Author Topic: X-Arcade BYO Kits now include USB adapter!  (Read 3503 times)
MiahXGaming
  • Last login:May 26, 2016, 02:42:21 pm
  • Legend
    • X-Arcade
BobA
  • What Me Worry?
Re: X-Arcade BYO Kits now include USB adapter!
« Reply #1 on: April 05, 2005, 07:50:39 pm »
I checked the BYO Kit page and could not see where the USB adapter is included.   Did I miss it?  It is still listed as a $29.95 adapter.  They say they include a USB connector but there is no evidence of one on their interface board as it has only the serial connector and the PS/2 pass thru.  They actually conect the USB adapter to their serial port.
Please point me in the right direction if I missed it.
BobA
mahuti
« Reply #2 on: April 05, 2005, 08:02:32 pm »
I saw it written on the page. Its in BOLD under the "what's included" heading on that link above. $59.95 total for the package. Follow the link.
BobA
  • What Me Worry?
« Reply #3 on: April 05, 2005, 08:36:33 pm »
The bold under what is included says USB connector.
« Last Edit: April 05, 2005, 08:47:11 pm by BobA »
MiahXGaming
  • Legend
    • X-Arcade
« Reply #4 on: April 06, 2005, 09:41:48 am »
It includes the USB adapter, it says so right under the "Add to Cart" button: "Includes USB & PS/2 Connector!".
millercentral
  • Last login:March 07, 2024, 04:38:47 pm
« Reply #5 on: April 06, 2005, 11:26:24 am »
Is the USB adapter a custom designed part, or are you OEMing a IPac/GPWiz/etc?
What are the details of the encoder? (number of inputs?, shift button?, poll speed? method of attaching wires to the encoder? etc)
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: April 06, 2005, 11:50:49 am »
Custom designed by X-arcade, AFAIK, Ultimarc and GGG ARE the OEM's for all their encoders, AKAIK.
http://www.mameworld.net/tigerheli/encoder/
28 inputs, 4 codesets, no shiftbutton, poll speed (generally unknown for any encoder), pin header.
Biggest advantage is the ability to use different adapters to hook it up to console systems.
MiahXGaming
  • Legend
    • X-Arcade
« Reply #7 on: April 06, 2005, 01:17:26 pm »
XGaming been using their own USB adapters built for the X-Arcade's for a long time now. Now they are simply including it for free.
Toonces
  • Last login:March 04, 2024, 11:25:24 pm
« Reply #8 on: April 06, 2005, 01:21:20 pm »
Any chance XGaming might sell just the wiring harness? Mine had an accident at one of the connectors so I ended up having to cut it out and replacing it with an IPAC cause I couldn't find the little connectors. Sure would be nice to put the old encoder back to work :)
Toonces
Tiger-Heli
    • Tiger-Heli
« Reply #9 on: April 06, 2005, 01:28:08 pm »
Toonces
Try E-mailing their customer support.
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #10 on: April 06, 2005, 04:25:53 pm »
I wanted to add a joystick to my single player unit so I called and asked to buy the wiring harness.  They FLAT OUT REFUSED to sell me one.  Then they didn't e-mail me the return authorization I asked for so I could return my single player unit.
I don't see the rationale for refusing to sell me a wiring harness.  They obviously sell them bundled with the encoder.  I already had the encoder, I just needed the wiring harness.  Their attitude (and lying to me about how they would e-mail me a return authorization) led to me purchasing an Ipac4 and a GP-WIZ and vowing to never buy another X-Arcade product.
BobA
  • What Me Worry?
« Reply #11 on: April 06, 2005, 06:52:06 pm »
My bad eye sight or understanding.
X Arcade BYO Kits do include the adapter as confirmed by X Arcade.
« Last Edit: April 06, 2005, 07:01:34 pm by BobA »
Tiger-Heli
    • Tiger-Heli
« Reply #12 on: April 07, 2005, 08:05:28 am »
Good info miahxgaming I assume you work for X Arcade or they monitor this board closely as now the Included info does specify that it connects to PS/2 and USB instead of just saying USB connector.
Or maybe they read your E-mail!
BobA
  • What Me Worry?
« Reply #13 on: April 07, 2005, 09:10:05 am »
Good point Tiger-Heli   :)
logik
  • Last login:July 02, 2012, 03:10:23 pm
« Reply #14 on: April 12, 2005, 02:31:01 pm »
markrvp
  • NFL Expert
« Reply #15 on: April 12, 2005, 02:33:07 pm »
When you find out, please let me know.  I have "guessed" what connector it is twice and ordered from MOUSER.  Now I have two sets of incorrect size Molex connectors.
logik
« Reply #16 on: April 15, 2005, 11:14:33 pm »
I found a few more "options" to try from the new jameco catalog I just got. http://www.jameco.comMay order some in a few weeks and try them out.
markrvp
  • NFL Expert
« Reply #17 on: April 15, 2005, 11:22:28 pm »
The last ones I got were Molex P/N 22-01-2057  These are described as .100 K. K. Connectors.  The .100 pin spacing is correct, however these connectors are just a little too "fat" to fit in the female header.
Their was an alternate version of this connector that has "locking tabs" which might actually be the correct one.  I just lost the heart to keep blindly buying connectors for a P.O.S. encoder.
Having said that, I am still going to use it if you can find the right connector, so GOOD LUCK!
