Author Topic: Coin Comparitors, Doors, & Mechanisms  (Read 6183 times)
Ler6557
  • Last login:May 07, 2006, 08:47:22 pm
« on: April 13, 2005, 09:29:45 pm »
Hi. I wanted to know what the difference is between a coin comparitor, door, and mechanism and which ones I need to make my machine's coin slot functional. The second thing I wanted to know concerning the coin door is how I can replace the coin return buttons. I want to replace them with different colors which I would also like to know where I can find. Thanks a lot.
« Last Edit: April 13, 2005, 11:13:22 pm by Ler6557 »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Coin Comparitors, Doors, & Mechanisms
« Reply #1 on: April 13, 2005, 09:40:57 pm »
Hi. I wanted to know what the difference is between a coin comparitor, door, and mechanism and which ones I need to have a fully functional coin accepting arcade.
Well, you'll need a door that's large enough for people to walk in. Businesses usually have those double glass doors. That's so that you can also wheel in large equipment you need to run a business. In your case, to run an arcade, you'll need these double doors to be large enough so you can bring all your game machines in.
So next thing you'll need is at least one guy to take people's money and give them coins to play the games with. You can usually get away with minimum wage for this person, though be careful, they might steal from you. You could always install token dispensors too.
~Ray B.
NO MORE!!
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #2 on: April 14, 2005, 10:02:00 am »
The humor and intellect that abounds from the members of this forum will always serve to amuse me and allow me to rest assured that I will never be alone in this ever crazy world we live in.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 14, 2005, 11:31:01 am »
A "coin comparitor" is an electronic coin mech that electronically compares a sample coin (in a holder) to all coins passing by it's sensors. Coins matching the properties of the sample are allowed through and a credit signal issued to the game or vending controller board. Coins inserted that do not match the sample are immediately rejected and sent to the coin return hole. Coin Comparitors require power to operate (usually 12 volts DC, but requirements vary from manufacturer to manufacturer and/or model to model). When no power is applied to the comparitor all inserted coins are rejected. Comparitors are manufactured in two styles: one style is the familiar 3.5" by 5" found in most game doors. The other style is called "roll down" and is similar to what you see on a Donkey Kong (Nintendo) cabinet. Coin Controls, Coinco, National Rejectors, Coin Mech, Mars, Lucky Sunshine, and Asahi Seiko all make coin comparitors. By the way, coin comparitors are much more secure than mechanical coin mechanisms which is why many casinos use them on slot machines. Mechanical coin mechanisms must be kept level to operate correctly, but coin comparitors don't generally need to be level to work.
A "coin door" is the door, frame, reject buttons, coin entry, and coin mechanisms & switches all mounted to an access door installed on a cabinet. Not all coin mechanisms or parts are interchangeable between coin door manufacturers. Coin return buttons are generally NOT interchangeable between different manufacturers.
A "coin mechanism" is the mechanical or electronic unit that sorts/accepts/rejects coins. These may be of the usual 3.5" by 5" game variety that are held to the door by a frame or bracket or the "roll down" variety that bolt directly to a door or wood cutout. Us older industry guys like me refer to coin mechanisms as "coin chutes" and the terms are interchangeable. Mechanical coin mechs generally only accept one denomination and they must be kept level in order to function properly. As they get used they build up dirt/gunk inside them and require cleaning and/or adjustment. In Japan, a coin mechanism is called a "coin selector".
« Last Edit: April 14, 2005, 12:43:31 pm by Ken Layton »
Ken Layton
  • Guru
  • Technician
« Reply #4 on: April 14, 2005, 11:39:13 am »
Attached is an example of a "roll down" style mechanical coin mechanism. In this example it's an Asahi Seiko brand and it's model 740A.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #5 on: April 14, 2005, 11:42:02 am »
Well done, Ken.  Thank you for the information.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: April 14, 2005, 11:53:13 am »
Attached is an example of a coin comparitor. In this example it's a Coin Mechanisms, Inc. model CC20. Notice the quarter in the sample coin holder. By sliding the retainer back you can insert a different sample coin (like say a token) and then that's all it will accept.
« Last Edit: April 14, 2005, 12:04:51 pm by Ken Layton »
Ken Layton
  • Guru
  • Technician
« Reply #7 on: April 14, 2005, 11:56:15 am »
Attached is an example of regular game style (3.5"x5") mechanical coin mechs. In this example it's the Coin Mechanisms, Inc. model 100 series (all metal construction).
Ken Layton
  • Guru
  • Technician
« Reply #8 on: April 14, 2005, 12:02:39 pm »
Attached is an example of an electronic "roll down" style coin comparitor. In this example it's a Lucky Sunshine brand and it's their model # HI-06CS. It operates on 12 volts DC. Fortunately electronic coin comparing roll down mechs and their mechanical counterparts are standardized between brands AND models. Bolt hole spacing/mounting cutout make this directly interchangeable with mechanical roll down mechanisms like the Asahi Seiko 740A in the above post.
« Last Edit: April 14, 2005, 12:09:22 pm by Ken Layton »
gabypotter
  • Last login:December 28, 2024, 12:36:33 am
  • I want to finish my Jukebox!!!
« Reply #9 on: February 14, 2006, 07:29:54 pm »
did you know how can i install this coin mech on my cpu?
this one has 5 cables, 2 gray 1 white, 1 red, and 1black,
but i have no idea how to install this... can you help me please!!!
Ken Layton
  • Guru
  • Technician
« Reply #10 on: February 14, 2006, 07:58:45 pm »
For that one you'll need to contact the manufacturer to get the connector pinouts.
