Author Topic: How to UnZIP multiple files at one time?  (Read 6969 times)
unclet
« on: March 24, 2004, 07:27:44 am »
I have a lot of ZIP files (4000+) which I would like to unzip at once time instead of clicking each one individually and selecting Extract.    Is there a way to select all files and extract to the same place?
Tiger-Heli
    • Tiger-Heli
Re:How to UnZIP multiple files at one time?
« Reply #1 on: March 24, 2004, 07:42:17 am »
http://www.filzip.com/en/index.html
Get and install Filzip.  It's freeware.  Enable the shell extensions.  Put all your zip files in the same directory (easier.)  Select all the files and right-click on them and select Filzip-Extract To.  Specify a destination directory, ensure "Same Directory" is selected, click ok and wait for it to finish.
unclet
« Reply #2 on: March 24, 2004, 08:18:14 am »
Thanks a lot.    What a big help.....
_Iz-
  • Last login:Yesterday at 10:23:42 pm
  • Time to coin up!
« Reply #3 on: March 24, 2004, 01:05:47 pm »
winzip can unzip multiple files at once...  select the files in windows explorer (ctrl + a    will select all files) then right-click in the selection. there should be some winzip options...  extract to here, extract to folder...  etc...
krick
  • Gotta have blue hair.
« Reply #4 on: March 24, 2004, 02:19:16 pm »
Just curious...
It looks like you're unzipping all your ROM files.  Why?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
CitznFish
  • Last login:November 13, 2024, 01:18:45 am
  • www.subvertcity.com - Prof. Strength Slackwear
« Reply #5 on: March 24, 2004, 02:25:56 pm »
winRAR does a great job of this as well...
Stingray
« Reply #6 on: March 24, 2004, 02:31:13 pm »
Just curious...
Wondering the same thing myself.
-S
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #7 on: March 24, 2004, 02:41:28 pm »
Side question:
How would you zip multiple files into seperate zip archives?
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
CitznFish
« Reply #8 on: March 24, 2004, 02:55:25 pm »
Doesn't that open multiple sessions of winzip, which then you have to manually close?
_Iz-
  • Time to coin up!
« Reply #9 on: March 24, 2004, 03:04:00 pm »
No.
_Iz-
  • Time to coin up!
« Reply #10 on: March 24, 2004, 03:07:32 pm »
Side question:
WinRAR can do that...  Select all the files, right click, then select winrar -> add to archive. Then in winrar on the "files" tab check "put each file to separate archive"  you can even change the compression type to zip instead of rar if you desire...
Mario
  • Last login:March 29, 2021, 08:55:12 pm
  • Mmmmm.....arcades!
    • Mario's Arcade Page
« Reply #11 on: March 24, 2004, 06:12:37 pm »
As an FYI, there's also this:
http://www.winzip.com/wzcline.htm
I use it within batch scripts.
Mario
unclet
« Reply #12 on: March 24, 2004, 10:06:15 pm »
The Atari2600, 5200, 7800 and NES Roms are all zipped, but needto be unzipped to the BIN or NES file extensions instead.   Of course for Mame I keep everything Zipped.
In WinZip, I could not find out how to extract multiple files.   It kept opening separate WinZip windows for each ZIP file I wanted to open and I did have to close each one individually.
I did not think of looking into WinRAR.   Anyway, FilZip works great....
Stormy151
  • Last login:June 11, 2011, 01:57:24 am
  • It was Dick Jones! DICK JONES!!!
« Reply #13 on: March 25, 2004, 12:09:01 am »
I use WinRAR, it's very good. :)
