Author Topic: Marquee Mounting  (Read 2538 times)
SuperRabbit0
  • Last login:July 07, 2006, 08:53:30 am
Marquee Mounting
« on: April 16, 2004, 01:40:55 pm »
I'm sure this a common question but I've searched everywhere and can't find the answer.
What do you use to mount you marquee?
I know Happs sells a marquee mount but I am not ordering anything else from them and I assume their is some product I can find at Home depot or the like that will also work acceptably.
Thanks for your help.
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
Re:Marquee Mounting
« Reply #1 on: April 16, 2004, 01:57:15 pm »
Some people route the top and bottom wood and slide it in the slot. Some get a mirror retainer (like what holds your bathroom mirror) and use that. Some just get a metal piece and bend it longwise. It all depends.
steve_pss
  • Last login:December 19, 2020, 06:56:53 pm
Re:Marquee Mounting
« Reply #2 on: April 16, 2004, 01:58:11 pm »
actally the happs stuff works well. ive used angle iron but it looks chooch compared the the happs retainer.
Doc-
  • Last login:April 09, 2007, 01:04:51 am
  • Carpe Arcadium!
    • Doc's Modular MAME
Re:Marquee Mounting
« Reply #3 on: April 16, 2004, 02:05:33 pm »
I just picked out some nice wood molding from Home Depot and made a frame around the marquee.
I then cut a narrow slot in the top panel on the machine so I could insert/remove it from the top without having to take the molding frame off.
« Last Edit: April 16, 2004, 02:08:53 pm by Mortalpawn »
Goz
  • KOTA
Re:Marquee Mounting
« Reply #4 on: April 16, 2004, 02:08:02 pm »
I actually way over ordered on my last Happs order. If you are local to me, I could part with some.
If you are in CA - Bay Area / Central Coast area it's yours.
-Goz
SuperRabbit0
Re:Marquee Mounting
« Reply #5 on: April 16, 2004, 09:00:24 pm »
Thanks so much for the offer but I am in Canada.  Airfare might be even more than shipping    ;D
On a related note, have any cabinets used a non-lit marquee?  This is going to be a very compact tabletop for my kids and I am not sure I want them to worry about turning the marquee on and off (and it might be a little too fun to do that if anyone with young kids knows what I mean...)
I am hesitant to leave out the backlight without seeing some examples of cabs built that way.
« Last Edit: April 16, 2004, 09:05:22 pm by SuperRabbit0 »
paigeoliver
  • Awesome face!
Re:Marquee Mounting
« Reply #6 on: April 17, 2004, 02:22:58 pm »
Sprint One, many ATW cabinets, and some other machines used unlit marquees.
AlexC
  • Last login:May 06, 2012, 05:18:05 pm
  • "Beware, I live!"
Re:Marquee Mounting
« Reply #7 on: April 17, 2004, 03:55:44 pm »
Home Depot sells metal corner pieces for a little over $2.00 . They are about 10 feet long and are colored white. I cut the pieces to size with a dremel, drilled the screw holes and painted them with black hammered spray paint I had left over from repainting a coin door.
They work and look great.
I'm at work so can't post any pics ATM but I can post some later if you want.
OSCAR
    • Oscar Controls
SuperRabbit0
Re:Marquee Mounting
« Reply #9 on: April 18, 2004, 01:06:17 pm »
All those suugestions are great!  Thanks so much for the help.  I am not sure how I couldn't find those previous threads.  I did look for a while...
Thanks again!
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
Re:Marquee Mounting
« Reply #10 on: April 19, 2004, 07:45:13 am »
Hmmmmm.....
I may try using the aluminum trim to hold in my marquee, and then install t-molding over top of it.
If you were to cut off the molding "spine", then I'm sure that hot glue would hold it in place.
%$#@!&* machine took my quarter!
spystyle
Re:Marquee Mounting
« Reply #11 on: May 19, 2004, 12:35:16 pm »
Nothing beats a HAPP marquee retainer, and it's only $20 shipped.
www.happcontrols.com
If you order this item from Happ's website it will cost $12.05 + $30.00 shipping as they use UPS by default. However, if you call Happ at 888-BUY-HAPP (289-4277) and order it with USPS shipping it will only cost $20 total ! It is part # 49-1000-00 "Retainer for video game marquee"
I don't think there will ever be a superior homemade alternative
Dig it?
Craig
rdagger
Re:Marquee Mounting
« Reply #12 on: May 19, 2004, 02:43:10 pm »
I stopped by the local hardware store last week and picked up a 6 foot piece of right angle aluminum for about $6.  The piece I bought is 1/2" x1/16"wide on each side.  They also sell bigger widths.  It looks very much like the original retainers found on many games.  The aluminum is very easy to cut and probably easy to paint.
OSCAR
    • Oscar Controls
Re:Marquee Mounting
« Reply #13 on: May 19, 2004, 03:00:51 pm »
That's exactly what I use in the 3/4" x 3/4" x 1/16" size.  You are correct, when painted black it looks nearly identical to what is found on many older games.  Check out this thread:  http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=19166.
