Author Topic: Alternative to shrink tubing?  (Read 2401 times)
pmc
  • Last login:February 07, 2026, 12:21:50 pm
    • website
« on: January 18, 2005, 11:59:59 pm »
I have some wires I soldered together but I forgot to use shrink tubing. It's too late to slip it on because both ends are soldered too. I've used electrical tape before, but it often unsticks and comes off unless I twist it on really tight.
What's an alternative or best practice? I don't want a short happening.
-pmc
stevejt
  • Last login:January 01, 2022, 01:21:32 pm
  • stevejt.com
    • My site
Re: Alternative to shrink tubing?
« Reply #1 on: January 19, 2005, 12:11:53 am »
cut, slip on tubing, resolder.  How long could it take? A minuteafter the iron is hot?
Steve
Ken Layton
  • Guru
  • Technician
« Reply #2 on: January 19, 2005, 12:41:47 am »
Try MCM Electronics (www.mcminone.com) Cold Shrink Tape # 21-3535 or 21-3545.
There is also made "Heat Shrink Tape" which works just like heat shrink tubing but it's in a tape form.
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #3 on: January 19, 2005, 01:00:07 am »
I've seen a "liquid electrical tape" that you can just paint on connections.  I've never used it, so I can't speak as to how well it works.  I imagine it's like that Plasti-Dip stuff for tool handles...
Rocky
« Reply #4 on: January 19, 2005, 08:25:29 am »
I hate when that happens
pmc
    • website
« Reply #5 on: January 19, 2005, 08:38:12 am »
Thanks guys. Lot's of options.
And simply redoing it never occured to me for some reason.
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #6 on: January 19, 2005, 08:39:15 am »
It works great! It takes a little getting used to & you'll want a different brush than the one in the can.  The one in the can is always too stiff...
Anyhow, I've used this to protect a few projects & even when I was too lazy to solder some wires together... Just twist really tight & smother with "liquid electrical tape". Haven't had a problem yet.
I'm not a freak!...
Oh wait...
Yes I am...
JThw8
  • Last login:November 24, 2010, 10:31:15 pm
« Reply #7 on: January 19, 2005, 09:07:11 am »
I'll second that, liquid electrical tape is some good stuff.  I use it alot on different things that are just not suitable for heat shrink wrap and it works fine.  Always good stuff to keep around just in case.
Hoagie_one
  • Um....whats a cabinet
« Reply #8 on: January 19, 2005, 09:09:25 am »
what about globs of hot glue?
somunny
  • Is it hot in here?
« Last Edit: January 19, 2005, 10:26:50 am by somunny »
Beeeph
  • Last login:October 18, 2006, 12:31:44 pm
« Reply #10 on: January 19, 2005, 03:23:06 pm »
CAT5 Cable.
Hoagie_one
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #12 on: January 19, 2005, 03:34:00 pm »
CAT5 Cable.
What? how is Cat5 going to help him protect the connection?  ??? ???
That liquid electrical tape works fine, but if it were me, I'd just snip the wire and do it again.
first off your and idiot
Beeeph
« Reply #13 on: January 19, 2005, 05:47:27 pm »
CAT6 cable then.
Lilwolf
« Reply #14 on: January 19, 2005, 05:53:05 pm »
Cat5 stinks for cabling... Well... not really... Solid core wires stink for cabling until you solder...
but have you tried the two sided crimp on connectors... There is a name for them... And they work.  I got a box of 100 for a few bucks years ago.  I did one control panel using them... But now I'm moving towards using screw in terminal blocks.  But these are part of my hotswap setup.
somunny
« Reply #15 on: January 19, 2005, 06:30:41 pm »
Couldn't get my link to work, either.
