:36:40 pm
    • Dream Arcades, LLC
« Reply #30 on: August 07, 2005, 08:11:55 pm »
If you use a dremmel I'd recommend using 7/8 t-molding. You can then cut off the excess on either side with a utility knife. It's it's a little wavey no one will know.
I've don this with a skill saw before when in a jam.
peanut
  • Last login:November 11, 2009, 01:47:29 pm
  • arcade nut
« Reply #31 on: August 08, 2005, 04:53:26 am »
kinda off topic but, could u use a dremel to cut the holes for the buttons?
PedroSilva
  • Last login:August 01, 2018, 08:37:57 am
  • Grettings !
« Reply #32 on: August 08, 2005, 07:27:55 am »
There are some attachments that might do the trick ...
« Last Edit: August 08, 2005, 07:31:37 am by PedroSilva »
pointdablame
« Reply #33 on: August 08, 2005, 01:23:12 pm »
I've used that mini saw, and let me just tell you ..... I have NEVER been more scared in my life.  I don't know what it is, but putting any toothed saw blade on a dremel, even with the guard is VERY scary.
I need some weight and girth to my saws... I'm afraid I'm gonna zip something off that I'll need  :o
