Author Topic: Act-labs light guns question  (Read 2271 times)
vibez
  • Last login:February 09, 2011, 08:33:20 am
« on: February 25, 2005, 07:51:52 am »
HI,
I have a hantarax standard 15hz arcade monitor using a j-pac & aracdevga 9200 card running xp.
Will the tv lightguns from act-labs work with this setup?
Here is the link to the guns http://www.act-labs.com/scripts/proddetails.asp?pid=132
EDIT: damn, they are discontinued. Is there another source apart from ebay?
« Last Edit: February 25, 2005, 07:56:06 am by vibez »
Lilwolf
Re: Act-labs light guns question
« Reply #1 on: February 25, 2005, 09:16:05 am »
nope... and ebay auctions are going for 150+ in some cases.  They really aren't worth that much.  They are the best out there right now... but not nearly perfect.  I would wait and hope for a better solution (thats less then 150 bucks)
vibez
« Reply #2 on: February 25, 2005, 10:21:29 am »
shame. Guess I'll just have to wait it out
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #3 on: February 25, 2005, 11:16:26 am »
Some of us have been waiting longer than others......
Signature tags are dumb.
woodywood
  • Last login:February 19, 2006, 11:03:11 am
« Reply #4 on: February 25, 2005, 09:51:13 pm »
This is so strange. I have been reading that these are discontinued but when I went to the website and ordered them I got them in less than 1 week wait time. I don't know. Maybe I was lucky but I did get 2 light guns (TV version) in less than a week.
ErikRuud
  • Last login:March 23, 2026, 07:42:27 pm
« Reply #5 on: February 25, 2005, 10:50:03 pm »
The TV version is still available.
The  VGA version is discontinued!
American Laser Games Wrapper
O2em Rom Utility
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #6 on: February 25, 2005, 11:14:58 pm »
They are listing the tv version as discontinued also.
Later,
dabone
armax
  • Last login:July 12, 2017, 07:20:15 pm
  • Game Not Over
« Reply #7 on: February 25, 2005, 11:48:34 pm »
hmmm...no they're not.  They're listing the tv version as available and the PC version as discontinued...
Lilwolf
« Reply #8 on: February 25, 2005, 11:54:54 pm »
when the tv version is out of stock its discontinued...
dabone
  • Time to work...
« Reply #9 on: February 26, 2005, 08:30:28 am »
Just click on add to cart and see what the TV version says then,...
Sad day.
I've got 2 of the VGA versions, and they see quite a bit of use, I'll probally need replacements within a year but still no options for me yet.
I like the idea of the camera gun, but I'm concerned how to intergrate it into a cab without the camera sticking out like a sore thumb.
Later,
dabone
vibez
« Reply #10 on: February 26, 2005, 12:25:46 pm »
i guess the tv version wont work with 15hz arcade monitors
M3talhead
« Reply #11 on: February 26, 2005, 12:29:39 pm »
Sad day.
Later,
dabone
If you had smoked glass, you might be able to hide it in an upper corner without anyone noticing. (This is assuming that the infrared will pass throught the tint)
vibez
« Reply #12 on: February 26, 2005, 12:32:03 pm »
erm, wont the interface matter? my mame cab only has a vga input [aracade vga)
1UP
  • Token Junkie
    • 1UPArcade
« Reply #13 on: February 26, 2005, 09:09:51 pm »
If you're going to spend $150, you might as well get this:
http://www.r0r3.com/productsusbopticalgun.htm
Anyone used it?
My other job...
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #14 on: February 26, 2005, 09:16:50 pm »
That ror3 interface keeps coming up, but nobody ever takes the plunge.  I think Kev tried to get one for review, but no dice there.
How 'bout it, 1UP, wanna be our guniea pig?
DaemonCollector
  • Last login:December 26, 2009, 07:02:16 pm
  • All your base are belong to us.
« Reply #15 on: February 26, 2005, 09:26:57 pm »
I thought in one of these posts about the ror3 someone contacted the supplier and they are made to work with the PS2 and have no current driver for the PC, but should be technicaly easy to write one. But I may be completely off, so in that case, you can ignore me :)
1UP
  • Token Junkie
    • 1UPArcade
« Reply #16 on: February 26, 2005, 09:29:04 pm »
R0R3 USB Optical Light Gun Interface Board (ULGI)
$159.95
R0R3 Introduces the industries first USB Optical Gun Interface Board for the PCArcade and Location Based Gaming and Amusement Market. This is another first, a fully HID USB compliant optical gun interface board that will allow a first person shooter to be built around a WINDOWS or LINUX USB compliant PC. The optical gun board will work in conjunction with the UGCI and will allow a complete Optical Gun system supporting two optical gun inputs can be built for less than a few hundred dollars.
Key Benefits
SVGA Compatible from 640x480@ 60 Hz to 1024x768 @ 100Hz
Patented ScreenFlash Technology, no blank screen rendering required
Resolves less than one Pixel at 640x480
Supports up to two guns
Pin for Pin Compatible with the Happ Optical Gun Product Line
Uses high resolution ASIC technology for low cost/component count
WINDOWS 98/ME Compatible
Sounds to ME like it works in Windows...
BTW, I will probably be getting one, but I'm waiting to hear back from them whether "supports up to two guns" means that I have to buy two boards...
« Last Edit: February 26, 2005, 09:30:53 pm by 1UP »
My other job...
Tommy Boy
  • Last login:April 13, 2010, 04:13:56 am
« Reply #17 on: February 26, 2005, 09:54:02 pm »
I think the problem was that the guns' windows driver does not emulate a mouse and therefore there needs to be a MAME code modification to read the input...IIRC from earlier threads on this topic.
Tommy Boy
« Reply #18 on: February 26, 2005, 10:34:24 pm »
vibez
« Reply #19 on: February 27, 2005, 11:50:25 am »
back to my original question. using an aracde monitor & aracdevga card, do I want the tv or the crt  version?
Nevermind, found the answer on the website's faq
« Last Edit: February 27, 2005, 11:54:41 am by vibez »
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #20 on: February 28, 2005, 04:31:07 am »
Do post if you hear back from them about the 2 player issue. I get the impression its 1 board, but you never can trust marketing speak!
No one seems to have tried these.
"Resolves less than one Pixel at 640x480" sounds like a bold claim to me. Of course "resolving" to 1 pixel can be done in a driver - it may not mean that it is a direct reflection on accuracy...
