Author Topic: MAME Steering Wheel Interface Question  (Read 4899 times)
ponyboy32
  • Last login:February 04, 2010, 01:28:01 pm
« on: February 20, 2005, 04:06:22 am »
I am in the process of building my first MAME cabinet and I would like to incorporate a detachable steering wheel to the control panel.  If I got a PC USB steering wheel and pedals could I plug that into the PC USB port and configure it through windows/MAME or would I still need to use an encoder card? I was thinking I attach a 4-port USB hub to the control panel and then plug the steering wheel or even USB gamepad into that if they can be used by MAME.  Thanks in advance.
Tailgunner
Re: MAME Steering Wheel Interface Question
« Reply #1 on: February 20, 2005, 05:41:41 am »
A USB based PC wheel would plug in directly to the computer or hub. If you were using a wheel from a Pole Position cab, you'd need the encoder or a mouse hack.
I would point out that PC wheels are usually 270 degree wheels, where the majority of arcade wheels are 360 degree wheels.
ponyboy32
« Reply #2 on: February 20, 2005, 01:54:32 pm »
Thanks for the response. That clears things up a little for me. Another question, are there any PC USB wheels that can be used as both 360 and 270 degree wheels by flipping a switch or something?
Gunstar Hero
  • Last login:September 28, 2014, 01:51:17 am
  • Back in action!
« Reply #3 on: February 20, 2005, 02:14:15 pm »
Nope.  :P
The only home use 360 wheel I've ever seen was for the Colecovision.
ponyboy32
« Reply #4 on: February 20, 2005, 02:21:32 pm »
Ok thanks. Is there a list of driving games and what type of wheel they use anywhere? I would to just implement the 260 degree wheel but if all the games that I want to play use the 360 degree wheel then I may do both. Thanks for the info guys.
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: February 20, 2005, 02:34:03 pm »
Well, the closest you are going to get to know which games use what controls is this:
Note this is not complete, however it does contain almost everything that has resource.  I will be trying to update the site to the currect version of mame soon.
http://fe.donkeyfly.com/controls/gamesbycontrol.php
There's a control type thread in everything else I think.  I know one was started but I don't remember exactly where.  Check the stickies in each forum.
Chris
    • Chris's MAME Cabinet
--Chris
JODY
  • Last login:June 08, 2025, 11:26:01 pm
  • After a long delay...the arcade is underway!
« Reply #7 on: February 20, 2005, 10:59:50 pm »
Did it velcro to the center of the wheel so when you turned the wheel it turned the mouse ball?
quarterback
« Reply #8 on: February 20, 2005, 11:02:07 pm »
Don't some people clamp steering wheels to their spinners?
-- Chad Tower
Chris
« Reply #9 on: February 20, 2005, 11:03:19 pm »
Yes.  With the tail pointing toward you, if I remember right.
--Chris
JODY
« Reply #10 on: February 20, 2005, 11:05:21 pm »
Had heard of that, but I'd be afraid it would bend my spinner's shaft or something.
Tailgunner
« Reply #11 on: February 20, 2005, 11:25:51 pm »
Arcade spinners typically use a 1/4" shaft, 360 degree arcade wheels typically use a 3/4" shaft.
« Reply #12 on: February 21, 2005, 04:56:23 am »
I think it's more 50/50, maybe with ~270deg wheel games overtaking in recent MAME versions.
NoOne=NBA=
« Reply #13 on: February 21, 2005, 06:48:04 pm »
The general trend is that there are more MULTI-player driving games in the 360 lineup, and more SINGLE player games in the 270 lineup.
For a single player only cab, you can go with whichever best supports the games YOU want to play.
For multi-player, I'd definitely go 360 though.
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #14 on: February 22, 2005, 08:44:11 am »
This places does
quarterback
« Reply #15 on: February 22, 2005, 11:16:47 am »
This places does
I knew I'd see it somewhere before.  I'd have the same concerns expressed by others: that the spinner wouldn't take it and I'd bend it all out of whack
-- Chad Tower
