Author Topic: LEDBlinky issues freezes in CoinOps  (Read 2858 times)
jlcpremier
  • Last login:June 06, 2026, 03:30:27 pm
« on: June 06, 2026, 03:30:30 pm »
I just got a Ultimarc Pac Drive board and set up LEDBlinky (trial version for now)  When CoinOps starts the buttons light up and animate for a few seconds, then freeze. If I launch a game though, the buttons used will light up correctly. Exiting out of the game the same stuck buttons light up in CoinOps FE. If I exit CoinOps I get an error from LEDBlinky.
Any idea how to fix this?
excaliburlives
  • Last login:June 11, 2026, 12:37:45 pm
Re: LEDBlinky issues freezes in CoinOps
« Reply #1 on: June 06, 2026, 06:13:11 pm »
I don’t use coin oips I use aattrack mode, had the same issue you did. Is your mame.cfg in the proper location? I’m sure there must be a way to set your file and folder location pointing to the files you need.
   For example, I need 3 files, a attractmode.cfg, Mame.cfg, and a Mame.xml for mine to work properly.
« Last Edit: June 06, 2026, 06:16:06 pm by excaliburlives »
