Author Topic: Trackball Help!  (Read 2519 times)
jrj8541
  • Last login:May 29, 2008, 04:48:09 pm
Trackball Help!
« on: May 20, 2005, 05:15:50 pm »
Howdy!  I bought a trackball from Peale (I think) a few months ago.  I am finally getting around to building my machine and I have a few questions about the trackball.  It rolled fairly well when I got it, but rolling it now it rolls extremely slowly.  I opened it up and cleaned everything off, but its still less than optimal.  The bearings look to be R74 bearings.  Doing a quick search online I found some for sale for 12 bucks, which seems a little steep!
I was curious if anyone knows where I could get them cheaper, or what I could do (can you use WD40 or the like on them?)
Thanks so much for the help guys.  Only a few more loose ends to tie up and I will have my first machine all done!
James
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
Re: Trackball Help!
« Reply #1 on: May 21, 2005, 12:15:10 am »
try some 3in1 oil.
quarterback
Re: Trackball Help!
« Reply #2 on: May 21, 2005, 12:28:27 am »
therealbobroberts sells complete roller/bearing kits for likst $20 or something (don't sue me if I'm off on the price) but yeah, try some 3-in-one.   You can also put the bearings onto the pointed end of a pencil, put the eraser end into your drill and spin those babies up.
-- Chad Tower
IntruderAlert
  • Last login:May 02, 2007, 09:10:59 am
  • Chicken.. Fight Like A Robot
    • Intruder Alert
Re: Trackball Help!
« Reply #3 on: May 21, 2005, 01:09:10 am »
What kind of shape are the rollers in?
I recently experimented with cleaning a set of bearings.
I had some WD40 and some R/C car bearing cleaner lying around
I took a small cup and sprayed each bearing liberally over the cup so as not to waste the cleaning fluid and let the bearings soak for a bit while agitating the cup.
Then poured it all out and did it again..and again.. and again until the fluid stayed clean looking after agitating.
Then after emptying the cup the final time I oiled the bearings with 3in1 oil over the cup and let them soak a bit while shaking the cup around again.
The result was much better performance but don't expect new performance from old bearings and rollers
eventually you'll have to end up buying a new set
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Trackball Help!
« Reply #4 on: May 22, 2005, 01:54:06 pm »
When you swish a bearing around in oil like that, how do you get the outer rim of the bearing oil-free? Seems to me if there's oil on that outer edge, them the trackball will just glide across the bearing and not really turn it real well.
NO MORE!!
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
Re: Trackball Help!
« Reply #5 on: May 22, 2005, 02:06:44 pm »
Bob Roberts says not to use WD40 because it will become sticky over time and gum up the bearings.
Kremmit
  • - AHOTW -
  • Who the heck is that?
Re: Trackball Help!
« Reply #6 on: May 22, 2005, 02:25:01 pm »
So?  If the ball glides across the bearing easier than turning the bearing, they the ball is rolling pretty darn resistance-free.  Let it!
JODY
Re: Trackball Help!
« Reply #7 on: May 22, 2005, 02:41:23 pm »
As long as the encoder wheel turns.  Lube up that ball and shaft though and the encoder wheel doesn't turn and it isn't playable.
IntruderAlert
    • Intruder Alert
Re: Trackball Help!
« Reply #8 on: May 22, 2005, 04:47:01 pm »
lol... I was talking about the BEARINGS not the ROLLERS ::)
NJDevils2006
  • Last login:September 14, 2006, 08:20:32 pm
  • proof the Mark Messier likes boys!
Re: Trackball Help!
« Reply #10 on: May 22, 2005, 08:39:40 pm »
new bearings are the way to go, i tried several cleaning techniques, and ended up buying new bearings anyway.
At least the fans go to hockey games "for the love of the game"........to bad the players don't!
jrj8541
Re: Trackball Help!
« Reply #11 on: May 23, 2005, 01:48:32 pm »
Alright, ordered the parts from therealbobroberts today.  Thanks for all the advice folks!
I tried the 3 in 1 oil and it spins better, but still not what I am looking for.   The bearings are just nasty.
Thanks again!
RayB
  • There's my post
    • RayB.com
Re: Trackball Help!
« Reply #12 on: May 24, 2005, 02:20:30 pm »
DOH!!!!!!
NO MORE!!
