Author Topic: happ trackball question  (Read 1677 times)
muell67
« on: November 26, 2004, 03:55:05 pm »
I just recieved my happ 3" inch trackballl the translucent blue one with the usb and ps2 cable and wires for three buttons . I tested it out and it works great I just have one question and Im sure its a stupid one. There are wires coming from it that I dont know what to do with they come to a single connector is this a ground or is it for power. the site says it has lights on it I just need a 12v power source is this wire for that?
paigeoliver
  • Awesome face!
Re: happ trackball question
« Reply #1 on: November 26, 2004, 06:05:37 pm »
Pictures, show us some pictures. Saying it has wires coming off it is only slightly more usefull than the standard thing people tell computer tech people "my computer did something, and it had all these words on the screen".
muell67
« Reply #2 on: November 26, 2004, 07:32:15 pm »
here is the pdf from happs site http://www.happcontrols.com/images/pdf/ins-0053.pdf
its the wires on the left.
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #3 on: November 26, 2004, 07:47:35 pm »
I'm pretty sure its a ground wire with that ring at the end of it.  If the wire is green, I'm sure its a ground wire.
first off your and idiot
muell67
« Reply #4 on: November 26, 2004, 08:06:33 pm »
yeah its green. I thought this thing would be grounded through the usb
paigeoliver
  • Awesome face!
« Reply #5 on: November 26, 2004, 08:09:32 pm »
The green thing is a different ground. Run it to your cabinet ground strap, or to your metal control panel and monitor frame if you don't have a cabinet ground strap.
It is there to get rid of static electricity.
muell67
« Reply #6 on: November 26, 2004, 08:24:51 pm »
thanks
paigeoliver
  • Awesome face!
« Reply #7 on: November 26, 2004, 08:29:17 pm »
If you have neither one of those, then run the sucker to the coin door or the third prong of the power outlet.
Matt Berry
  • Last login:September 11, 2018, 06:09:06 pm
  • llama kind of tastes like chicken
« Reply #8 on: November 27, 2004, 07:47:49 am »
Just so nobody has an accident connecting the green (earth) ground to a power strip, make sure you are connecting the green wire to a greenish colored screw on the outlet. The gold screw is for hot (Zap  :o ) typically black wire and the silver screw is neutral (still has potential to carry a load) which is the white wire.
ekans
  • Last login:December 27, 2004, 09:49:52 pm
  • To fly is fine, but to hover...divine.
    • Maritime Cobras
« Reply #9 on: November 27, 2004, 11:14:39 pm »
Yes I figured the green wires were the grounds too. Thanks for the info Matt, that could have been hari raising!  ::)
muell67, you say that you have the illumination source with yours, you just have to add 12v?
I have just received the same trackball but thought I had to add a little clip on LED or other light to get it to light up. Did yours come with a light? My ball is translucent, but I could not find any light source with it.
muell67
« Reply #10 on: November 28, 2004, 12:07:29 am »
no mine didnt come with a light source I miss read the description. I was going to take it off and putt some led's on it anyway. like these http://www.retroblast.com/reviews/lazer.html
