Author Topic: Cooling Custom Arcades??  (Read 2239 times)
Kampfflieger
  • Last login:April 24, 2025, 04:15:51 pm
  • The force is strong with my Cabinet.
« on: May 10, 2004, 07:49:56 pm »
If i put a motherboard without case inside a custom arcade, maybe it don't heat like if where inside the PC Case.
I'm open to good suggestions to cooling a custom arcade, beforehand thanx!!!
The Dark Side of the Force is the pathway to many abilities, some consider to be, unnatural."
rsoandrew
  • Last login:February 24, 2018, 09:02:10 am
  • Worldwide travelling Mame Machine
    • Andrew's Arcade
Re:Cooling Custom Arcades??
« Reply #1 on: May 11, 2004, 12:12:06 pm »
That's my plan too. I figure that as long as there are some type of vents in the back and some on the top of the cab, natural convection will take care of the rest. I
rsoandrew
    • Andrew's Arcade
« Reply #2 on: May 11, 2004, 12:12:19 pm »
Tilzs
  • Last login:February 16, 2011, 10:41:56 am
  • Neat
    • Cocktail Arcade
« Reply #3 on: May 11, 2004, 12:39:17 pm »
just cut some slots in the back for some vent slots and mount a pc case fan. You might want to have a couple slots with a couple of fans, maybe one blowing in and one out.
Monitor is going to generate most of the heat, and remember heat rises.
FoX
  • Last login:May 27, 2005, 03:32:01 pm
« Reply #4 on: May 11, 2004, 01:51:50 pm »
Yea...a fan pulling in cool air low and one expelling hot air uptop should be sufficient
Stingray
« Reply #5 on: May 11, 2004, 02:43:03 pm »
I put one fan inside the cab blowing across the processor heat sink. I then put another fan on the other side of the motherboard blowing the air out of the cab. This seems to keep everything nice and cool.
-S
spystyle
« Reply #6 on: May 14, 2004, 10:49:27 pm »
I recommend using 120mm computer fans connected to  the 5 volt line on the molex (instead of 12)
This results in very quiet cooling (who wants to hear the roar of computer fans when playing their arcade?)
also check www.pricewatch.com for a Zalman cpu cooler to quietly cool the processor.
In my opinion a quiet computer is an essetial part of keeping authentic (real arcade machines don't have roaring CPU fans) but cooling is also essential, so many 5 volt fans keep your cabinet extra groovy.
Dig it?
Craig
« Reply #7 on: May 15, 2004, 08:35:11 am »
I have a Zalman noiseless PSU.  The fan only comes on when required, and only to the required (low) rpm, so it is *very* quiet.  The PSU can also control the speed of other fans, so I have a Cooler Master regular case fan controlled from it (that spins slow+quiet too).  The only fan that really makes any noise is the CPU (blower) fan, which I can manually slow down to whatever speed I like (comprimise between noise/cooling).
DaveJ-UK
  • Last login:January 11, 2025, 04:20:37 am
  • Dirty Dawg
    • ChronicGames.NET
« Reply #8 on: May 15, 2004, 09:49:07 am »
I can recommend the Zalman range of silent cooling solutions too.
I have their pure copper heat sink / fan on my CPU. It barely makes a whisper, even at full speed.
AmericanDemon
  • Last login:February 27, 2026, 01:01:31 am
  • Still an AmericanDemon
« Reply #9 on: May 15, 2004, 10:45:16 am »
If you are planning to use the cabinet as a full on media center too, then stick a water cooling kit in there and sit back and watch it cool down.  :)
paigeoliver
  • Awesome face!
« Reply #10 on: May 15, 2004, 05:25:04 pm »
A few notes on this stuff.
I used to decase my computers in my Mame cabinets. I stopped doing it once I got a good look at the insides of several modern PC based arcade games. Every single one still has the computer inside the case.
So, keeping the computer in the case IS correct.
As long as your cabinet has SOME sort of ventilation then you will be fine. My (slotted) decased Athlon 650 powered micro-mini had NO ventilation, and it did get a little warm inside, but no warmer than the inside of any normal computer.
