Author Topic: Do switchres monitor presets always display game content in some form?  (Read 7831 times)
nix999
  • Last login:Yesterday at 01:02:18 pm
I have a question about switchres presets such as pal ntsc and arcade_15.
Give that a game has a 'Working' status in MAME is it correct to expect GroovyMAME to show at least some output on screen when launched with a preset.
Using for example
./groovymame inthunt -monitor pal
or
./groovymame inthunt -monitor ntsc
or
I have Sony Trinitron PAL SCART television set that is used with a custom build Arch.
I tried to find information about the capabilities of the TV and slightly modified the arcade_15 settings found on
https://gitlab.com/groovyarcade/support/-/wikis/3-Post-Installation-and-Maintenance/3.5-Monitor-Definitions#built-in-monitor-definitions
to fit as much as possible and that range is in mame.ini and the monitor is set to custom.
I set the dotclock_min to 6.0 and tested some games like wboy, toki, sf2, cabal and they all center nicely and run absolutely fine.
Then I found out that my TV cannot display some content even though a valid mode gets calculated. It displays rolling content from top to bottom.
This is the case for mk, mk2, mk3 mk4 and likely others.
Next I made a bash script that reads the names from ./problematic_games.txt and if it is in there I get the refresh rate from the given game's xml and if it is lower then 55hz I launch it with
-monitor pal
and if it is above I launch it with
-monitor ntsc.
The idea is that I use the slightly modified arcade_15 preset to make as much games as possible run native - if I can call it that - and force the exceptions to pal or ntsc the TV can display.
All was fine at that point until ...
What I did not expect is to find games that loose sync on all presets.
From the looks of it they are all NeoGeo games such as In The Hunt and Puzzle Bobble. I tested other games and for one game the TV showed the blue information screen but it also lost sync after.
I do not understand what I am doing wrong.
Any hints about a correct approach please?
Thank you.
« Last Edit: November 30, 2025, 01:14:40 pm by nix999 »
Zebidee
  • Last login:Today at 06:13:31 am
Re: Do switchres monitor presets always display game content in some form?
« Reply #1 on: December 01, 2025, 04:46:17 am »
I've found that many TVs do OK at close to both 60hz or 50hz, but lose sync at close to ~55hz.
This being the case, the default generic_15 and arcade_15 default presets are insufficient as they cover a large range from 49.50hz to 65.00hz, without blocking out the middle frequencies. This means they can generate modes at ~55hz that the TV cannot display.
My solution was to create a custom monitor preset that includes multiple ranges, for both "NTSC" and "PAL". That way you can specify the valid frequencies for each. It looks something like this
monitor "ChinaTV1", "China TV - 50/60 Hz", "4:3"
        crt_range0 15625.00-15750, 49.50-55.00, 1.500, 4.700, 5.800, 0.191, 0.191, 1.056, 0, 0, 192, 288, 448, 576
        crt_range1 15625.00-15750, 55.01-62.00, 2.000, 4.700, 6.200, 0.256, 0.191, 1.200, 0, 0, 192, 248, 448, 480
The above example is what I use with my "China" TV. The switchres driver chooses the most appropriate crt_range based on the maximum number of permitted lines allowed. Each range has a max progressive lines specified, which I've bolded above.
For example: if you chose to launch MK2, which wants 254p, switchres checks the lowest range (crt_range1, "NTSC") first. This allows max 248 progressive lines, or 248p, not enough. So it moves onto the next range (crt_range0, "PAL"), which allows up to 288p, and uses a 256p video mode generated from that range.
You might have noticed that, in the above example, I didn't actually block out any frequencies around 55hz - that is because my "China" TVs are fine with handling 55hz. So why do I even use the split ranges? Because the TVs default to different screen geometries based around "NTSC" and "PAL" signals, and automatically change depending the signal received! By modifying the crt_ranges to align with this, the front/backporch values can be further tweaked to ensure a better "screen fit" for the video modes.
If you wanted to limit video modes to just those close to 50hz and 60hz, and block out most frequencies in-between, you might use a preset like this:
monitor "NTSC/PAL only", "PAL/NTSC 50/60hz only", "4:3"
        crt_range0 15600-15900, 49.50-50.00, 2.000, 4.700, 4.700, 0.064, 0.192, 1.056, 0, 0, 192, 288, 448, 576
        crt_range1 15600-15900, 59.50-61.00, 2.000, 4.700, 5.800, 0.064, 0.192, 0.898, 0, 0, 192, 248, 448, 480
You could even specify PAL for only 50hz exactly, and NTSC for only 59.94hz exactly, if you really wanted to.
The horizontal frequencies specified are less important. I usually just use the same for each crt_range, covering the total for both.
I guess you could specify a preset with three separate sets of crt_range values, hone in on those 55hz modes, but I don't see a compelling reason to do so with TVs - especially given they seem to usually default to "NTSC" or "PAL" modes of operation.
I don't know how Calamity thinks about this, or if this is what was intended - I "improvised" this approach based on existing implementations for dual-sync monitors. Looking at it a certain way, TVs that work for both 50hz and 60hz ARE dual-sync, auto-switching monitors. I don't know if this will work the same for you, but is what I've found works for me. Feel free to tinker, try playing around with it to see what works for you.
** Disclaimer: I use Win7+CRT_emulator+GM, not Retroarch, but I think all the same theory applies.
For further queries, maybe attach a log file.
« Last Edit: December 01, 2025, 04:48:48 am by Zebidee »
  • Last login:Yesterday at 06:12:50 pm
« Reply #2 on: December 01, 2025, 11:18:35 am »
Yes, the method explained by Zebidee is how this is supposed to be handled.
Yes, GroovyMAME will always show some output on the screen. If you have a certain game that goes out of sync, try to find the reason. If you have dotclock issues, 8.0 is a reasonable minimum (rather than 6.0). Note that the lower end of admitted dotclocks may have gaps (i.e. 5.5 may work, 5.6 not, etc.) until you find a number that works fine from there on.
nix999
« Reply #3 on: December 01, 2025, 02:20:04 pm »
Ok. Thank you for the detailed responses. I'll tinker a bit more and report back. I'll attach a log file if I can't sort it out. It might take some days. Probably next weekend.
One thing I do see is that my system never generates 2560x... modes. It is always much lower though 2560 is in mame.ini super_resolution it's called if I'm not mistaking.
I do not understand why it behaves that way but I'll document it and report back.
I also started from a fresh ini created with ./groovymame -cc.
The dotclock 6.0 is what made Cabal work.
I'm not using RetroArch. It's a bash shell with groovymame 0.280 and some scripts around it.
nix999
« Reply #4 on: December 02, 2025, 03:24:23 pm »
I got a whole lot further but I'm still not there.
I increased dotclock to 8.0
These two ranges make every game I started thus far run ~100%
crt_range0                15600-15800, 49.50-50.20, 2.000, 4.700, 5.800, 0.064, 0.192, 1.056, 0, 0, 192, 288, 448, 576
crt_range1                15600-15800, 59.30-60.50, 2.000, 4.700, 5.800, 0.064, 0.192, 0.898, 0, 0, 192, 248, 448, 480
The issue I have is that in general the screen is off to the left and too wide.
I can use the slider controls
CRT H size between 0.70 and 0.65
CRT H shift between -2 and -7
Seem to do the trick.
This means I need to adapt every game manually.
I already tried putting them in default.cg but they get stripped it seems. I might need to create a wrapper script to pre-create the cfg files.
I'll look into that a bit further.
But ideally the two ranges should be adjusted to cope with the issue I just described.
I do not succeed unfortunately.
The 2nd issue I have I cannot solve using the slider controls as there is no CRT V size in the slider menu.
If I use MAME's own Screen Vert Stretch combined with MAME's own Screen Vert Position or CRT V shift I get artifacts.
For In The Hunt for example in the bottom to top scrolling monster demo I see the background being re-drawn in a choppy way.
What really happens is that the Top op the screen is correct but the bottom section falls off.
I see for example the top letters in some demo scene perfectly positioned but the bottom score is 75% visible.
Ideally the two ranges should be adjusted to also cope with the issue I just described.
I do not succeed either unfortunately.
If I have to adapt every game for issue 1 so be it. I'd rather avoid to but it is manageable I of course would like to solve it in general.
But the 2nd one is worse ...
Can someone assist in adapting the two ranges I posted please or give me some hints how that's supposed to work.
Thank you.
EDIT: Perhaps this is helpfull:
inthunt.cfg
        <sliders>
            <slider desc="CRT H size" value="700" />
            <slider desc="CRT H shift" value="-2" />
        </sliders>
generated mode with these settings:
Switchres/SDL2: Detected SDL version 2.33.0
Switchres: Calculating best video mode for 320x240@60.012478 orientation: normal
Switchres: Modeline "640x240_60 15.603244KHz 60.012478Hz" 12.404579 640 665 723 795 240 242 245 260   -hsync -vsync
Switchres: Modeline "640x240_60 15.603244KHz 60.012478Hz" 13.262757 640 680 742 850 240 242 245 260   -hsync -vsync
So the first Modeline is a result from range_1 it seems and the 2nd one seems to be a recalculation based on the <sliders></sliders> tag
So the 2nd Modeline effectively solves problem1 - by hand - but not problem2
« Last Edit: December 02, 2025, 03:36:00 pm by nix999 »
Zebidee
« Reply #5 on: December 02, 2025, 05:31:36 pm »
You have "overscan". Almost every TV as this issue. When people watch TV they don't like seeing black, unfilled parts of the screen. So TVs are designed to make the picture a little larger. Sucks for gaming. Arcade monitors have pots so you can tweak the size to suit the game, TVs have little of that. The exact options available depend on your TV. Best place to start looking is in the TV's service mode.
For the TV - Every TV is different, but generally you can find service menu controls to vary vertical height & position, and horizontal position. Horizontal width control is sometimes possible, but probably not. You may have some other geometry controls for stuff like pincushioning.
For PC - You can trim back some of the horizontal width & position by modifying the front and back porch settings, which I've bolded above. You may find that different settings optimal for "NTSC" vs "PAL". You don't really get any control over vertical size with CRT_emulator.
Given all these limitations, I often dive right in and change the TV's width capacitor!  This is a large polypropylene capacitor near the flyback, HOT (horizontal output transistor) and yoke coils connector (visible in background of photo below). Obviously TVs vary, but it is usually a value like 384, 474, 564, usually rated for high voltage, typically 400v or higher. Substituting a slightly larger value brings the picture in a little.
In the example photo below, from an RGB mod of a JVC TV I did earlier this year, I swapped a 474 400v for a 684 630v, and this brought the picture in by around 1.5cm. For more detail, see my writeup of the JVC TV mod. I have probably also discussed it in earlier TV mods, if you want to look through them.
In terms of capacitor codes, pay attention to the "XX4" format - the number is capacity in nanofarads (nF) and "4" means number of zeros. So a 564 means 560,000 nF. Point is to stay close to that level, use a capacitor of similar but different value. For example, if you have a 474 cap, don't replace with a 473, but a 684 is probably fine. It is OK to sub in a capacitor with a higher voltage rating, but don't go lower than the original.
Also, be sure to use the same kind of capacitor (polypropylene in this case). You can buy kits of these capacitors (range of various values) from Aliexpress and similar. I recall walking the street in Bangkok's electronics district to see an old woman, with no teeth and a big smile, presenting a trestle table covered with these capacitors in bags of various values. Like she was selling bananas. Anyway...
Hacking your TV is obviously "risky" and taking it to the next level - not for everyone. However, I have done this particular hack around a dozen times and all is good. I don't know of a better way to reduce the built-in overscan in many TVs. Just don't blame me if something goes wrong! :D  8)
« Last Edit: December 02, 2025, 05:58:37 pm by Zebidee »
nix999
« Reply #6 on: December 03, 2025, 02:01:50 pm »
Ok ... I'll try tweaking the bolded values and I'll see how far it will take me.
But I'm wondering now ... if the xml tag triggers switchres to generate a 'perfect' modeline the 2nd time it must be possible to tweak crt_range0 and crt_range1 to immediately generate the 'perfect' mode the first time?
And crt_rangeX does not allow me to control the vertical height and position then? Probably the absence of the CRT V size is related to that ...
Perhaps the service menu could help indeed ... or a combination of things.
As for the soldering ... That's out of my league ...
The last thing I soldered was a new battery in a razor and it fried near instantly upon attaching it to the grid.  :o
I should have been easy but apparently the electronics in the charger didn't agree.
So that being said opening a television and soldering other stuff in it just might trigger my funeral.
I'm a programmer not an electrotechnician. I've always wanted to learn some electronics later in life but until now it just didn't happen.
Real life always intervenes.
Thank you for your valuable feedback.
Zebidee
« Reply #7 on: December 03, 2025, 07:30:11 pm »
We do what we can :D
Good luck and take care.
« Last Edit: December 03, 2025, 09:18:26 pm by Zebidee »
« Reply #8 on: December 04, 2025, 04:33:24 am »
Hi nix999,
Of course it is, all the geometry options do is to modify the default params in the crt_range line. The idea is to build a crt_range that gives the correct geometry first, and then only apply the UI tweaks in edge cases.
You can control the vertical position, but not the vertical height (or v-size). This is not a limitation of the software, but a real feature of the CRT technology. V-size control requires electrical adjustments happening inside the monitor that we can't request through the video signal itself.
makya
  • Last login:Today at 07:42:54 am
« Reply #9 on: December 05, 2025, 06:31:07 am »
I have a TRINITRON too, chassis FE-1A, I heard this is an easy one, at least easier than most other SONY's chassis of that era. It can sync any signal I had try, between 50-60, like R-TYPE, Mortal Kombat, Xexex or Psychic 5, but not without tinkering first.
Anyway, maybe it's just this set but, I found that going from 50Hz to 55Hz, synchronization is successful most of the time, while going from 60Hz to 55Hz is much less likely.
nix999
« Reply #10 on: December 11, 2025, 12:26:13 pm »
These two ranges work for me:
crt_range0                15600-15800, 49.50-50.20, 3.200, 4.700, 6.000, 0.064, 0.192, 1.056, 0, 0, 192, 288, 448, 576
crt_range1                15600-15800, 59.30-60.50, 1.300, 4.700, 7.000, 0.064, 0.192, 0.898, 0, 0, 192, 248, 448, 480
EDIT : dotclock has been set to 8.0
Combined with some modifications in the TV's service menu they give me full screen games both PAL and NTSC. So no squished video output anywhere.
Few games require adjustments using the sliders. Some do but not many and always minor adaptations.
I still have some vertical overscan.
I can get rid of it all but then there is a blue line and some artifacts in some titles probably because the TV is at its limits somehow.
So now I tweaked it to a degree that it always produces a satisfactory image in every situation. Perfect doesn't exist it seems.
In the mean time I compiled Retroarch and AttractmodePlus. If I use the two ranges in Retroarch it works standalone but if I launch something from AttractmodePlus it crashes. If I don't use the ini it works as expected.
Somehow it freaks out on the resolution change but I still might have some things to try.
It's all but a standard build but all in all very cool stuff.
« Last Edit: December 13, 2025, 03:40:26 am by nix999 »
Zebidee
« Reply #11 on: December 11, 2025, 08:02:20 pm »
Looks about right to me!
Ahhhh, wisdom!
In this context, perfection is a mirage. It perpetually seems to be be just over the next sand dune, you keep walking but you never get there.
Perfect image for every game has always been impossible, even in the original arcades. Arcade monitors are tweaked for a single game, or maybe a game system (like NeoGeo, Capcom etc.). If you put in a new board, you must tweak the monitor.
I use Attract-Mode and it all works smoothly. I use Win7 and a 720x480i desktop. The default layouts work fine, though I did tweak the "Basic" layout a little to make a better fit for TVs with overscan.
After you've finished fiddling with monitor presets and VMMaker, be sure to exit the GUI by clicking OK. VMMaker will then process the config, and in the console window you'll see a message "Exporting settings to mame.ini...". This is copying the crt_rangeX data into your mame.ini, which is what GM/switchres uses. If you don't complete this step then the application won't have the right settings!
So give that a go and see if it improves things.
It is indeed very cool  8)
« Reply #12 on: December 12, 2025, 04:25:38 am »
OP uses Arch so no vmmaker in there. The supported way for this on Linux is to make the Switchres compatible emulators pull their configuration from the global switchres.ini. In MAME this is done by enabling the switchres_ini option.
In the switchres repo you can find the geometry.py tool that helps with the process of adjusting geometry interactively and then exporting the resulting range to switchres.ini (although OP's already succeeded doing it manually). This works smoothly on Linux. The geometry tool works on Windows too. However, since it's command line based and there's no centralized switchres.ini, exporting from vmmaker as explained may be easier.
