Author Topic: Lexan Cutting? CPO protection  (Read 2159 times)
Taborious
  • Last login:December 29, 2011, 04:55:45 pm
  • Win or go Home!
    • The Way Back Machine
« on: March 09, 2005, 09:24:52 am »
Getting ready to start constructing my CP. I have the wood and the Lexan but I was wondering what is the best way to cut the Lexan? I was going to sandwich it between 2 peices of MDF but I'm wondering is a circular saw my best bet and any suggestion on teeth count for the blade? Do I need to lubricate???
The Way Back Machine - http://www.taborious.com
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
Re: Lexan Cutting? CPO protection
« Reply #1 on: March 09, 2005, 09:31:07 am »
They make a circular saw blade specific for plexi/lexan, can't remember the brand.  Might be able to use other blades too, probably the higher number of teeth the better.
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #2 on: March 09, 2005, 12:48:40 pm »
I cut it on a table saw with a 60 tooth blade if I am using a "circular Saw" IMHO the best way to cut it is with a router and a pattern bit.
rdagger
« Reply #3 on: March 09, 2005, 01:31:23 pm »
The easiest way to make straight cuts in Lexan is to use a utility knife.
Taborious
  • Win or go Home!
« Reply #4 on: March 09, 2005, 01:39:16 pm »
Is there a specific type router bit I should be looking for?
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #5 on: March 09, 2005, 02:25:43 pm »
I used a flush trimming bit.  See here..
DreamWeb
  • Last login:July 25, 2020, 08:36:59 pm
« Reply #6 on: March 09, 2005, 02:37:25 pm »
What about for the rounded edges of lexan/plexi?  Would you just sand it down (is this possible?  I've never worked with it before)
Thanks guys.
walls83
  • beer is good
« Reply #7 on: March 09, 2005, 03:05:17 pm »
sanding will leave scratchs.  A diff. router bit will round the edges.
Taborious
  • Win or go Home!
« Reply #8 on: March 09, 2005, 03:29:06 pm »
I'll give the razor knife and router bit a shot, I'll post pics after the fact.
I've worked with MDF before but I have just cut it with the blade that came with the saw. Does anyone know what the best teeth count blade is for cutting MDF. Mine is probably about 34 (7 1/4)
nostrebor
  • SHOCKING!!
« Reply #9 on: March 09, 2005, 04:17:51 pm »
Mdf will cut fine with that tooth count. It (MDF) is hard on blades ao carbide tipped blades are best. For smooth cuts use a "saw board" as a guide wherever you can.
Also use dust masks when cutting MDF. It is nasty stuff, will make lots of fine dust, and is very irritating to the eyes nose and throat.
Dave.
Edit: added saw board linkage below.
http://www.benchnotes.com/Skillsaw%20Guide/skillsaw_cutting_guide_boa.htm
« Last Edit: March 09, 2005, 04:19:58 pm by nostrebor »
GGKoul
  • Cheesecake Apprentice
« Reply #10 on: March 09, 2005, 04:23:51 pm »
If you do use a Knife to cut the Lexan.. take your time and remember to always scrap on the same spot... as you can easily side off the line and make another scratch line in the lexan.
rosborn
  • Last login:November 08, 2021, 04:49:42 pm
  • rosborn
    • MAME Play-Choice
« Reply #11 on: March 09, 2005, 04:47:15 pm »
I second Sasquatch on the use of the flush-trimming bit for this.
rosborn
markrvp
  • Last login:April 13, 2026, 04:51:46 pm
  • NFL Expert
« Reply #12 on: March 09, 2005, 05:16:53 pm »
For my control panel I rough cut the Lexan with a Band Saw and then screwed it to the CP top which had already been drilled for Joystick and Button Holes.  I used a 3/8" laminate router bit to make a perfect cut around the edge.  I then drilled 3/8" pilot holes through the Lexan (where the button and Joystick holes were) and ran the router bit through these for perfect holes in the Lexan.  See image below.
For smooth cuts in MDF and particle board, use a blade with as many teeth as possible.  Same principle as wood cross cuts.  There is less tear.  This Freud blade is the best in my opinion.  It is expensive, so if you won't need a saw blade after this project, you can get a cheaper knockoff.
DreamWeb
« Reply #13 on: March 09, 2005, 05:26:42 pm »
Does all of this also apply to Plexiglass?  I know they're not quite same thing..  I was just wondering if plexi and lexan were pretty much interchangeable around these parts.
d.
nostrebor
  • SHOCKING!!
« Reply #14 on: March 09, 2005, 05:40:04 pm »
d.
Yes.
rdagger
« Reply #15 on: March 09, 2005, 06:50:11 pm »
