Author Topic: Has anyone had an issue with oversized disconnects?  (Read 1828 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: January 15, 2005, 10:16:06 pm »
I ordered my quick disconnects for 22 AWG wire from Hosfelt. Now that I'm wiring up my controls, I've discoverd that they are slightly too big and are fairly loose on the microswitches.  So loose, that even moderate jolting dislodges them from the switch.
Has anyone else encountered this issue? Where could I get disconnects that have a tighter fit?
KrawDaddy
  • Last login:February 19, 2007, 06:37:04 pm
  • I am a LOSER
Re: Has anyone had an issue with oversized disconnects?
« Reply #1 on: January 15, 2005, 11:01:06 pm »
did you buy .187 or .250?
All I ask is that my routers obey me as though they would the word of GOD!
quarterback
« Reply #2 on: January 15, 2005, 11:02:44 pm »
I gently squeezed my .250s on either side with a pair of pliers and they fit nice and tight on the male .187 tabs.
                            ___
squeeze here---> U  U  <--- and here
-- Chad Tower
shawnzilla
« Reply #3 on: January 15, 2005, 11:11:23 pm »
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #4 on: January 15, 2005, 11:27:51 pm »
Doesn't Peale sell them by the bundle?  Otherwise you'll have to raid the local hardware stores.
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #5 on: January 16, 2005, 12:53:00 am »
if theyre non insulated, i would either crimp them down or just throw a dab of solder on them
"Owens is the ringleader in the ass hat circus"  D K
crashwg
« Reply #6 on: January 16, 2005, 07:02:45 am »
I had to tap every single one of mine with a hammer to get it to a tension I thought was acceptable...  It was as simple as tap-tap, check fit, tap-tap...
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
« Reply #7 on: January 16, 2005, 12:13:43 pm »
The ones I got from Peale were somewhat loose, I had to squeeze them a bit to make them tight.
Trimoor
  • Last login:November 18, 2006, 09:01:46 pm
  • I like shooting out of helicopters.
    • Trimoor
« Reply #8 on: January 16, 2005, 01:56:32 pm »
I gave up on quick connects and just soldered the wire to the switch.  Its much faster and easier.  I wish I did it earlier.
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:October 08, 2024, 04:40:31 am
  • I am t3h GAY!!!
« Reply #9 on: January 16, 2005, 02:05:33 pm »
Until you have to replace one.
It takes all of one second to pinch the quick connect a little with a pair of pliers. Quick connects are not all going to be open the exact same amount to start with anyway. It is not like they are a highly tuned pieced of scientific equipment. We are talking mass produced, bulk packaged, little pieces of light metal that slides over another piece. Not much harm can be done in a little pinch.
SirPeale
  • Green Mountain Man
« Reply #10 on: January 16, 2005, 02:07:37 pm »
Faster than a QD?  Strip, insert and crimp.  Takes me about six seconds.
