Author Topic: Question on trackball hole size  (Read 4721 times)
Heinekenator
  • Last login:April 04, 2005, 10:16:01 am
« on: January 27, 2005, 12:54:45 pm »
Hello.
I'm building my first control panel, and I have a question about the hole size for a trackball.
The top of the CP is 3/4" MDF, with a sheet of 0.193" thick GE Crystallite (lexan?) on top. I bought a 3" Happs trackball. I plan to route the top of the MDF out to flushmount the trackball mounting plate. My problem is that I don't know what size hole to drill through the lexan to accommodate the ball.  Any insight?
Thanks in advance. I'm new to this hobby and am loving it.  ;D
-Greg
Stingray
Re: Question on trackball hole size
« Reply #1 on: January 27, 2005, 01:15:41 pm »
I don't use Lexan on my CPs so maybe I'm missing something. You'd just cut the hole in the Lexan the same size as the hole in the mounting plate wouldn't you?
-S
brained
  • Last login:April 10, 2026, 03:46:03 pm
  • Raised by Atari
    • Nux
« Reply #2 on: January 27, 2005, 02:48:13 pm »
Well if you got a 3" trackball, get a 3" hole saw.... that worked for me ...
NoOne=NBA=
« Reply #3 on: January 27, 2005, 06:24:32 pm »
Did you buy the "high-lip" trackball?
If not, you probably won't like the finished results with the plexi over the top.
ArcadeMaze
  • No-Edit-Allowed
  • Last login:April 11, 2025, 01:36:59 pm
« Reply #4 on: January 27, 2005, 06:49:20 pm »
That works great for a 3" trackball, but how do you handle a 2 1/4"?
Jakobud
  • Last login:April 07, 2026, 10:10:56 pm
« Reply #5 on: January 27, 2005, 06:53:18 pm »
Why don't you just lay your trackball mounting plate down on your lexan and use the mounting plate hole as your guide?
Hiub1
  • Last login:June 05, 2011, 11:43:25 am
  • www.sleepyjack.com
« Reply #6 on: January 27, 2005, 07:02:16 pm »
I am sure you could get a 2 1/4'' hole saw. That should work.
brained
  • Raised by Atari
    • Nux
« Reply #7 on: January 28, 2005, 03:26:13 pm »
ArcadeMaze
  • No-Edit-Allowed
« Reply #8 on: January 28, 2005, 03:29:54 pm »
Yes, I realize that 1/4 = .25, but on happs the hole measures out to 2.26 - I imagine to accomodate the rim around the trackball.  I was planning on having the rim flush with the top of the panel.
FractalWalk
  • Newbie
  • Last login:September 20, 2010, 06:12:37 pm
  • Life is time spent fighting entropy.
« Reply #9 on: January 28, 2005, 03:51:42 pm »
If you are worried about 1/100th of an inch then you have much better eyes than I do.
saint ganked my avatar.
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
« Reply #10 on: January 28, 2005, 04:02:42 pm »
They make adjustable "hole saws". Seen a thread on it once I did. but I cant find it now.
Edit
http://forum.arcadecontrols.com/index.php/topic,18515.0.html
« Last Edit: January 28, 2005, 04:07:19 pm by Shape D. »
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
« Reply #11 on: January 28, 2005, 04:11:10 pm »
I have used 2 1/4" hole saws and specified 2 1/4" for a laser cut for happs tballs and 2 1/4" is dandy
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #12 on: January 28, 2005, 05:14:35 pm »
Sort of depends which 3" happs model you got.  Happs has three: 1) normal (aka old school, aka atari), 2) high lip (aka goldenTee, aka GT), and 3) high ball.
One thread illustrating the differences (and different ways to mount).
There are a few others discussing this more in depth.  Search for threads with trackball, high, and happs, and by me. ;D
Robin
Knowledge is Power
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #13 on: January 29, 2005, 03:08:27 am »
It depends on how you want it to look.  The mounting plate has a hole larger than you need.  There is about a 1/8" lip around the trackball that fits into the hole of the plate.  So if you cut a hole the size of the mounting plate hole you will see the black lip of the TB uncoverd by lexan.  I would recommend measuring the TB once you get it.  I did the same here but I didn't measure quite right so I have some of the lip showing.  I wish I'd cut it smaller.
Also for a TB you may want to bevel/round the lexan to make it a bit smoother when you are sliding your hand over it.  Shown here is a 45 bevel made by a dremel.
Next I'll be on fries, and that's when the big money starts rolling in.
quarterback
« Reply #14 on: January 31, 2005, 11:29:26 pm »
Is that true?  For a 3" trackball you want a 3" hole?  Wouldn't that allow you to actually lift the trackball straight up out of the CP?   It seems like the hole would be smaller than the diameter of the trackball.
-- Chad Tower
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #15 on: February 01, 2005, 02:23:55 pm »
Yes, mostly. ;D  If you look at the picture above by Nannuu, you'll see some of the part of the black TB case called the "lip" aka "rim" around the ball.  The arcade standard for the outer diameter of the lip is 3" (or metric equiv).  The standard inner diameter is ~ 0.25 inches smaller (thus no balls popping out).
Now, if you are going to leave the lip completely under the plexi, then you can cut the plexi hole ~ 2.75 inches.  But then the ball is lower (yuck, IMO).
Or if you have happs "High Ball", both the outer and inner diameters of the lip are bigger, and you'd need to adjust the plexi hole accordingly.  But, again IMO, the high ball model pops off the rollers easier than the arcade standards.
All which leads to this illustration previously ref'ed above.
Robin
Knowledge is Power
