Author Topic: Is there a std way to keep track of Jamma connections? Which wire goes where?  (Read 2041 times)
quarterback
Just bought an old cab (my 1st) and I'd like to pull everything so I can get inside and clean it up.  It's got a 4player CP connected to a Jamma board.  I can just start pulling the connectors apart and/or label each one, but I was wondering if that's necessary.
Is there a standard jamma wiring identification method based on wire color or something?  I'd just like to have the ability to reconnected each thing correctly after cleaning.
Also, what's the best way to clean the bottom of the buttons/joysticks?  They're not really dirty, just some cobwebs, but I figure if I'm going to clean the thing up, I should do it right.
-- Chad Tower
Ken Layton
  • Guru
  • Technician
The only wire colors standardized in JAMMA is the +5 volt (red) and Ground (black). Other wires in the JAMMA harness could be ANY color depending on who manufactured it. :o
quarterback
So, if I physically disconnect the wires from the controls themselves (by pulling the disconnects off the leaf-switch tabs), I either need to keep detailed notes about what-went-where or I'll be screwed when I try to put it all back together?
-- Chad Tower
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Well there is a standard JAMMA pinout that says that pin xx corresponds to P1B1 or coin return slot, etc etc.
Assuming your cab is wired correctly for JAMMA, and you can see where the wires are coming from on the harness, you could figure it out that way.  It might not be fun having to count out which wire is which, but it's possible.
first off your and idiot
paigeoliver
  • Awesome face!
There seems to be a bit of a color standard now based on the colors bob robert uses in his harnesses, but this does no good for old cabs.
The only reason I say that was that my new Multiwilliams panel from apollo amusements matched the color of EVERY SINGLE WIRE on my new bob roberts jamma harness.
SirPeale
  • Green Mountain Man
Maybe it was one of Bob's harnesses?
Here's a JAMMA pinout:
http://www.pealefamily.net/tech/mame/jamma.html
Goz
  • KOTA
You can get a new JAMMA harness for between $10 and $20 from Bob or eBay, etc. These hardness' are usually labled. If you are doing a clean up... You could replace the harness.
-Goz
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
I followed Bob's JAMMA harness instructions on how to group the wires with cable ties. I then labelled each group with a piece of masking tape (ie: "video", or "Player one"). You could take it a step farther and label each wire.... Why not? I didn't because the JAMMA connector itself is labelled.
NO MORE!!
paigeoliver
  • Awesome face!
Well to clarify, I bought a new harness from bob, and a pre-wired multiwilliams panel from Apollo amusements, and the colors of all the wires matched. They wouldn't have been chopping up Bob's harness's to make these (too costly to do that), so I must assume they made them the same color on purpose.
SirPeale
Paige: I misunderstood.  I thought that you bought a JAMMA harness from Appolo, and those colors matched one of Bobs.
quarterback
-- Chad Tower
