Author Topic: Are Trackballs supposed to jump?  (Read 2780 times)
Hoagie_one
  • Um....whats a cabinet
« on: March 08, 2005, 05:53:35 pm »
bought a used trackball off ebay and its a little dusty but looks good, rolls good.  Granted I havent took it apart yet.  But when I give it a thumb snap (Snap teh ball fast), it jumps up a little.  I gotta think that any jump means it's not rolling and thus not sending a signal.  Is this normal or do i have to replace some rollers ofr somthing?
Its a 3" imperial BTW
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
Re: Are Trackballs supposed to jump?
« Reply #1 on: March 08, 2005, 06:03:14 pm »
Backspin maybe?  I dont have a trackball, but lots of people have these problems due to sensitivity.
paigeoliver
  • Awesome face!
« Reply #2 on: March 08, 2005, 06:04:15 pm »
It probably has dirt or something built up on the rollers.
Hoagie_one
« Reply #3 on: March 08, 2005, 06:14:54 pm »
let me rephrase my question.  Am I supposed to be able to lift the ball off the rollers slightly?
IMMark
  • Last login:August 05, 2016, 07:30:02 pm
« Reply #4 on: March 08, 2005, 06:30:03 pm »
mine does not lift up at all.
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #5 on: March 08, 2005, 07:15:28 pm »
I've got a new Happ 3".
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #6 on: March 08, 2005, 07:28:57 pm »
My Imperial had this problem also.
Mine had some thin washers in between the two halves as some sort of shim.  I removed them and the "Jumping" problem went away.
American Laser Games Wrapper
O2em Rom Utility
coasternuts
  • Last login:January 11, 2010, 08:39:24 pm
  • Ouuuuch....I am not the worst game ever!!
« Reply #7 on: March 08, 2005, 11:08:01 pm »
I have an Ultimarc 2 1/4" that does this.  I would say for Golden Tee this is not good.  It feels like a loose fit between the ball and case.
But, from browsing the forums, it supposed to get better the more it's used.  Time will tell I guess.
Hoagie_one
« Reply #8 on: March 08, 2005, 11:25:19 pm »
its better when i keep it flat.  I'll know for sure when I mount it
Lilwolf
« Reply #9 on: March 09, 2005, 08:32:25 am »
Mine does this and I was a little annoyed... got new rollers hoping it would fix it (mine was used on ebay).
But in games, I ahven't noticed any problem yet.  but I dont play many spin it super hard games...
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #10 on: March 09, 2005, 09:37:26 am »
Maybe the bearings aren't quite as "free" as they should be...
Soak them in AeroKroil. Lube them with 3 in 1. Spin them with a drill.
heh.
Also check the springs underneath the bearings. (I dunno if yours has those, but in a Wico there are small springs). THese springs help keep the ball as close to the opening as possible, without it really rubbing against it. If those springs are compacted, then your gap will be a bit bigger than it should be, allowing the ball to jump up.
NO MORE!!
Stingray
« Reply #11 on: March 09, 2005, 09:42:39 am »
I have the same trackball that you have and mine does not do what you describe.
-S
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #12 on: March 09, 2005, 01:27:04 pm »
I suggest looking into getting new rollers and bearings.  My happs did that for abit until I replaced the rollers and bearings.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #13 on: March 09, 2005, 05:09:14 pm »
I agree, the most likely problems are not good bearings, and worn rollers.  Open up the case (four screws on bottom) and take a look.
TheRealBobRoberts bearings how-to
TheRealBobRoberts trackball basics (including pics of good and bad rollers)
Bob has replacement bearings and rollers for betsons, which are different from happs.
Robin
Knowledge is Power
