Author Topic: Marquee Help  (Read 3470 times)
Bren
  • Newbie
  • Last login:November 30, 2002, 02:50:04 pm
  • Blah?
Marquee Help
« on: November 30, 2002, 02:55:10 pm »
Hey All!
It's great when you have a long weekend to work on your cabinet!  In any case, the wiring is done and I was moving back to the Marquee design.  I have two pieces of Plexiglass to use that I was going to sandwich the design to make the marque, but I have no idea how to attach it to the cabinet.  I don't see any groves or holes that would lead me to believe that it was mounting in that fashion.  Plus, I would like to be able to remove the marque to get to the light (which will be installed later) or the speakers.  My question to all of you, is how do normal cabinets connect the marque or some examples that show how it is done...
Thanks a bunch
-Bren
liche
  • Last login:November 13, 2007, 08:05:18 am
  • This is my BOOMSTICK!
Re:Marquee Help
« Reply #1 on: November 30, 2002, 06:46:49 pm »
Usually, there is a horizontal groove on the top section of the cabinet where the marquee simply presses into.  On the bottom, there is usually a bracket which holds the marquee up into this groove.
StingMe
  • Last login:December 18, 2002, 02:30:38 pm
  • * Ouch! *
Happ Marquee Retainer
« Reply #2 on: November 30, 2002, 08:36:20 pm »
The main Happ page seems to be messed up right now, but here's the item page:
http://www.happcontrols.com/amusement/acesor/49100000.htm
About $1/ft - this stuff gives a nice finished look. Since it comes in 10 foot lengths, I was able to use it for the marquee and for the monitor bezel/glass as well.
You can always make your own "frame" of sorts or screw the plexi sandwich right to the cab.
Good Luck!
SNAAAKE
  • -Banned-
Re:Marquee Help
« Reply #3 on: December 01, 2002, 02:11:54 am »
buy marque retainer from happs...nothing beats that look...you can just use very small scres the screw it to the wood piece then install retainers and that will hide the screws...think again..avoid cheap shot of makin your own..wont look right and I know it.
bcard74
  • Last login:August 24, 2007, 11:46:24 pm
Re:Marquee Help
« Reply #4 on: December 01, 2002, 10:46:17 am »
Hey All!
Thanks a bunch
-Bren
On my bartop I just used 2 L brackets, and put velcro on each of them.  Other piece of velcro on the marquee and there you go.  To keep the light from leaking, I used some 3/4 inch black window sealing foam adhesive around the perimeter and it works quite will.  It is a good 5 dollar idea, but if you are going all out, I would suggest going with some of the other ideas for the best look.
Chris
    • Chris's MAME Cabinet
Re:Marquee Help
« Reply #5 on: December 01, 2002, 12:38:07 pm »
I just used a piece of plastic corner moulding from Home Depot.  It came in white, so I spray-painted it gloss black. It was about $3.00 for an 8 foot length.
--Chris
--Chris
elfman12
  • Last login:November 20, 2010, 09:23:38 pm
  • FOTR, TTT, ROTK
Re:Happ Marquee Retainer
« Reply #6 on: December 01, 2002, 04:03:06 pm »
Good Luck!
BTW, how do you mount that Happs retainer material? I have some, but I can't find any instruction of how it's supposed to be intalled. Actually, it looks like there are a couple of different ways that would work.
In the orchard, drenched in blue light, she changes your bandages and soothes you.
StingMe
  • * Ouch! *
Installing Happ Marquee Retainer
« Reply #7 on: December 01, 2002, 06:23:47 pm »
It's really simple but not all that obvious...the retainer hooks over the edge of the MDF, particle board, etc. and pulls the marquee up against that edge. Make sense? So the top retainer would look like this:
At least that's the way I did it...hope this helps!  ;D
elfman12
  • FOTR, TTT, ROTK
Re:Installing Happ Marquee Retainer
« Reply #8 on: December 01, 2002, 06:47:26 pm »
Hey, that's great, very clear! I just thought that the little ridge on the top of tat piece was meant to snug against the board to keep it from moving, but the only way to do that would be to put it on the inside of the MDF, and would loose display area.
Thanks again!
isugoat
  • Last login:March 15, 2004, 10:46:51 pm
Re:Marquee Help
« Reply #9 on: December 01, 2002, 07:14:00 pm »
--Chris
what kind of molding do you have on the edges?  i like that leathery texture...
Chris
Re:Marquee Help
« Reply #10 on: December 01, 2002, 07:24:58 pm »
That's the T-Molding that was already on the cabinet.  It's 7/8" black leather texture.  You can find it at T-molding.com at http://www.t-molding.com/cart/customer/home.php?cat=24 .
--Chris
--Chris
rcrules
  • Last login:February 28, 2026, 10:30:00 am
Re: Marquee Help
« Reply #11 on: September 12, 2006, 12:41:51 pm »
Does anyone know the height and width of the Happ's marquee retainer (the red and yellow dimensions - I mean)?
Thanks!!
« Last Edit: September 12, 2006, 12:47:19 pm by rcrules »
