Author Topic: Anyone bother with a coin counter?  (Read 1859 times)
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« on: June 30, 2004, 11:39:09 pm »
I don't think I've seen it mentioned... Do MAME'ers ever bother installing working coin counters in their machines?
NO MORE!!
Walkinshaw
  • Last login:April 14, 2009, 12:02:57 am
Re:Anyone bother with a coin counter?
« Reply #1 on: June 30, 2004, 11:51:53 pm »
My current cab I ripped out the coin tray as to clean it up and paint it again. This involved cutting the wires to it from the Jamma harness and I dont think I will be connecting them back up... unless I want to charge every person who plays it and then see if the wife is skimming  ;)
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #2 on: July 01, 2004, 01:34:14 am »
I haven't seen a lot of them in MAME machines I've looked at, but it might be cool to add.
I just noticed a coin counter on my Xmen cab the other day... its up over 160,000.
first off your and idiot
Rocky
« Reply #3 on: July 01, 2004, 10:09:00 pm »
I hooked one up in a multi-Jamma cab I did, but not in my MAME cab.  But, it is always fun to hook up original equipment.  I'm using lockout coils in one of my cabinets just becuase they were there and I felt like making them work.
Go for it.
Rocky
rsoandrew
  • Last login:February 24, 2018, 09:02:10 am
  • Worldwide travelling Mame Machine
    • Andrew's Arcade
« Reply #4 on: July 02, 2004, 12:14:55 am »
I have a coin counter in my cab but don't know how it's supposed to be connected. It has two leads. One that says 12VDC and one for negative.
Anyone care to share how this is supposed to be connected?
Ken Layton
  • Guru
  • Technician
« Reply #5 on: July 02, 2004, 03:25:29 am »
Randy Fromm's site has meter hookup diagrams on his Super Secret Technical page.
JoeB
  • Last login:February 12, 2026, 11:59:45 am
  • NES Fanatic
« Reply #6 on: July 02, 2004, 07:52:16 pm »
I have one in mine..
it would be cool if I figure out how to reset it, and then hook it up so that the JPAC sends a signal to it when coin 1/2 is registered!  Think of it is a counter that keeps track how many times you played your machine.  :)
RayB
  • There's my post
    • RayB.com
« Reply #7 on: July 03, 2004, 11:32:35 am »
I was wondering about that. MAME would have to support sending a signal out to the counter. I doubt it does that???
You could hardwire the coin switch to the counter but I don't think the voltage is high enough. (Coin switch is what, 5v? And the counter needs 12v?)
NO MORE!!
Ken Layton
  • Guru
  • Technician
« Reply #8 on: July 03, 2004, 11:47:13 am »
Coin counter meters are available in many different voltages. Here are the DC voltage ones:
4.5 volt, 6 volt, 10 volt, 12 volt, 24 volt, 48 volt.
Here are the AC voltage ones:
12 volt, 24 volt, 48 volt, 120 volt
Remember that ALL coin counting meters use a PULSE to operate. To apply a constant voltage to them will burn them up!
Daniel270
  • Last login:April 10, 2011, 12:34:14 pm
  • Older Than PONG!!!
« Reply #9 on: July 03, 2004, 02:01:28 pm »
My cab's got a coin meter mounted over the coin box, under the mechs..... I left it unplugged (mainly because I'm clueless as to how to wire it).  I also like being able to show it off as is so that people can see how much business the machine made when it was still a full working NBA JAM  ;D
I Haven't Lost My Mind, It's Backed Up On Disk Somewhere.
hardcorevideogames
  • Last login:March 21, 2012, 09:35:35 pm
« Reply #10 on: July 03, 2004, 07:07:19 pm »
I dunno in real machines I never bother to hook them up usually , I restored a ms pac man and got some parts from Bob Roberts and I think he said the coin counters and original power supply cause lots problems , I guess thats why , and alot of newer games keep track internally how much money theve made anyways .
