Main > Main Forum
t-moulding
<< < (2/2)
TalkingOctopus:
--- Quote from: FractalWalk on February 11, 2005, 03:39:33 pm ---Am I the only one that used 3/32". That worked perfectly for me. It holds tight but still lets me remove it without taking a pound of MDF with it.
Anything smaller than 7/64" should work fine.
sodapopinski:
 I'm a carpenter and I was explaining my problem of the wrong slot cutter size at work when I noticed that there was t-moulding right in front of me. Its commonly used between lino and carpet. The moulding is nearly identical to the arcade machine moulding. I assume its cheap plus the moulding clearly is designed for 1/8". I plan on looking further into this because it would be a hell of alot more convenient. I've checked everywhere for a 1/16" slot cutter here in Edmonton, Alberta and nothing. Has anyone used this alternative?
FractalWalk:
--- Quote from: TalkingOctopus on February 11, 2005, 04:13:11 pm ---I don't plan on removing it.
sodapopinski:
What about 1/8" and some really good adhesive or epoxy?
TalkingOctopus:
--- Quote from: sodapopinski on February 11, 2005, 06:22:28 pm ---What about 1/8" and some really good adhesive or epoxy?
Sure that could work but I'd really recommend doing it the "right" way if possible.  You can use hot glue w/ an 1/8" slot.  You need an adhesive that dries quickly because tmolding does not stay in place.  You could also use small nails to pound it in or to keep it in place while the adhesive is drying.
Navigation
[0] Message Index
[*] Previous page
Go to full version
