Author Topic: Cab Storage in a Conservatory  (Read 3048 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
« on: May 18, 2005, 01:19:13 pm »
I have been offered opportunity to store my new Centipede project at a friends house for a month or so (because not feasible to store it at my flat - too heavy to carry up the stairs). It is to be put into their conservatory. They said that it might get bit hot in there.
http://forum.arcadecontrols.com/index.php/topic,36900.0.html
Bearing in mind that we are in the UK and its not exactly tropical at the moment....
would storage in a conservatory and potential temperature affect the cab?
i figured everything should be ok except potential sun damage to the sideart. i planned to cover it with a dust sheet to protect it.
any other potential problems i should consider?
PS - not sure if called same thing in US so posted picture of a conservatory ;)
« Last Edit: May 18, 2005, 04:52:00 pm by rchadd »
Stingray
Re: Cab Storage in a Conservatory
« Reply #1 on: May 18, 2005, 02:48:57 pm »
As you said, I doubt it will get hot enough in the UK to worry about it.
-S
Flinkly
« Reply #2 on: May 18, 2005, 03:58:47 pm »
i'd get a really opaque sheet to cover it if you care abuot the sideart.  i'd also worry a bit about any sort of temperature, but like stingray said, it probably will be fine.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #3 on: May 18, 2005, 09:51:54 pm »
In parts of Canada we call it a solarium, or sunroom.
Use a dark and thick covering, as mentioned. Keep in mind that sunlight/UV light goes THROUGH cloth.
NO MORE!!
crashwg
« Reply #4 on: May 19, 2005, 07:41:10 am »
Lather it up with a thick coat of spf 50!  8)
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
AlanS17
    • AlanS17
« Reply #5 on: May 19, 2005, 02:22:26 pm »
A blanket will shield it from the vast majority of heat as well as UV radiation. After after all, it won't generate its own heat if it's not turned on. A blanket will act as a good insulator. You really ought not to have any problems.
Of course, I'm not claiming responsibility if something DOES happen.  :)
Redseven80
  • Last login:December 18, 2005, 01:57:13 am
  • New Zealand
« Reply #6 on: May 23, 2005, 02:15:42 am »
Watch out for thieves or vandals dude, might attract unwanted attention.
rchadd
  • Made in Cornwall
« Reply #7 on: May 23, 2005, 06:02:50 am »
turns out they're letting me keep it in corner of their kitchen :)
thats what you call good friends!
priority now is to get it up and running - so at least they can play it whilst i am in process of finishing it off...
ethous
  • Last login:June 11, 2025, 09:33:36 am
  • Life is prescious enjoy every minute
« Reply #8 on: May 27, 2005, 08:31:39 am »
Wow Thats Very nice of them :D
