Author Topic: Has anyone seen different colored Coin slots?  (Read 2857 times)
subzero23
  • Last login:April 24, 2017, 03:21:43 am
« on: November 13, 2004, 09:28:33 am »
The lightup part/reject button.....
I know they make them in amber now which I've really never ever seen on a real arcade game, but every arcade game I remember is red.....
I'm thinking about using blue ones on my cab, bad idea?
This user has been banned by saint and cannot reply. --- saint
Matt Berry
  • Last login:September 11, 2018, 06:09:06 pm
  • llama kind of tastes like chicken
Re:Has anyone seen different colored Coin slots?
« Reply #1 on: November 13, 2004, 09:46:03 am »
That's the nice thing about building your own, you have complete control over the whole design process and you can pick out the colors and design you want. The original arcades were all manufactured in a cookie cutter fashion with little thought on the overall design. Why change if it isn't broke. Point is don't be afraid to try new things a find something you like and makes it unique to you.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: November 13, 2004, 10:38:53 am »
I'm not much help here - someone was using LED's to light the coin doors, and I thought had a blue one.
Someone else I think had a photoshop file of the label that went on them that you could change to blue and maybe print of transparency film.
FWIW.
subzero23
« Reply #3 on: November 13, 2004, 10:44:07 am »
This is sort of offtopic but I got led to this question since I was looking at light wiring topics
how many fans would I need for a modern 2ghz computer?
Just one? Should I add more than one (they're cheap) and if so do I just use Y-adaptors like I would with coin mech lights? If so, where the heck do I put extra fans?
Matt Berry
« Reply #4 on: November 13, 2004, 12:47:37 pm »
Depends on how cool you want everything to run. Personally I use a lot of fans and prefer extra space between componets to increase air flow. Heat kills, my harddrives are spaced out and have a 120 mm fan blowing across them. From there I have 2 - 80 mm in the back, 1-80 in the side, 1 - 80 in the top, and then the fan in the power supply. I also have a zalman copper heatsink w/ 92 mm fan on the CPU. The processor stays nice n cool  ;) As for noise it is really quite, none of the fans produce more then 25 dba. Y-adapters or the fan monitoring plugs on the Motherboard will work fine.
shmokes
  • Don't tread on me.
    • Jake Moses
Best Kid iPad Apps
subzero23
« Reply #6 on: November 13, 2004, 02:46:43 pm »
Ya I definately think I might go with blue but I'm not sure, I'll wait a while and see how natural red looks
did you get replacement LEDs? if so what kind/color
rdagger
« Reply #7 on: November 13, 2004, 07:25:23 pm »
It would be cool if someone made clear ones.  Then you could change the coin slot colors with LED's.
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #8 on: November 14, 2004, 11:57:54 am »
SORT OF off topic :o
You may want to re-read the topic first.  That required a whole new topic.
Depending on the strength of the LED, IIRC, someone had yellow rejects and the blue LED STILL made them blue.  I'd have to guess that yellow is as close to clear as you'll find.
Pixelhugger
  • Last login:April 15, 2026, 10:01:57 am
« Reply #9 on: November 14, 2004, 04:54:39 pm »
Hulkster used blue ones on his showcase, see below. Seeing these convinced me to do the same. I guess it comes down to what color scheme you'll be using for the artwork and trim.
« Last Edit: November 14, 2004, 04:55:25 pm by Pixelhugger »
Project mega thread HERE
Rahzel
  • Last login:May 14, 2025, 11:23:34 pm
  • MAME4LiFE
« Reply #10 on: November 14, 2004, 05:45:55 pm »
I use 4 colors on my coin door to represent which player they belong to, it looks cool all lit up
« Last Edit: November 14, 2004, 06:50:02 pm by Rahzel »
paigeoliver
  • Awesome face!
« Reply #11 on: November 15, 2004, 01:37:24 am »
I'm not sure I would pay actual money for different colored coin slots, but I must admit that they do look nice.
Tailgunner
« Reply #12 on: November 15, 2004, 03:45:53 am »
I would if buying a new coin door, why Happ doesn't supply them with red coin return buttons I don't understand.
danny_galaga
  • Last login:April 17, 2026, 10:06:35 pm
    • dans cocktail lounge
« Reply #13 on: November 15, 2004, 08:22:16 am »
hehe. i think we were seperated at birth. i bet we're identical twins. only, of course i'm more identical than you  ;D
DrewKaree
  • HAH! Nice one!
Re: Has anyone seen different colored Coin slots?
« Reply #14 on: November 23, 2004, 12:59:27 am »
I'm betting we were the first and most successful Siamese twins....although I was probably born first....and better looking!
I'll be dropping you a pm to peruse...check it!  You should get a KICK out of it!
