Main > Driving & Racing Cabinets
Road Fighters 3D
vandale:
thanks guys, I will give it a try
vandale:
Hey guys. Got it working and in twin linked mode. Once again thanks to all the input and help.
For the record I used:
win10-64 latest updates
Unpatched game image
Removed D3d files x2
Copied Boomslangs jgt.dll
used old spice tools, new just refused to work:
spicecfg.exe
spicetools/32/kbt.dll
spicetools/32/kld.dll
spicetools/32/spice.exe
used latest FFBPlugin for controller mapping, exit mapping refused to work so used following ahk script compiled to exe and set as additional app in launchbox:
Escape::
Process,Close,spice.exe
Run,taskkill /im "spice.exe" /F
Process,Close,eaLocalServer
Run,taskkill /im "eaLocalServer.exe" /F
ExitApp
return
$5::LControl
For 2p link used Boomslangs guide:
Leave P1 files, only edit P2 files
open hex editor and load jgt.dll and go to Offset 0x5FA398 and change to
01 if P2
save file and now open dev/nvram/rfs.dat
and go to Offset 0x03 at the very start and change to
01 for P2
save and close hex editor and go play some Road Fighters 3D lan
holmes:
On my side controls do no work. I will try to apply your procedure.
Did you get the files from Virusman's site?
buttersoft:
EDIT: i was actually having some issues, after a while. Best to use the hacked files as above
From Boomslangz release notes for FFB plugin version 1.1:
--- Quote ---Added CabinetID code to Road Fighters 3D to not require hex edited files etc anymore. Simply select Cabinet ID in GUI and LAN Play will work :)
You need to have that set either way, or things can go a bit screwy.
I am having an issue where the shifter refuses to work in multiplayer. Works fine with two cabs before starting a multiplayer game, single player works ok on each, but when i go into a multiplayer game, the shifter does nothing. I'm using two G25's, and i tried rebinding, binding to different inputs, and i have definitely set sequential-only in the FFB plugin, but it doesn't help.
Nuexzz:
m.. obviously the game tries to read the same joy-d pad, try changing a p1 button for a key and your problem will be solved for sure. That is why I personally use joytokey and the joystick only for directions and to accelerate and brake (it is the only thing that it really works for) digital mode
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
