Author Topic: Ultimarc Ultimate IO Player 3 and 4 Wiring.  (Read 206 times)
mxpxpxpx
  • Last login:Yesterday at 09:09:34 pm
« on: May 15, 2026, 10:38:06 am »
Hello, I have a ultimarc ultimate IO and I am having trouble getting player 3 and 4 to work. When I try to configure the joysticks and buttons 3&4 are unresponsive.  Player 1 and 2 work. I have it wired right on the 3 and 4 spots on the IO. The IO board is set in X-input mode not keyboard mode. I have wired ground with the daisy chain for the player 1 and 2 buttons and joysticks. Does ground need to be different for player 3 and 4? I am using Batocera and when I try to configure them nothing happens. They could be working and it is a Batocera issue, I reall have no way else to test them. What could be wrong? Thanks again for all the help!!
Fursphere
  • Last login:Yesterday at 11:25:47 pm
Re: Ultimarc Ultimate IO Player 3 and 4 Wiring.
« Reply #1 on: Yesterday at 02:13:12 am »
XInput is like..  last resort with that board.   You really don't want to use it.  (and it kills LED support while active I believe).
Put it in keyboard mode, then if you really need Xinput for a particular game try https://gitlab.com/SchwingSK/Keyboard2Xinput
mxpxpxpx
« Reply #2 on: Yesterday at 09:08:21 pm »
I set it back into keyboard mode to be able to use all 4 joysticks.
I have set up the keys in winipac. I have set the keys in keyboardstopad in batocera, but that is as far as I get. None of the sticks or buttons work. I tried to map a controller, but it did not recognize anything. What is going on?  P1 controller only shows Default and 360 pad. I also tried following the custom control guide. Thanks for the help.
Fursphere
« Reply #3 on: Yesterday at 11:25:47 pm »
If I remember correctly, Batocera assumes gamepad controls (and its really picky about which gamepads it'll recognize).
The IPAC Ultimate is more suited for a Windows based build honestly.
