Author Topic: Control Panel Plans  (Read 9678 times)
Demon-Seed
    • DemonCade (WORKING URL!)
Control Panel Plans
« on: April 24, 2004, 03:52:19 am »
Hi
Anyone have some links to good plans for control panels or templates?
euclidean
  • Last login:May 07, 2004, 09:49:15 am
  • some people think I look like this guy!
Re:Control Panel Plans
« Reply #1 on: April 26, 2004, 09:36:17 am »
TalkingOctopus
    • My Arcade
« Reply #2 on: April 26, 2004, 12:49:09 pm »
I have some control panel templates available on my website:
http://webpages.charter.net/rbecker5/files.html
mahuti
« Reply #3 on: April 26, 2004, 09:23:18 pm »
http://www.localarcade.com/4images
A lot of vector CPOs from the original games. A few templates there as well. Most of the AI files are at size.
Demon-Seed
« Reply #4 on: April 26, 2004, 09:25:18 pm »
Thanks guys but I made my own! ehhe turned out ok.. i have some pics if you want to see em its onlhyh wood right now.
Question-for tmolding.. i am very very scared to try to router the edge of the cp (I dont want to wreck it!!) any advice or alternatives?
walls83
  • beer is good
« Reply #5 on: April 26, 2004, 10:45:14 pm »
practice on scrap wood first
depressd
  • Last login:April 04, 2019, 04:29:33 am
« Reply #6 on: April 27, 2004, 11:59:44 am »
Do you guys use a standard spacing between buttons? Would 1/2" be to much?
TalkingOctopus
    • My Arcade
« Reply #7 on: April 27, 2004, 01:10:38 pm »
I believed there is 1" 1.5" between the center of each button on my layout.
« Last Edit: April 27, 2004, 03:53:58 pm by TalkingOctopus »
hyiu
    • www
« Reply #8 on: April 27, 2004, 01:47:12 pm »
1 inch ?? each button requires a 1 1/8 hole....
therefore... if the button is literally touching each other... you'll need each button to be 1 1/8 apart.... (and I believe the bottom is even wider because of the screw nut...)
if each button is 1 in apart... they're overlapping...
that can't be right...
TalkingOctopus
    • My Arcade
« Reply #9 on: April 27, 2004, 03:53:21 pm »
Yeah you're right.  It is 1.5". I'm sorry about that.
depressd
« Reply #10 on: April 27, 2004, 07:19:55 pm »
Question, I did a quick "sketchup" No pun intended  :P
These are the happs ultimate measurements. The inner circle is the button, next is the drill hole, and the last is the edge of the button. The 1 1/2" length from the center doesn't appear to be right. Did I do something wrong there?
« Last Edit: April 27, 2004, 07:22:38 pm by depressd »
TalkingOctopus
    • My Arcade
« Reply #11 on: April 27, 2004, 09:18:55 pm »
hmm... Go get this template: http://webpages.charter.net/rbecker5/files/joy.doc Print it.  Measure the space between the button centers.  I would measure the space on my actual machine but I do not have access to it at the moment  :'(.  I don't even have a ruler!
depressd
« Reply #12 on: April 27, 2004, 10:11:44 pm »
Nevermind, I believe that measurement is representing the radius of the distance and not the true length. If I measure from the edge out 1/2 to 3/4 to the next edge. It is represented correctly.
depressd
« Reply #13 on: April 27, 2004, 10:39:26 pm »
Has anybody used this type of button layout? Do you like it?
« Last Edit: April 28, 2004, 09:06:26 am by depressd »
flampoo
  • Last login:March 20, 2014, 11:41:07 am
  • BYObsession
    • flampoo
« Reply #14 on: April 27, 2004, 11:20:30 pm »
The most important question is, "do you like it?" It doesn't look too functional, though. It's a skewed SFII layout. But if it works for you, go with it.
« Last Edit: April 27, 2004, 11:21:40 pm by flampoo »
