Author Topic: aaaaa...my showcase cab cp base wobbles!!  (Read 5416 times)
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« on: May 24, 2004, 02:29:23 pm »
i moved my cp base into the carpeted area today and it wobbles.  its not uneven because it was sturdy on the garage floor.  i bought some of these leveling feet, that are about 1" in diameter (maybe a little more) and put 4 of them on the bottom of the cp base.  drilled holes, and all that.  well it wobbled more!  whats the deal?  how do i get the base to stay sturdy?  is there some carpenter trick that everybody uses for cabs on carpet?  right now its on berber carpet (not soft) but when i move into my apt. it will be on softer carpet and i know it will wobble then.  right now i just have it on big piece of wood underneath it...and that works to some degree, but im still not completely satisfied.  what can i do??  bigger levels?(wider)...i was told to get some cedar wedges(Shims)...kinda like those door stop things, but that will look retarded.  help!
krick
  • Gotta have blue hair.
Re:aaaaa...my showcase cab cp base wobbles!!
« Reply #1 on: May 24, 2004, 02:44:00 pm »
You need to adjust the leveling feet by screwing them in or out as necessary to level your cab.
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
hulkster
« Reply #2 on: May 24, 2004, 02:46:10 pm »
i thought about that, but will that make it rock solid even on carpet??
Sylentwulf
  • Last login:October 05, 2009, 09:13:35 am
    • The Electric Quarter
« Reply #3 on: May 24, 2004, 03:00:01 pm »
You're ALWAYS gonna have problems on carpet. If NOTHING else, the the way the individual fibers bend in haphazrd directions is going to make it SLIGHTLY uneven.
The ONLY REAL way, is to build a small (even 1") base and screw it through the carpet into the floor.
The other ways, as you mentioned, are the leveling feet (I wouldn't go self-leveling, they never work) or just moving it into various places all over the place until it's level.
Then there's my personal favorite, and that of carpeneters world wide. Yes. It's the end-all-be-all of levelling tricks.
The Shim. (I use cedar shingles since you can buy them by the bale for less than $20 instead of those LUDICROUS 4 shims for $3 packages)
EDIT - One other note. You DON'T want to level it permanently to where you're going to be if you E?VER plan on moving it. Some people will shave off the side that's too high, and then when they move, the OTHER side is too high, so they shave that off..... You see where this is going. Their end table turns into a coffee table.
« Last Edit: May 24, 2004, 03:07:44 pm by Sylentwulf »
BYOAC users get 5% off with coupon code byoac5
krick
« Reply #4 on: May 24, 2004, 03:25:23 pm »
Is it wobbling because your floor and/or cabinet is crooked or is it because your carpet is really spongy?
If it's spongy carpet, you might be able to build a square platform that it can sit on to give it a more solid base and spread out the weight more evenly.
Hantarex Polo 15KHz
hulkster
« Reply #5 on: May 24, 2004, 03:26:38 pm »
yeah thats probably what im going to have to do....put it on a big piece of wood.  oh well.
Lilwolf
« Reply #6 on: May 24, 2004, 04:55:14 pm »
You REALLY need to shave your carpet.
Pick your spot... Get some toenail clippers... or maybe your weed wacker if you want to speed things along..
boom... your done!
(but increasing the size of your feet will probably do it... they aren't currently supporting your cab... you want the entire set of weight on the four small feet... so they squish down the carpet..  Kinda like why you have treads in the rain... or you have no control... something needs to hit sturdy ground.)
NoOne=NBA=
« Reply #7 on: May 24, 2004, 05:45:42 pm »
Adding weight at the bottom of the base inside will help too.
That will lower the center of gravity, and make the CP push harder on the leveling feet to squish the carpet down harder.
bigmoe
  • Last login:July 16, 2004, 04:17:54 pm
  • I forgot my mantra!
« Reply #8 on: May 24, 2004, 05:53:48 pm »
This is a tad "ghetto" as they say, but:
You can use shims, paint them a color that matches your carpet (shouldn't be too hard for a berber carpet) or cab, and shim from a side (like the back) where they're not likely to be seen.
I did this for some bookshelves in my basement rec room and it's...ok.  Not great, but it works, is cheap, non-permanent, and portable.  The worst part about mine, really, is that it gives spiders one more place to hide...
b
What was that again?
AlanS17
    • AlanS17
« Reply #9 on: May 24, 2004, 06:16:31 pm »
OH! It's wobbly? That's a bad sign. You better give it to me...
hulkster
« Reply #10 on: May 24, 2004, 06:50:41 pm »
nice try bub ;D
quarterstringer
  • Last login:June 19, 2016, 03:35:04 pm
  • Rampart
    • Rampart
« Reply #11 on: May 24, 2004, 07:17:23 pm »
Maybe some metal spikes will help. Like the kind they put on the bottom of loudspeakers.
jace055
  • Last login:August 22, 2025, 09:32:12 pm
« Reply #12 on: May 24, 2004, 07:57:26 pm »
Try and see if it is the cabinet or the floor that is uneven.
Screw the leveling feet all the way in and rock the cabinet back and forth and take note of which feet come off of the ground. Then, rotate the cabinet 90 degrees and rock again.  If it is the same amount of rocking on the same feet then it is the cabinet.  But if the rocking is more or less, or on different feet, then it is the floor.
This will give you a better idea of how to solve the problem.
hulkster
« Reply #13 on: May 24, 2004, 09:03:10 pm »
well i dont think its the cab cuz it was rock solid on the concrete.  so im guessing its the leveling of the carpet.  ill try the levels, give more suggestions please if that doesnt work  :)
Knoxximus
  • Last login:December 19, 2011, 12:22:58 am
  • Young Frozen
    • Beat-TECH Productions
« Reply #14 on: May 24, 2004, 09:06:42 pm »
Wish I could help....mines is on marble tile.
Dumb questions deserve dumb answers.
Chris
    • Chris's MAME Cabinet
« Reply #15 on: May 25, 2004, 01:07:23 am »
I'm going with there's not enough weight in the control panel pedestal.  Put a square or two of paving stone in the base.
--Chris
--Chris
fredster
  • It's all good!
« Reply #16 on: May 25, 2004, 10:30:07 am »
How about cutting a piece of plywood a little smaller than the cab base and just putting it on that?  Then you have a nice firm surface to level the feet out on.
You can do that or you can put feet coasters under the leveling feet to give them a nice solid base.
jcoleman
  • Last login:March 15, 2025, 04:12:49 pm
  • RTFM
« Reply #17 on: May 25, 2004, 10:41:35 am »
The first thing to keep in mind:  three points define a plane.  When you introduce a 4th point, you have created two intersecting planes.  Your wobbly control panel is rocking between the two planes.
My suggestion is to remove the feet and replace them with three (not four!) sufficiently placed speaker spikes.  Post a picture of your cab and I can point out where to put them so you have maximum stability.
Coleman
jcoleman
  • RTFM
« Reply #18 on: May 25, 2004, 10:46:42 am »
Had a look at your cab.  Should have checked for that first.  :)
I'd put two spikes on the front and one in the center of the back.  Actually, if you can assume that the floor under the carpet is level (which is very likely IS), you can use four spikes, one under each corner.  This is of course assuming that your cabinet is perfectly square.  If not, stick with three.
Coleman
Mugzilla
  • Last login:May 23, 2020, 03:25:47 pm
  • Negative Ghost Rider,...
« Reply #19 on: May 25, 2004, 11:59:58 am »
No wobble
hulkster
« Reply #20 on: May 25, 2004, 12:49:19 pm »
No wobble
= pissed off mom
or once i move into my new apt.
= pissed off landlord
so no good on the cutting up the carpet.  i may try those level spikes or whatever.  ill go to home depot and ask them as well as to what to do.  thanks for the tips guys.
Chris
« Reply #21 on: May 25, 2004, 12:54:11 pm »
Just to humor me, throw a few of those barbell weights in the base of the pedestal and see if that helps stabilize it.  I really think the problem is that the control pedestal is top-heavy.
--Chris
hulkster
« Reply #22 on: May 25, 2004, 01:13:13 pm »
well i did do that actually.  but im not sure if it was enough.  i need like a 50 lb. weight to put in there.  right now, i think the most i had in there was like 30 lbs.  and it still wobbled some.  but i think you are right, its top heavy.  still, i should be able to make it stable.  on the concrete it was fine, so i guess the cp base is not uneven, i just to find something that will help it sit flat.  ill put all the weights i can find in the base and see what happens when i get home.  ill also try to get some leveling things to put in there as well.
unclet
« Reply #23 on: May 25, 2004, 03:04:43 pm »
Would it help if you installed 4 caster wheels on the bottom of the cabinet?  This way the full weight of the cabinet would not be distributed over the entire square base of the cabinet but instead only be distributed at the four points where the casters hit the floor/carpet.   This means an increased weight on your carpet to allow the carpet to be pressed down and not be as spongy.
Basically if you have the complete square bottom of your cabinet on the carpet, then the cabinet might not have enough weight to push all carpet beneath it down flat, but casters might help you get more weight in 4 specific spots only.
did that make sense .......?
Witchboard
« Reply #24 on: May 25, 2004, 03:52:19 pm »
That's why spikes have been suggested.  I really think this would be the way to go.  There are different kinds of spikes, but they all generally do the same thing.
hulkster
« Reply #25 on: May 25, 2004, 04:38:42 pm »
whoa, ive never seen those before!  looks like something you would find right before you go dueling with someone....choose your weapons...cept the screw would be that good of a...yeah...okay nevermind.  anyway, can i find this stuff at home depot?
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #26 on: May 25, 2004, 08:11:51 pm »
I think you need to lay off the alcohol.  Once you sober up a bit you'll find that the wobbling disappears  ;D
Best Kid iPad Apps
hulkster
« Reply #27 on: May 25, 2004, 08:42:07 pm »
ha, nice. 8)
Knoxximus
  • Young Frozen
« Reply #28 on: May 25, 2004, 09:58:18 pm »
Mine wobbbed a little bit, but once I screwed it back into the Monitor sectional, it's like the weight from the monitor stabilized it....unless the stabilizer elves came out while I was sleeping or something.....mmmmmmmmmm....elves....COOKIES.....yeah :D
hulkster
« Reply #29 on: May 25, 2004, 10:05:16 pm »
you got a picture?  i was thinking about screwing it into the monitor section but i wasnt sure how to do it.  so pretty please show a picture?!?! ;D
NoOne=NBA=
« Reply #30 on: May 25, 2004, 10:26:14 pm »
Just screw it to the FLOOR, and be done with it.
Unless you have some really weird carpet, the lag holes will never show until someone goes to replace the carpet.
hulkster
« Reply #31 on: May 25, 2004, 10:48:44 pm »
well i dont have a house....sooooo....no bolting to the floor ::)
Witchboard
« Reply #32 on: May 25, 2004, 11:52:56 pm »
I would give your local audiophile store a shout.  I don't think that a home improvement store would carry them, but you never know.
Lilwolf
« Reply #33 on: May 26, 2004, 08:43:19 am »
btw... did you increase the size of your legs?
The size of your feet will probably do it...
they probably aren't currently supporting your cab...
Kinda like why you have treads on your tires for the rain.  Or you have no control.  Something needs to move through the non-sturdy stuff and hit sturdy ground.
Lance
  • Last login:December 08, 2008, 10:20:09 am
  • banned
    • arcade.spamrevenge.com
« Reply #34 on: May 26, 2004, 10:15:31 am »
I second the motion for carpet spikes.  I have a set on my Mirage sub, and we have really thick carpet, the sub is rock solid.  The spikes I have are go right through the carpet and sit on the subfloor.  They are thin enough where they don't leave a mark on the carpet either.
Check out http://www.audiopoints.com/shopping.html
You can probably find some cheaper at your local stereo shop as well.
Lance
  • banned
