October 19, 2025, 06:00:29 am
Yes, Add an outline and label it CUT LINE on the outside of the cut in several places
oh, you drew the line by hand on the sheet? if so, take a pic of it, insert the pic in photoshop and size it over your artwork, then create the line, Make sense?
If you had AutoCAD you could import the jpeg and then draw the lines and curves perfectly around it then export that LINEWORK to an EPS file and then import over top your Photoshop file.
