Author Topic: Groovymame latest version No nag and diff  (Read 10534 times)
fred92
  • Last login:March 03, 2025, 01:45:41 am
« on: July 04, 2021, 04:58:26 am »
Hello All  ;D
  compiled No Nag Groovymame .exe only and Diff file
or
compiled No Nag on my Github
0.251 is released
files are zipped with winrar
I have used this command to compile:
Code: [Select]
make -j5 OPTIMIZE=3 SYMLEVEL=1 SYMBOLS=1 STRIP_SYMBOLS=1
i used this command to patch my diff:
Code: [Select]
patch -p0 -E <C:\msys64\patchnonagxxx.diff
hope it could help and i will try to keep updated
any comments,any "thank you" are welcome
Fred.
« Last Edit: January 11, 2023, 12:46:16 pm by fred92 »
peterson65
  • Last login:December 13, 2025, 03:57:23 pm
Re: Groovymame latest version No nag and diff i would like to share
« Reply #1 on: July 07, 2021, 03:40:28 pm »
THANKS! :applaud:
peterson65
« Reply #2 on: January 04, 2022, 03:27:18 pm »
thanks for keeping up on this, needed groovymame 238 no nag  ;)
Dalba
  • Last login:August 18, 2025, 02:54:37 pm
« Reply #3 on: January 07, 2022, 10:42:46 am »
Hello,
It's been a long time since i compile mame, but today if i want to compile my own groovymame using a dev mame build version, where can i find a groovymame diff file to apply ?
fred92
« Reply #4 on: January 08, 2022, 02:22:29 am »
Hello,
There is no official diff for groovymame but :
you can create  your own
you can use mine
you can read the great tutorial  b4nd1t0.blogspot.com
Cheers,
Fred.
« Last Edit: January 08, 2022, 02:29:48 am by fred92 »
Elektronix
  • Last login:October 31, 2023, 02:45:09 pm
« Reply #5 on: April 08, 2022, 07:30:36 am »
Thank you, was looking for this.
bandicoot
  • Last login:April 19, 2026, 04:39:57 am
« Reply #6 on: May 31, 2022, 04:46:51 am »
thanks
vector1
  • Last login:May 04, 2026, 01:35:20 pm
« Reply #7 on: June 01, 2022, 10:45:38 am »
markran
  • Last login:October 23, 2025, 10:14:47 pm
« Reply #8 on: October 18, 2022, 08:12:36 pm »
Thanks!!!!!
beaches
  • Last login:April 03, 2026, 02:53:12 pm
« Reply #9 on: December 15, 2022, 06:51:15 am »
Thanks for your work!
« Last Edit: December 21, 2022, 05:12:23 pm by beaches »
Andypc
  • Last login:Yesterday at 02:03:13 am
« Reply #10 on: May 03, 2026, 05:50:44 pm »
Has anyone created a No Nag version of Groovymame 0.287
Andypc
« Reply #11 on: May 04, 2026, 02:31:22 pm »
or a No Nag version of Groovymame 0.285, as I can't seem to get 0.287 running on my system.
0.285 is working perfectly, but 0.287 give me the following error: -
"The procedure entry point std terminate could not be located in the dynamic link library api-ms-win-crt-private-l1-1-0.dll "
  • Last login:Yesterday at 10:10:28 pm
« Reply #12 on: May 04, 2026, 06:39:17 pm »
Sounds like this might be related to MAME moving to c++20 and win10/11.
In this thread, Robbbert links to a post he did on another forum that tells you how to make MAME work again with Win7.
https://forum.arcadecontrols.com/index.php/topic,170214.0.html
