Author Topic: monitor/computer problems  (Read 1930 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
« on: August 01, 2004, 08:21:19 pm »
the computer i have for my cab has a 15" monitor and it shows up the horizontal games with about half the screen. is this a problem of the computer or monitor? on my regular desktop pc the hoprizontal games take up the whole screen, just not on the MAME one.  i have attached a picture to make it more clear. if it doesn't seem clear just post saying so and i will try to fix it. the white space is the space the games take up. the black is the space of the monitor. my desktop screen is a 17".
thansks in advance
SirPeale
  • Green Mountain Man
Re:monitor/computer problems
« Reply #1 on: August 01, 2004, 11:35:46 pm »
Might be a video card issue.  I recently obtained a Radeon PCI card that would display only off center images.  With some tweaking I could get a good picture, but that's with tweaking.  I pulled it and went back to my TNT2.
toffee
  • Last login:August 02, 2004, 06:18:47 pm
  • learning fast....
« Reply #2 on: August 02, 2004, 07:18:34 am »
you know - I am having a similar problem.  my usual dektop PC displays the games as "full screen"  but the PC I just built for my cab-in-progress shows them as you describe.  by tweaking the monitor x/y position and size seems to be working, but is a pain ...
is there an OS link to this? my desktop is XP, went for 98 on the cab PC.
Nefesis
« Reply #3 on: August 02, 2004, 09:01:10 am »
my cab pc is a 98 too, and desktop xp. will look for an os link.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: August 02, 2004, 11:50:17 am »
Can I point out to you that your Monitor's physical size has NOTHING to do with what you're displaying???
Check what RESOLUTIONS are being used. That's what makes a difference.
NO MORE!!
Tiger-Heli
    • Tiger-Heli
« Reply #5 on: August 02, 2004, 01:05:55 pm »
Here is what I do:
Set Windows to display at 800x600 (and 85 Hz but that's optional).
Adjust Windows desktop to be full screen.
Edit MAME.ini to have the following settings:
hwstretch               1
resolution              800x600
keepaspect              1
That should fix it.  If it doesn't, you might try using Multires from www.entechtaiwan.com.  This will try to "Lock" the refresh rate at 85 Hz.
Apart from this, if you are using an ATI card, the driver may say it is outputing 85 Hz and actually be displaying 60 Hz.  There is a registry change to fix this.
toffee
  • learning fast....
« Reply #6 on: August 02, 2004, 06:23:28 pm »
thanks for the reply tiger-h!
800x600 made things even worse, but playing around I set resolution in mame.ini to 1024x768 and now everything looks better.....
looking at the monitor setting, all games are running 1024x768 at 60 hz
a few games are a little "small" tho - e.g. smash tv. ill have another fiddle with the different options....
thanks again!
« Last Edit: August 02, 2004, 06:35:25 pm by toffee »
Tiger-Heli
    • Tiger-Heli
« Reply #7 on: August 03, 2004, 07:10:17 am »
thanks again!
Odd that 800x600 was worse . . . You DID select 800x600 in windows and adjust the desktop sizing using the screen adjustments on the monitor, correct?
toffee
  • learning fast....
« Reply #8 on: August 03, 2004, 07:43:49 am »
yeah - did that. I think its the crappy onboard videocard that is in the Dell PC I am using. I will see what other video cards I have in my big-box-of-crap that I can use.....
that said I am fairly happy now with the way it looks - its Full Screen or at least 80% on all games.
captainpotato
  • Last login:November 11, 2016, 06:10:59 am
  • I'm a tapir!
    • Tapir Design
« Reply #9 on: August 03, 2004, 08:34:29 am »
I just had this issue whilst configuring AdvanceMAME... those screenmodes that stayed like that were ignored, and I just used the ones that didn't have that problem (not an issue as there was at least one per resolution).
If you are not using AdvanceMAME, give it a go and that may solve your problems.
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
« Reply #10 on: August 03, 2004, 08:56:23 am »
Seems to me you need to use hardware stretch and forget about auto switching resolutions...
Edit:
Should have read the whole thread before replying, my bad...
« Last Edit: August 03, 2004, 08:57:08 am by MiKman »
